i.MX8MM operating points
7,111 次查看
pierluigi_p
Senior Contributor I
Dear NXP team,
in the file imx8mm.dtsi, the opp-table reports the same 3 operating points documented in tabled 10 of the SoC datasheet: 1.2, 1.6 and 1.8 GHz
However, in the file clk-pll14xx.c, the table imx_pll1416x_tbl reports also additional clock frequencies.
Can these additional frequencies be introduced in the opp-table to farther reduce the clock frequency ?
If yes, which values should be used for the properties opp-microvolts, opp-supported-hw, clock-latency-ns ?
Best Regards
Pier
7,077 次查看
Zhiming_Liu
Hi @pierluigi_p
Have sent your the patch.
10 回复数
7,078 次查看
Zhiming_Liu
Hi @pierluigi_p
5,541 次查看
PetersonJA68
Was the patch mentioned here ever provided publicly?  We are working on a new device using the iMX8MM and are interested in running at operating points below 1.2 GHz.
6,453 次查看
m_karabela
I would love to see this patch. I'm interested in lowest possible power consumption of imx8mm.
Can you share it?
6,601 次查看
dev_pcs
@Zhiming_Liu can you send me also the patch?
6,701 次查看
VilleS
Can you share the patch publicly also?
7,013 次查看
jxb4256
Can you please send this patch to me too?
7,070 次查看
pierluigi_p
Thanks @Zhiming_Liu,
one last question: can I share the patch with customers ?
Best Regards
Pier
7,067 次查看
Zhiming_Liu
Yes, you can share it.
6,494 次查看
gary_bisson
Senior Contributor III
In that case, can you share that patch here directly?
Also, could you elaborate as to why this isn't in the tree in the first place?
Gary
7,035 次查看
pierluigi_p
Hi @Zhiming_Liu ,
can this approach be used for NANO too ?
Best Regards
Pier
