i.MX8MM operating points
7,183件の閲覧回数
pierluigi_p
Senior Contributor I
Dear NXP team,
in the file imx8mm.dtsi, the opp-table reports the same 3 operating points documented in tabled 10 of the SoC datasheet: 1.2, 1.6 and 1.8 GHz
However, in the file clk-pll14xx.c, the table imx_pll1416x_tbl reports also additional clock frequencies.
Can these additional frequencies be introduced in the opp-table to farther reduce the clock frequency ?
If yes, which values should be used for the properties opp-microvolts, opp-supported-hw, clock-latency-ns ?
Best Regards
Pier
7,149件の閲覧回数
Zhiming_Liu
Hi @pierluigi_p
Have sent your the patch.
10 返答(返信)
7,150件の閲覧回数
Zhiming_Liu
Hi @pierluigi_p
5,613件の閲覧回数
PetersonJA68
Was the patch mentioned here ever provided publicly?  We are working on a new device using the iMX8MM and are interested in running at operating points below 1.2 GHz.
6,525件の閲覧回数
m_karabela
I would love to see this patch. I'm interested in lowest possible power consumption of imx8mm.
Can you share it?
6,673件の閲覧回数
dev_pcs
@Zhiming_Liu can you send me also the patch?
6,773件の閲覧回数
VilleS
Can you share the patch publicly also?
7,085件の閲覧回数
jxb4256
Can you please send this patch to me too?
7,142件の閲覧回数
pierluigi_p
Thanks @Zhiming_Liu,
one last question: can I share the patch with customers ?
Best Regards
Pier
7,139件の閲覧回数
Zhiming_Liu
Yes, you can share it.
6,566件の閲覧回数
gary_bisson
Senior Contributor III
In that case, can you share that patch here directly?
Also, could you elaborate as to why this isn't in the tree in the first place?
Gary
7,107件の閲覧回数
pierluigi_p
Hi @Zhiming_Liu ,
can this approach be used for NANO too ?
Best Regards
Pier
