i.MX8M Mini SAI3 UART2 RTS/CTS configuration
john_weber
It seems that the SAI3 UART2 configuration is missing from the pins-imx8mm.h file in the dt-bindings. Can you please take a look at the attached patch and confirm that it should work?
Labels (2)
Tags (2)
diegoadrian
We do not have ported the UART since the pin is already ported in the SAI3_RXC for the UART2_CTS and the SAI3_RXD for the UART2_RTS. These pins are already in use.
I apologize for the inconveniences that this could give.
Diego.
