i.MX8M DDR3L register programming aid difference
已解决
跳至解决方案
1,997 次查看
m_c
Senior Contributor I
There are two i.MX8M DDR3L register programming aid.
Old is MX8M_DDR3L_register_programming_aid_VAL_preliminiary_v1_2.xlsx from <https://community.nxp.com/docs/DOC-340268>.
New is MX8M_DDR3L_RPA_v6.xlsx from <https://community.nxp.com/docs/DOC-340179>.
May we know more detail about below two modifications?
1. New “K18”, it is related to “C175” & “D175” and the result will be changed for “0x3D400120”
2. Disable DDRC_DFIPHYMSTR in the latest version “6”, but in previous v1.2, the value is “1” that means the DDRC_DFIPHYMSTR is enabled. Should we set value to “0”?
标签 (1)
1 解答
1,821 次查看
gusarambula
Hello M.C.
Some details on the changes between revisions can be found on the Revision History sheet.
As for your questions this is the information I received from our experts:
1. IP vendor ticket STAR 9001091272 dictates that we should set DRAMTMG8.t_xs_x32 = DRAMTMG8.t_xs_dll_x32 to avoid timing violations from SRX to PDE in DDR3.
2. Disabled DDRC_DFIPHYMSTR.DFI_PHYMSTR_EN as it is not used for DDR3L PHY firmware.
As a side note, it’s always recommended to use the latest version of the programming aid.
在原帖中查看解决方案
2 回复数
1,821 次查看
gusarambula
Hello M.C.
I’m looking for more information on the changes between both versions. I will let you know as soon as I have an update.
1,822 次查看
gusarambula
Hello M.C.
