i.MX6 and SyncE
i.MX6 and SyncE
2,445 次查看
xav
does i.MX6 SoloX allow to use SyncE ethernet ?
If not, does another i.MX chip allow it ? Or even the soon-to-be i.MX7 ?
        Xav
标记 (1)
2,334 次查看
Hi Xavier
unfortunately i.MX6SX, iMX7 do not support in
hardware SyncE. I am not aware of future chips
where it will be supported.
5 回复数
2,335 次查看
Hi Xavier
2,334 次查看
xav
Hi Igor,
OK, I understand. Is it possible to still have SyncE by adding a different PHY, which will replace the built-in one ?
2,334 次查看
Hi Xavier
I am afraid not, because except PHY, it should be also supported by i.MX MAC.
~igor
2,334 次查看
xav
I'm not so sure, this PHY DP83640 | PHY | Ethernet | Description & parametrics  has been used on a Sitara AM335x and make it support SyncE, which I don't think it does natively.
Would it be usable on an i.MX ?
2,334 次查看
xav
Would adding a dedicated PCIe ethernet chip work ?
