i.MX6 SMFC enable
i.MX6 SMFC enable
1,638 次查看
sugiyamatoshihi
I have a question about sequence of SMFC enable by set SMFC_EN bit.
When SMFC make enable, IDMAM dma_active should activate before SMFC enable or after SMFC enable?
Sugiyama
标签 (3)
1,381 次查看
qiang_li-mpu_se
SMFC should be enable first, the IDMAC active (Set IDMAC channel ready) is the last step to enable the capture.
1,382 次查看
qiang_li-mpu_se
