Unable to duplicate a SD card with uboot/root/data
已解决
跳至解决方案
1,107 次查看
g__
I have a working sd card with 3 partitions (uboot / root / data) for an iMX 28 system.
I would like to duplicate the sd to another one.
I tried with several tools  (Win32 Disk Imager, ...) but it's not booting.
What's the right way to do it ?
标记 (2)
1 解答
1,022 次查看
qiang_li-mpu_se
You can dump the sd card on Linux PC or linux virtual machine:
sudo dd if=/dev/sdx of=~/dump.sdcard
Create the new card from the image:
sudo dd if=~/dump.sdcard of=/dev/sdx
在原帖中查看解决方案
1 回复
1,023 次查看
qiang_li-mpu_se
