i.MX6 SMFC enable
i.MX6 SMFC enable
sugiyamatoshihi
Contributor V
I have a question about sequence of SMFC enable by set SMFC_EN bit.
When SMFC make enable, IDMAM dma_active should activate before SMFC enable or after SMFC enable?
Sugiyama
Labels (3)
qiang_li-mpu_se
SMFC should be enable first, the IDMAC active (Set IDMAC channel ready) is the last step to enable the capture.
qiang_li-mpu_se
