how to Cut uboot
how to Cut uboot
2,418 次查看
lixuhui112
My uboot version is imx_v2014.04_3.14.28_1.0.0_ga,now I want to cut the uboot ,my board is mx6qsabresd ,
I want to remove support for the display and ethernet.What should I do,can someone guide me please?
Thank you very much!
标签 (3)
标记 (2)
2,159 次查看
Hi Xu
you can try to remove definitions for splash screen and fec
SPLASH SCREEN Configs
CONFIG_FEC_
also check attached Porting Guide Chapter 1 Porting U-Boot
2,159 次查看
saurabh206
Senior Contributor III
You can check include\configs\mx6sabre_common.h.
You can enable/disable functionality according to your requirement.
2,159 次查看
lixuhui112
