how to Cut uboot
how to Cut uboot
2,486件の閲覧回数
lixuhui112
My uboot version is imx_v2014.04_3.14.28_1.0.0_ga,now I want to cut the uboot ,my board is mx6qsabresd ,
I want to remove support for the display and ethernet.What should I do,can someone guide me please?
Thank you very much!
ラベル(3)
タグ(2)
3 返答(返信)
2,227件の閲覧回数
igorpadykov
Hi Xu
you can try to remove definitions for splash screen and fec
SPLASH SCREEN Configs
CONFIG_FEC_
also check attached Porting Guide Chapter 1 Porting U-Boot
2,227件の閲覧回数
saurabh206
Senior Contributor III
You can check include\configs\mx6sabre_common.h.
You can enable/disable functionality according to your requirement.
2,227件の閲覧回数
lixuhui112
