gstreamer1.0-plugins-imx build fail on IMX8MP
shlomz
HI,
when building gstreamer1.0-plugins-imx with yocto (6.1-langdale) it sequently builds libimxvpuapi2 which fails during its configuration stage on:
Checking for library hantro_h1 :
not found
The configuration failed
would appreciate the help.
thanks.
Tags (3)
Harvey021
Please share more details with what steps you've taken and error log.
Like what DISTRO AND MACHINE you build with?
I've tried to build with fsl-imx-wayland and imx8mp-lpddr4-evk. Found that some of open sources for this release have been changed. The BSP has been released a bit long. So, can you please use the new BSP and then built it?
Harvey
Harvey021
Harvey
shlomz
im using a custom MACHINE which is basically aligned with imx8mp-lpddr-evk.
I will try the new BSP and see if it works on imx8mp-lpddr-evk.
as I understand it, gstreamer1.0-plugins-imx should enable freerdp to work with the gstremer libs and thus have hw acceleration on vpu enabled, is it correct?
Harvey021
Is the build working for you with new BSP?
About the freerdp to work with gstremer libs, please raise a new ticket for further assistance.
Harvey
shlomz
yes, but only after updating the src for libimxvpuapi2 to a commit that includes this fix:
https://github.com/Freescale/libimxvpuapi/pull/62/commits/7ad208c83515c34f54200614e3ac6940a9dfb0fa
Otherwise, I get the same linker error during the build.
I suggest NXP updates the recipe
thanks!
Harvey021
Thank you, already inform the same to internal team for these updates.
Harvey
%3CLINGO-SUB%20id%3D%22lingo-sub-2040473%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Egstreamer1.0-plugins-imx%20build%20fail%20on%20IMX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2040473%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%2C%3C%2FP%3E%3CP%3Ewhen%20building%26nbsp%3Bgstreamer1.0-plugins-imx%20with%20yocto%20(6.1-langdale)%20it%20sequently%20builds%20libimxvpuapi2%20which%20fails%20during%20its%20configuration%20stage%20on%3A%3C%2FP%3E%3CP%3E%3CSTRONG%3EChecking%20for%20library%20hantro_h1%20%3A%20%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Enot%20found%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EThe%20configuration%20failed%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Ewould%20appreciate%20the%20help.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Ethanks.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2042422%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20gstreamer1.0-plugins-imx%20build%20fail%20on%20IMX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2042422%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%2C%20already%20inform%20the%20same%20to%20internal%20team%20for%20these%20updates.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards%3C%2FP%3E%0A%3CP%3EHarvey%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2042404%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20gstreamer1.0-plugins-imx%20build%20fail%20on%20IMX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2042404%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eyes%2C%20but%20only%20after%20updating%20the%20src%20for%20libimxvpuapi2%20to%20a%20commit%20that%20includes%20this%20fix%3A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FFreescale%2Flibimxvpuapi%2Fpull%2F62%2Fcommits%2F7ad208c83515c34f54200614e3ac6940a9dfb0fa%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FFreescale%2Flibimxvpuapi%2Fpull%2F62%2Fcommits%2F7ad208c83515c34f54200614e3ac6940a9dfb0fa%3C%2FA%3E%3C%2FP%3E%3CP%3EOtherwise%2C%20I%20get%20the%20same%20linker%20error%20during%20the%20build.%3C%2FP%3E%3CP%3EI%20suggest%20NXP%20updates%20the%20recipe%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Ethanks!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2042397%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20gstreamer1.0-plugins-imx%20build%20fail%20on%20IMX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2042397%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIs%20the%20build%20working%20for%20you%20with%20new%20BSP%3F%26nbsp%3B%3C%2FP%3E%0A%3CP%3EAbout%20the%20freerdp%20to%20work%20with%20gstremer%20libs%2C%20please%20raise%20a%20new%20ticket%20for%20further%20assistance.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards%3C%2FP%3E%0A%3CP%3EHarvey%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2040857%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20gstreamer1.0-plugins-imx%20build%20fail%20on%20IMX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2040857%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eim%20using%20a%20custom%20MACHINE%20which%20is%20basically%20aligned%20with%20imx8mp-lpddr-evk.%26nbsp%3B%3C%2FP%3E%3CP%3EI%20will%20try%20the%20new%20BSP%20and%20see%20if%20it%20works%20on%26nbsp%3Bimx8mp-lpddr-evk.%3C%2FP%3E%3CP%3Eas%20I%20understand%20it%2C%26nbsp%3Bgstreamer1.0-plugins-imx%20should%20enable%20freerdp%20to%20work%20with%20the%20gstremer%20libs%20and%20thus%20have%20hw%20acceleration%20on%20vpu%20enabled%2C%20is%20it%20correct%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2040786%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20gstreamer1.0-plugins-imx%20build%20fail%20on%20IMX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2040786%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3EPlease%20share%20more%20details%20with%20what%20steps%20you've%20taken%20and%20error%20log.%26nbsp%3B%3C%2FP%3E%0A%3CP%3ELike%20what%20DISTRO%20AND%20MACHINE%20you%20build%20with%3F%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI've%20tried%20to%20build%20with%20fsl-imx-wayland%20and%26nbsp%3Bimx8mp-lpddr4-evk.%20Found%20that%20some%20of%20open%20sources%20for%20this%20release%20have%20been%20changed.%20The%20BSP%20has%20been%20released%20a%20bit%20long.%20So%2C%20can%20you%20please%20use%20the%20new%20BSP%20and%20then%20built%20it%3F%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards%3C%2FP%3E%0A%3CP%3EHarvey%3C%2FP%3E%3C%2FLINGO-BODY%3E
