im using a custom MACHINE which is basically aligned with imx8mp-lpddr-evk.
I will try the new BSP and see if it works on imx8mp-lpddr-evk.
as I understand it, gstreamer1.0-plugins-imx should enable freerdp to work with the gstremer libs and thus have hw acceleration on vpu enabled, is it correct?
