Hi All,
I am trying to get the mkimage tool for building the SCU FW by using the steps mentioned in the following link:
On using "
git clone https://source.codeaurora.org/external/imx/imx-mkimage
I get the following output with the warning:
nikola@NikolaTesla:mkimage$ git clone https://source.codeaurora.org/external/imx/imx-mkimage
Cloning into 'imx-mkimage'...
remote: Enumerating objects: 63, done.
remote: Counting objects: 100% (63/63), done.
remote: Compressing objects: 100% (62/62), done.
remote: Total 2175 (delta 24), reused 0 (delta 0), pack-reused 2112
Receiving objects: 100% (2175/2175), 475.84 KiB | 959.00 KiB/s, done.
Resolving deltas: 100% (1373/1373), done.
warning: remote HEAD refers to nonexistent ref, unable to checkout.
And on doing checkout by using the command "git checkout imx_4.14.98_2.0.0_ga" i get the following output:
error: pathspec 'imx_4.14.98_2.0.0_ga' did not match any file(s) known to git
I tried using "git fetch" followed by "git checkout" but it did not fix the issue.
How to overcome this error?
Thanks and Regards,
Ramprakash
解決済! 解決策の投稿を見る。
 Zhiming_Liu
			Zhiming_Liu
I have tested below command is work:
git clone https://source.codeaurora.org/external/imx/imx-mkimage -b imx_4.14.98_2.0.0_ga
Zhiming
Hi Ramprakash,
Adding your branch with the command is necessary if you are using the latest version of git. ex:- "$ git checkout -b imx_4.14.98_2.0.0_ga". I hope it may help you.
 Zhiming_Liu
			Zhiming_Liu
Zhiming
It is definately dead now... and it is not on "codelinaro.org"..
"Thank you for your interest in codeaurora.org. As of March 31, 2023, all source repositories have been migrated to other platforms and the project has been shut down."
