format of SD card for flashing Android OS
1,079 次查看
Ruban1
which Format is recommended for SD card before creating partition and flashing Android OS. because in pdf its mention SD card should be unmount before flashing . So can you suggest me ,Should i format in FAT32 or NTFS format.
1,076 次查看
b36401
Actually it is never mind how the card is formatted. The format will be lost after re-partitioning of the card.
1,077 次查看
b36401
