feed RTC_XTALI with square wave
chris321
Hello Community,
I did not found anything about this in the datasheet.
Is it possible to feed the (analog) pin RTC_XTALI from the i.MX28 with a square wave?
For example the square wave output from an external RTC.
Best Regards
4guin4g4
Yes, a squared wave can feed the RTC_XTALI. yous be sure that it meets the specs in the RM:
"Since the internal RTC circuitry is powered from VDDXTAL which
voltage level is around 1.0V, the input 32K clock signal level on  RTC_XTALI should be 1V also. "
4guin4g4
chris321
Thank you Carlos,
I do not want to embarrass myself, but in wich Reference Manual did you found this sentence?
The downloadable version is Rev. 1, 2010, in this version I did not found it.
If I feed the XTALI with a 1V squared wave, what about the XTALO? Put it to GND, or let it floated?
WSLJ
%3CLINGO-SUB%20id%3D%22lingo-sub-274113%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Efeed%20RTC_XTALI%20with%20square%20wave%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-274113%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Community%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20did%20not%20found%20anything%20about%20this%20in%20the%20datasheet.%3C%2FP%3E%3CP%3EIs%20it%20possible%20to%20feed%20the%20(analog)%20pin%20RTC_XTALI%20from%20the%20i.MX28%20with%20a%20square%20wave%3F%3C%2FP%3E%3CP%3EFor%20example%20the%20square%20wave%20output%20from%20an%20external%20RTC.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%20Regards%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-274113%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX2x%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2252664%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20feed%20RTC_XTALI%20with%20square%20wave%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2252664%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3El%20aslo%20meet%20the%20same%20question%20with%20you.%3CBR%20%2F%3ERefer%20to%20below%20link%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2FCan-RTC-XTALI-connect-to-RTC-SQW%2Fm-p%2F2252653%23M242549%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2FCan-RTC-XTALI-connect-to-RTC-SQW%2Fm-p%2F2252653%23M242549%3C%2FA%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-274115%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20feed%20RTC_XTALI%20with%20square%20wave%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-274115%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%20Carlos%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22short_text%22%20lang%3D%22en%22%3E%3CSPAN%20class%3D%22hps%22%3EI%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22hps%22%3Edo%20not%20want%20to%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22hps%22%3Eembarrass%20myself%2C%20but%20in%20wich%20Reference%20Manual%20did%20you%20found%20this%20%3C%2FSPAN%3E%3C%2FSPAN%3Esentence%3F%3C%2FP%3E%3CP%3EThe%20downloadable%20version%20is%20Rev.%201%2C%202010%2C%20in%20this%20version%20I%20did%20not%20found%20it.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIf%20I%20feed%20the%20XTALI%20with%20a%201V%20squared%20wave%2C%20what%20about%20the%20XTALO%3F%20Put%20it%20to%20GND%2C%20or%20let%20it%20floated%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-274114%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20feed%20RTC_XTALI%20with%20square%20wave%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-274114%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EYes%2C%20a%20squared%20wave%20can%20feed%20the%20RTC_XTALI.%20yous%20be%20sure%20that%20it%20meets%20the%20specs%20in%20the%20RM%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%22Since%20the%20internal%20RTC%20circuitry%20is%20powered%20from%20VDDXTAL%20which%20%3C%2FP%3E%3CP%3Evoltage%20level%20is%20around%201.0V%2C%20the%20input%2032K%20clock%20signal%20level%20on%26nbsp%3B%20%3CSPAN%20class%3D%22%26amp%3Bquothighlight%22%3E%3CSTRONG%3ERTC_XTALI%3C%2FSTRONG%3E%3C%2FSPAN%3E%20should%20be%201V%20also.%20%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
