delay between the boot loader and kernel splash screens
9,731件の閲覧回数
divyardharan
We are using sabresd iMx6Q board.The boot loader splash screen is showing for 7 sec.After that the lcd screen is blank for 20 sec before the kernal splash screen is loaded.Kindly help us to solve the delay between the boot loader and kernel splash screens.
9 返答(返信)
8,140件の閲覧回数
jaymind
Hi Divya,
Is your splash screen custom image or default boot up logo ??
Can you please provide the kernel logs from start ?
in your kernel logs which you will provide me please marks when your screen appears, when screen becomes blank.
Just add line approximately above or below when you examine your kernel logs.
May be some configuration set and it was slowed due to it, I am not sure about it, but may be conclusion will come after your logs.
Jaymin D
8,140件の閲覧回数
divyardharan
Thank you for the response.
We are using custom image.
Kindly find the log below.
[LCD] Initializing LCD frambuffer at 27b00000
[LCD] Drawing the logo...
ipu_clk = 260000000
IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
Framebuffer at 0x27b00000
mxcfb_init_fbinfo: 4 640 112 524
Framebuffer structures at: fbi=0x27602c50 mxcfbi=0x27602e60
allocated fb @ paddr=0x27B00000, size=3145728.
Channel already disabled 9
Channel already uninitialized 9
setup_disp_channel1 called
bpp_to_pixfmt: 16
init channel = 9
pixclock = 64998000l Hz
panel size = 1024 x 768
pixel clk = 64998000
setup_disp_channel2: 95ffcff 1024 768 2048 27b00000 27c80000
bpp_to_pixfmt: 16
initializing idma ch 23 @ 027005c0
IPU DMFC DP HIGH RES: 1(0,1), 5B(2~5), 5F(6,7)
ch 23 word 0 - 00000000 00000000 00000000 E0001800 000BFC7F
ch 23 word 1 - 04F90000 009EC000 20E3C000 F2C1FFC0 00082CA0
PFS 0x7, BPP 0x3, NPB 0xf
FW 1023, FH 767, Stride 2047
Width0 4+1, Width1 5+1, Width2 4+1, Width3 7+1, Offset0 0, Offset1 5, Offset2 11, Offset3 16
MXC IPUV3 configured
XRES = 1024 YRES = 768 BitsXpixel = 4
IPU_CONF =       0x00000660
IDMAC_CONF =                0x0000002F
IDMAC_CHA_EN1 =        0x00800000
IDMAC_CHA_EN2 =        0x00000000
IDMAC_CHA_PRI1 =       0x18800000
IDMAC_CHA_PRI2 =       0x00000000
IPU_CHA_DB_MODE_SEL0 =      0x00800000
IPU_CHA_DB_MODE_SEL1 =      0x00000000
DMFC_WR_CHAN =        0x00000090
DMFC_WR_CHAN_DEF =             0x202020F6
DMFC_DP_CHAN =         0x0000968A
DMFC_DP_CHAN_DEF =               0x2020F6F6
DMFC_IC_CTRL =             0x00000002
IPU_FS_PROC_FLOW1 =               0x00000000
IPU_FS_PROC_FLOW2 =               0x00000000
IPU_FS_PROC_FLOW3 =               0x00000000
IPU_FS_DISP_FLOW1 =                 0x00000000
In: serial
Out: serial
Err: serial
Net: got MAC address from IIM: 00:10:2e:e0:00:02
FEC0 [PRIME]
### main_loop entered: bootdelay=3
### main_loop: bootcmd="run bootcmd_mmc"
Hit any key to stop autoboot:  3 2  1  0
********Power On Reset *****************
***Image validation flag=0******
*** Image Identifier flag is 0
Enabled Watch Dog Timer
System going to reboot within 120 sec, if watchdog not get feeding
file name=/
<2, 0, 204>
ext2fs read inode 2
ext2fs read 0 group descriptor (blkno 2 blkoff 0)
<4, 0, 32>
ext2fs read inode blkno 0 blkoff 0
ext2fs read inode blkno 262 blkoff 128
<524, 128, 128>
ext2fs_read_block 00000205
<1034, 0, 8>
<1034, 8, 1>
iterate >.<
ext2fs read inode 2
<4, 0, 32>
<524, 128, 128>
<DIR>       1024 .
<1034, 12, 8>
<1034, 20, 2>
iterate >..<
ext2fs read inode 2
<4, 0, 32>
<524, 128, 128>
<DIR>       1024 ..
<1034, 24, 8>
<1034, 32, 10>
iterate >lost+found<
ext2fs read inode 11
<4, 0, 32>
ext2fs read inode blkno 263 blkoff 256
<526, 256, 128>
<DIR>      12288 lost+found
<1034, 44, 8>
<1034, 52, 4>
iterate >home<
ext2fs read inode 14281
ext2fs read 7 group descriptor (blkno 2 blkoff 224)
<4, 224, 32>
ext2fs read inode blkno 57606 blkoff 0
<115212, 0, 128>
<DIR>       1024 home
<1034, 56, 8>
<1034, 64, 3>
iterate >mnt<
ext2fs read inode 36721
ext2fs read 18 group descriptor (blkno 2 blkoff 576)
<5, 64, 32>
ext2fs read inode blkno 147459 blkoff 0
<294918, 0, 128>
<DIR>       1024 mnt
<1034, 68, 8>
<1034, 76, 3>
iterate >etc<
ext2fs read inode 67321
ext2fs read 33 group descriptor (blkno 3 blkoff 32)
<6, 32, 32>
ext2fs read inode blkno 270339 blkoff 0
<540678, 0, 128>
<DIR>       1024 etc
<1034, 80, 8>
<1034, 88, 3>
iterate >lib<
ext2fs read inode 46921
ext2fs read 23 group descriptor (blkno 2 blkoff 736)
<5, 224, 32>
ext2fs read inode blkno 188419 blkoff 0
<376838, 0, 128>
<DIR>       3072 lib
<1034, 92, 8>
<1034, 100, 4>
iterate >root<
ext2fs read inode 6121
ext2fs read 3 group descriptor (blkno 2 blkoff 96)
<4, 96, 32>
ext2fs read inode blkno 24838 blkoff 0
<49676, 0, 128>
<DIR>       1024 root
<1034, 104, 8>
<1034, 112, 3>
iterate >dev<
ext2fs read inode 22441
ext2fs read 11 group descriptor (blkno 2 blkoff 352)
<4, 352, 32>
ext2fs read inode blkno 90115 blkoff 0
<180230, 0, 128>
<DIR>       1024 dev
<1034, 116, 8>
<1034, 124, 4>
iterate >sbin<
ext2fs read inode 8161
ext2fs read 4 group descriptor (blkno 2 blkoff 128)
<4, 128, 32>
ext2fs read inode blkno 32771 blkoff 0
<65542, 0, 128>
<DIR>       1024 sbin
<1034, 128, 8>
<1034, 136, 3>
iterate >usr<
ext2fs read inode 73441
ext2fs read 36 group descriptor (blkno 3 blkoff 128)
<6, 128, 32>
ext2fs read inode blkno 294915 blkoff 0
<589830, 0, 128>
<DIR>       1024 usr
<1034, 140, 8>
<1034, 148, 4>
iterate >proc<
ext2fs read inode 38761
ext2fs read 19 group descriptor (blkno 2 blkoff 608)
<5, 96, 32>
ext2fs read inode blkno 155651 blkoff 0
<311302, 0, 128>
<DIR>       1024 proc
<1034, 152, 8>
<1034, 160, 3>
iterate >opt<
ext2fs read inode 42841
ext2fs read 21 group descriptor (blkno 2 blkoff 672)
<5, 160, 32>
ext2fs read inode blkno 172035 blkoff 0
<344070, 0, 128>
<DIR>       1024 opt
<1034, 164, 8>
<1034, 172, 7>
iterate >linuxrc<
ext2fs read inode 10898
ext2fs read 5 group descriptor (blkno 2 blkoff 160)
<4, 160, 32>
ext2fs read inode blkno 41309 blkoff 128
<82618, 128, 128>
<SYM>         11 linuxrc
<1034, 180, 8>
<1034, 188, 3>
iterate >run<
ext2fs read inode 51001
ext2fs read 25 group descriptor (blkno 2 blkoff 800)
<5, 288, 32>
ext2fs read inode blkno 205062 blkoff 0
<410124, 0, 128>
<DIR>       1024 run
<1034, 192, 8>
<1034, 200, 6>
iterate >config<
ext2fs read inode 53041
ext2fs read 26 group descriptor (blkno 2 blkoff 832)
<5, 320, 32>
ext2fs read inode blkno 212995 blkoff 0
<425990, 0, 128>
<DIR>       1024 config
<1034, 208, 8>
<1034, 216, 3>
iterate >var<
ext2fs read inode 55081
ext2fs read 27 group descriptor (blkno 2 blkoff 864)
<5, 352, 32>
ext2fs read inode blkno 221446 blkoff 0
<442892, 0, 128>
<DIR>       1024 var
<1034, 220, 8>
<1034, 228, 3>
iterate >tmp<
ext2fs read inode 30601
ext2fs read 15 group descriptor (blkno 2 blkoff 480)
<4, 480, 32>
ext2fs read inode blkno 122883 blkoff 0
<245766, 0, 128>
<DIR>       1024 tmp
<1034, 232, 8>
<1034, 240, 3>
iterate >bin<
ext2fs read inode 44881
ext2fs read 22 group descriptor (blkno 2 blkoff 704)
<5, 192, 32>
ext2fs read inode blkno 180227 blkoff 0
<360454, 0, 128>
<DIR>       3072 bin
<1034, 244, 8>
<1034, 252, 3>
iterate >sys<
ext2fs read inode 57121
ext2fs read 28 group descriptor (blkno 2 blkoff 896)
<5, 384, 32>
ext2fs read inode blkno 229379 blkoff 0
<458758, 0, 128>
<DIR>       1024 sys
*******************Execute Primary Image ***********
mmc3(part 0) is current device
MMC read: dev # 3, block # 40960, count 8192 ... 8192 blocks read: OK
* kernel: default image load address = 0x10800000
## Booting kernel from Legacy Image at 10800000 ...
****CV1 Kernel Validation Based on CRC Algorithm***
Image Name: Linux-3.0.35-ts-armv7l
Image Type:   ARM Linux Kernel Image (uncompressed)
Data Size:    3379356 Bytes =  3.2 MB
Load Address: 10008000
Entry Point:  10008000
Verifying Checksum ... OK
********Image validated********
kernel data at 0x10800040, len = 0x0033909c (3379356)
## No init Ramdisk
ramdisk start = 0x00000000, ramdisk end = 0x00000000
Loading Kernel Image ... OK
OK
kernel loaded at 0x10008000, end = 0x1034109c
## Transferring control to Linux (at address 10008000) ...
Starting kernel ...
At this point the boot loader screen disappears and the Lcd screen is blank for 18 seconds.
Linux version 3.0.35-ts-armv7l (user@NTP-096) (gcc version 4.8.2 (Timesys 20140527) ) #1 SMP PREEMPT Fri Jan 2 13:14:44 IST 2015
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: XXXX YYYY device Target Board
Ignoring unrecognised tag 0x54410008
Memory policy: ECC disabled, Data cache writealloc
CPU identified as i.MX6Q, silicon rev 1.2
PERCPU: Embedded 7 pages/cpu @8c008000 s5440 r8192 d15040 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 194560
Kernel command line: setenv bootargs ${bootargs} console=ttymxc1,115200 ip=none root=/dev/mmcblk0p1 rootwait video=mxcfb0:dev=adv739x,BT656-NTSC,if=BT656,fbpix=RGB565 video=mxcfb1:dev=hdmi,1280x720M@60,if=RGB24 video=mxcfb2:dev=ldb,LDB-XGA,if=RGB24,bpp=24,fbpix=BGR32 ldb=dul0 video=mxcfb3:off consoleblank=0
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 512MB 256MB = 768MB total
Memory: 766668k/766668k available, 281908k reserved, 0K highmem
Virtual kernel memory layout:
vector  : 0xffff0000 - 0xffff1000   (   4 kB)
fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
DMA     : 0xf4600000 - 0xffe00000   ( 184 MB)
vmalloc : 0xc0800000 - 0xf2000000 ( 792 MB)
lowmem  : 0x80000000 - 0xc0000000   (1024 MB)
pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
modules : 0x7f000000 - 0x7fe00000 (  14 MB)
.init : 0x80008000 - 0x8003a000 ( 200 kB)
.text : 0x8003a000 - 0x809be838 (9747 kB)
.data : 0x809c0000 - 0x80a17360 ( 349 kB)
.bss : 0x80a17384 - 0x80a5fe18   ( 291 kB)
SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Preemptible hierarchical RCU implementation.
NR_IRQS:624
MXC GPIO hardware
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms
arm_max_freq=800MHz
MXC_Early serial console at MMIO 0x21e8000 (options '115200')
bootconsole [ttymxc1] enabled
Console: colour dummy device 80x30
Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
CPU1: Booted secondary processor
CPU2: Booted secondary processor
CPU3: Booted secondary processor
Brought up 4 CPUs
SMP: Total of 4 processors activated (6324.22 BogoMIPS).
print_constraints: dummy:
NET: Registered protocol family 16
print_constraints: vddpu: 725 <--> 1300 mV at 700 mV fast normal
print_constraints: vddcore: 725 <--> 1300 mV at 1150 mV fast normal
print_constraints: vddsoc: 725 <--> 1300 mV at 1200 mV fast normal
print_constraints: vdd2p5: 2000 <--> 2775 mV at 2400 mV fast normal
print_constraints: vdd1p1: 800 <--> 1400 mV at 1100 mV fast normal
print_constraints: vdd3p0: 2625 <--> 3400 mV at 3000 mV fast normal
hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step.
hw-breakpoint: maximum watchpoint size is 4 bytes.
L310 cache controller enabled
l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x02070000, Cache size: 1048576 B
CV1 *** mxc_pwm_probe
CV1 *** Got pwm for PWM for IR Board\n
bio: create slab <bio-0> at 0
mxs-dma mxs-dma-apbh: initialized
print_constraints: vmmc: 3300 mV
SCSI subsystem initialized
spi_imx imx6q-ecspi.0: probed
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Freescale USB OTG Driver loaded, $Revision: 1.55 $
mc_pfuze 1-0008: recv failed!:-110,c8
mc_pfuze: probe of 1-0008 failed with error -1
imx-ipuv3 imx-ipuv3.0: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
imx-ipuv3 imx-ipuv3.1: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
MIPI CSI2 driver module loaded
Advanced Linux Sound Architecture Driver Version 1.0.24.
Bluetooth: Core ver 2.16
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
i2c-core: driver [max17135] using legacy suspend method
i2c-core: driver [max17135] using legacy resume method
Switching to clocksource mxc_timer1
NET: Registered protocol family 2
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
PMU: registered new PMU device of type 0
Static Power Management for Freescale i.MX6
wait mode is enabled for i.MX6
cpaddr = c0880000 suspend_iram_base=c08f8000
PM driver module loaded
IMX usb wakeup probe
add wake up source irq 75
cpu regulator mode:ldo_enable
  1. i.MXC CPU frequency driver
alg: No test for stdrng (krng)
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
###mxc_adv739x_i2c_init #1
###mxc_adv739x_probe #1
MIPI DSI driver module loaded
mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver adv739x
mxc_adv739x_setmode #1
Console: switching to colour frame buffer device 90x30
mxc_sdc_fb mxc_sdc_fb.1: register mxc display driver hdmi
mxc_hdmi mxc_hdmi: Detected HDMI controller 0x13:0xa:0xa0:0xc1
fbcvt: 1280x720@60: CVT Name - .921M9
mxc_sdc_fb mxc_sdc_fb.2: register mxc display driver ldb
_regulator_get: get() with no identifier
mxc_sdc_fb mxc_sdc_fb.3: Can't get fb option for mxcfb3!
imx-sdma imx-sdma: loaded firmware 1.1
imx-sdma imx-sdma: initialized
Serial: IMX driver
imx-uart.1: ttymxc1 at MMIO 0x21e8000 (irq = 59) is a IMX
console [ttymxc1] enabled, bootconsole disabled
imx-uart.2: ttymxc2 at MMIO 0x21ec000 (irq = 60) is a IMX
imx-uart.3: ttymxc3 at MMIO 0x21f0000 (irq = 61) is a IMX
Can't recover from RESET HBA!
No sata disk.
FEC Ethernet Driver
fec_enet_mii_bus: probed
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
fsl-ehci fsl-ehci.0: irq 75, io base 0x02184000
fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
add wake up source irq 72
fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller
fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2
fsl-ehci fsl-ehci.1: irq 72, io base 0x02184200
fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
ARC USBOTG Device Controller driver (1 August 2005)
mousedev: PS/2 mouse device common for all mice
i2c-core: driver [isl29023] using legacy suspend method
i2c-core: driver [isl29023] using legacy resume method
snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0
i2c /dev entries driver
max8903-charger max8903-charger.1: Invalid pin: chg.
max8903-charger: probe of max8903-charger.1 failed with error -22
imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=0)
Bluetooth: Virtual HCI driver ver 1.3
Bluetooth: HCI UART driver ver 2.2
Bluetooth: HCIATH3K protocol initialized
Bluetooth: Generic Bluetooth USB driver ver 0.6
usbcore: registered new interface driver btusb
sdhci: Secure Digital Host Controller Interface driver
mxc_hdmi mxc_hdmi: Read EDID again
sdhci: Copyright(c) Pierre Ossman
mmc0: SDHCI controller on platform [sdhci-esdhc-imx.3] using DMA
sdhci sdhci-esdhc-imx.0: no write-protect pin available!
mmc1: no vmmc regulator found
mmc1: SDHCI controller on platform [sdhci-esdhc-imx.0] using DMA
mmc2: SDHCI controller on platform [sdhci-esdhc-imx.1] using DMA
mmc3: SDHCI controller on platform [sdhci-esdhc-imx.2] using DMA
mxc_vdoa mxc_vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
VPU initialized
mxc_asrc registered
Galcore version 4.6.9.6622
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
usbcore: registered new interface driver snd-usb-audio
mxc_hdmi_soc mxc_hdmi_soc.0: MXC HDMI Audio
Cirrus Logic CS42888 ALSA SoC Codec Driver
i2c-core: driver [cs42888] using legacy suspend method
i2c-core: driver [cs42888] using legacy resume method
imx_3stack asoc driver
asoc: mxc-hdmi-soc <-> imx-hdmi-soc-dai.0 mapping ok
ALSA device list:
  #0: imx-hdmi-soc
NET: Registered protocol family 26
mmc0: new high speed DDR MMC card at address 0001
mmcblk0: mmc0:0001 MMC04G 3.52 GiB
mmcblk0boot0: mmc0:0001 MMC04G partition 1 16.0 MiB
mmcblk0boot1: mmc0:0001 MMC04G partition 2 16.0 MiB
mmcblk0: p1 p2 p3 p4
TCP cubic registered
mmcblk0boot1: unknown partition table
NET: Registered protocol family 17
mmcblk0boot0: unknown partition table
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
lib80211: common routines for IEEE802.11 drivers
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
Bus freq driver module loaded
Bus freq driver Enabled
mxc_dvfs_core_probe
DVFS driver module loaded
snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 00:00:11 UTC (11)
EXT3-fs: barriers not enabled
kjournald starting.  Commit interval 5 seconds
EXT3-fs (mmcblk0p1): using internal journal
EXT3-fs (mmcblk0p1): mounted filesystem with writeback data mode
VFS: Mounted root (ext3 filesystem) on device 179:1.
Freeing init memory: 200K
init started: BusyBox v1.20.2 (2014-07-11 16:18:48 IST)
mxc_hdmi mxc_hdmi: No modes read from edid
mxc_hdmi mxc_hdmi: create default modelist
mmc2: queuing unknown CIS tuple 0x01 (3 bytes)
mmc2: queuing unknown CIS tuple 0x1a (5 bytes)
mmc2: queuing unknown CIS tuple 0x1b (8 bytes)
mmc2: queuing unknown CIS tuple 0x14 (0 bytes)
mmc2: queuing unknown CIS tuple 0x80 (1 bytes)
mmc2: queuing unknown CIS tuple 0x81 (1 bytes)
mmc2: queuing unknown CIS tuple 0x82 (1 bytes)
mmc2: new high speed SDIO card at address 0001
mmc3: queuing unknown CIS tuple 0x01 (3 bytes)
mmc3: queuing unknown CIS tuple 0x1a (5 bytes)
mmc3: queuing unknown CIS tuple 0x1b (8 bytes)
mmc3: queuing unknown CIS tuple 0x14 (0 bytes)
mmc3: queuing unknown CIS tuple 0x80 (1 bytes)
mmc3: queuing unknown CIS tuple 0x81 (1 bytes)
mmc3: queuing unknown CIS tuple 0x82 (1 bytes)
mmc3: new high speed SDIO card at address 0001
Setting hotplug handler: [ OK ]
Creating device files: Auto-mount of [/media/mmcblk0p1] successful
EXT3-fs (mmcblk0p2): using internal journal
EXT3-fs (mmcblk0p2): mounted filesystem with writeback data mode
Auto-mount of [/media/mmcblk0p2] successful
EXT3-fs (mmcblk0p3): using internal journal
EXT3-fs (mmcblk0p3): mounted filesystem with writeback data mode
Auto-mount of [/media/mmcblk0p3] successful
EXT3-fs (mmcblk0p4): using internal journal
EXT3-fs (mmcblk0p4): mounted filesystem with writeback data mode
Auto-mount of [/media/mmcblk0p4] successful
[ OK ]
modprobe: module galcore not found in modules.dep
Setting timezone and system clock: hwclock: settimeofday: Invalid argument
[Fail]
Starting system logging.
Configuring network interfaces: ifdown: interface lo not configured
done
Starting dbus: [ OK ]
Starting ntpd: [OK]
****Executing Custom Script************ CV1: /dev/mmcblk1p1$ Not Mounted ****
48
Error count=0****Startup Error logged:19700101,  5:30:22.000, 30
****gadgetfs: USB Gadget filesystem, version 24 Aug 2004
AR6k module loading start...
Module Arguments...
Platform set to LOCAL_i686-SDIO
Platform Setup Script is: /home/plat_LOCAL_i686-SDIO.sh
Image path: /home
Mac address:
sdiostack loading
loading AR6K module... Args = (bmienable=1  ifname=wlan0 busspeedlow=0) , logfile:/tmp/dbglog.out
AR6000: configuration opcode 7 is only used for RTOS systems, not Linux systemsCompleted loading the module ar6000_avail_ev
BMI Write Register (address: 0x1c284, param: 0xf9104001)
BMI Write Register (address: 0x4020, param: 0x1)
BMI Write Register (address: 0x1404c, param: 0x28)
BMI Write Register (address: 0x14050, param: 0x20)
BMI Write Register (address: 0x14054, param: 0x20)
BMI Write Register (address: 0x14058, param: 0x20)
BMI Write Register (address: 0x1405c, param: 0x20)
BMI Write Register (address: 0x40e0, param: 0x100000)
Load Board Data from /home/ath6k/AR6003/hw2.1.1/fakeBoardData_AR6003_v2_0.bin
BMI Write Memory (address: 0x1234, filename: /home/ath6k/AR6003/hw2.1.1/otp.bin)
BMI Execute (address: 0x945d20, param: 0x0)
Return Value from target: 0x0
BMI Write Memory (address: 0x1234, filename: /home/ath6k/AR6003/hw2.1.1/athwlan.bin)
BMI Write Memory (address: 0x57fec8, filename: /home/ath6k/AR6003/hw2.1.1/data.patch.hw3_0.bin)
BMI Write Memory (address: 0x540618, value: 0x57fec8)
BMI Write Register (address: 0x5406a4, param: 0x16)
BMI Write Register (address: 0x540680, param: 0x8)
BMI Done
AR6K: ** HIF layer does not support scatter requests (17)
[ OK ]
[Fail]
done
Starting ntpd: [OK]
48
Module Arguments...
Image path: /home
Mac address:
sdiostack loading
BMI Done
AR6K: targetconf_ver : 1
Image path: /home
Mac address:
sdiostack loading
loading AR6K module... Args = (bmienable=1  ifname=uap0 busspeedlow=0) , logfile:/tmp/dbglog.out
BMI Write Memory (address: 0x1234, filename: /home/ath6k/AR6003/hw2.1.1/athwlan_router.bin)
BMI Done
AR6k module load Done...
/etc/init.d/S50-openssh: Creating system user 'sshd' with generic settings. Review and modify as required.
Generating public/private rsa1 key pair.
killall: hostapd: no process killed
killall: udhcpd: no process killed
info, udhcpd (v0.9.9-pre) started
error, max_leases value (234) not sane, setting to 9 instead
Configuration file: /home/hostapd.conf
killall: udhcpc,: no process killed
killall: wpa_supplicant: no process killed
Internet Systems Consortium DHCP Client V3.1-ESV-R3
Copyright 2004-2011 Internet Systems Consortium.
All rights reserved.
For info, please visit https://www.isc.org/software/dhcp/
channel hint set to 2412
ioctl[SIOCGIWESSID]: Invalid argument
Using interface uap0 with hwaddr 00:80:92:62:25:ec and ssid 'UltraGen2_AP'
WPA: Nonce1 - hexdump(len=24): [NULL]
Listening on LPF/eth0/00:10:2e:e0:00:02
Sending on LPF/eth0/00:10:2e:e0:00:02
Sending on Socket/fallback
eth0: Freescale FEC PHY driver [Micrel KSZ9021 Gigabit PHY] (mii_bus:phy_addr=1:01, irq=-1)
0x100019, Log file create
0x100095, ErrLogger_appndr_dbg_file_open()
QIconvCodec::convertFromUnicode: using Latin-1 for conversion, iconv_open failed
wlan0: Trying to associate with SSID 'Hospital_AP'
httpd not running, trying to start
gadgetfs: bound to fsl-usb2-udc driver
Suspend udc for OTG auto detect
fsl-usb2-udc: bind to driver gadgetfs
gadgetfs: suspended from state 2
/dev/gadget/fsl-usb2-udc ep1 configured
serial="o27dg4f58lqonneusbky1kaya77f3lua1vyqiojae05tf9nukjdrz1uq0x58e2u"
gadgetfs: connected
gadgetfs: disconnected
gadgetfs: connected
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 5
Your identification has been saved in /etc/openssh/ssh_host_key.
Your public key has been saved in /etc/openssh/ssh_host_key.pub.
The key fingerprint is:
26:0c:cd:34:a4:b2:c1:90:0d:8a:71:c3:78:76:4e:0f root@SABRE_SDB
The key's randomart image is:
+--[RSA1 2048]----+
|+*o .+          |
|===.E= .         |
|oo++ooo          |
| +.o.          |
| .   o S        |
| o         |
Generating public/private dsa key pair.
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 13
wlan0: CTRL-EVENT-DISCONNECTED bssid=00:00:00:00:00:00 reason=0
Your identification has been saved in /etc/openssh/ssh_host_dsa_key.
Your public key has been saved in /etc/openssh/ssh_host_dsa_key.pub.
b5:94:ed:5e:83:f9:1d:6c:db:84:12:0e:dd:04:ed:cc root@SABRE_SDB
+--[ DSA 1024]----+
| .o.  |
| + o.  |
| o = +E. |
| S . * ++.|
| . ..o|
Generating public/private rsa key pair.
Your identification has been saved in /etc/openssh/ssh_host_rsa_key.
Your public key has been saved in /etc/openssh/ssh_host_rsa_key.pub.
5a:6a:fe:0b:6b:bd:54:45:f7:e6:0a:87:6a:65:e2:eb root@SABRE_SDB
+--[ RSA 2048]----+
| .   o|
| . . o |
| S o = . .|
| + o = o . |
| o.+.. .     |
| .o.++E      |
Generating public/private ecdsa key pair.
Your identification has been saved in /etc/openssh/ssh_host_ecdsa_key.
Your public key has been saved in /etc/openssh/ssh_host_ecdsa_key.pub.
cb:5d:a0:39:85:44:33:d3:bd:7a:32:65:5f:91:7e:2d root@SABRE_SDB
+--[ECDSA 256]---+
| . =. .  o |
| . o  .. o|
| + .+ E.+|
| S  +.. o.|
| o .+     |
Starting /usr/sbin/sshd: Could not load host key: /etc/openssh/ssh_host_ed25519_key
[ OK ]
/etc/init.d/S64-apache-httpd: Creating system user 'daemon' with generic settings. Review and modify as required.
Starting apache-httpd
httpd (pid 2566) already running
BusyBox v1.20.2 (2014-07-11 16:18:48 IST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
# DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 12
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 14
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 3
No DHCPOFFERS received.
No working leases in persistent database - sleeping.
ÿ
U-Boot 2009.08 (May 15 2014 - 09:19:57)
CPU: Freescale i.MX6 family TO1.2 at 792 MHz
Thermal sensor with ratio = 173
Temperature:   27 C, calibration data 0x5484c469
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
ipg clock     : 66000000Hz
ipg per clock : 66000000Hz
uart clock    : 80000000Hz
cspi clock    : 60000000Hz
ahb clock     : 132000000Hz
axi clock : 264000000Hz
emi_slow clock: 132000000Hz
ddr clock     : 528000000Hz
usdhc1 clock  : 198000000Hz
usdhc2 clock  : 198000000Hz
usdhc3 clock  : 198000000Hz
usdhc4 clock  : 198000000Hz
nfc clock     : 24000000Hz
Board: i.MX6Q-SABRESD: unknown-board Board: 0x63012 [POR ]
Boot Device: MMC
DRAM: 1 GB
MMC: FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2,FSL_USDHC: 3
Using default environment
In: serial
Out: serial
Err: serial
FEC0 [PRIME]
Hit any key to stop autoboot:  0
Data Size:    3170380 Bytes =  3 MB
## Loading init Ramdisk from Legacy Image at 10c00000 ...
Image Name:   uboot initramfs rootfs
Image Type:   ARM Linux RAMDisk Image (gzip compressed)
Data Size:    4545326 Bytes =  4.3 MB
Load Address: 00000000
Entry Point:  00000000
OK
Starting kernel ...
Linux version 3.0.35-ts-armv7l (sfm@sfm) (gcc version 4.8.2 (Timesys 20140527) ) #1 SMP PREEMPT Wed Aug 27 14:25:16 IST 2014
PERCPU: Embedded 7 pages/cpu @8c008000 s5184 r8192 d15296 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 227328
Kernel command line: console=ttymxc1,115200 rdinit=/linuxrc enable_wait_mode=off
Memory: 640MB 256MB = 896MB total
Memory: 897220k/897220k available, 151356k reserved, 0K highmem
.init : 0x80008000 - 0x80097000 ( 572 kB)
.text : 0x80097000 - 0x80610598 (5606 kB)
.data : 0x80612000 - 0x806602e0 ( 313 kB)
.bss : 0x80660304 - 0x8068b254   ( 172 kB)
NR_IRQS:624
MXC GPIO hardware
arm_max_freq=800MHz
Brought up 4 CPUs
No AHCI save PWR: PDDQ disabled
Clockevents: could not switch to one-shot mode:
Clockevents: could not switch to one-shot mode: dummy_timer is not functional.
Could not switch to high resolution mode on CPU 3
Could not switch to high resolution mode on CPU 1
Could not switch to high resolution mode on CPU 0
TCP reno registered
Unpacking initramfs...
Could not switch to high resolution mode on CPU 2
Freeing initrd memory: 4436K
wait mode is disabled for i.MX6
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 1761
cryptodev: driver loaded.
mxc_sdc_fb mxc_sdc_fb.0: NO mxc display driver found!
fbcvt: 1920x1080@60: CVT Name - 2.073M9
Console: switching to colour frame buffer device 240x67
mxc_sdc_fb mxc_sdc_fb.3: register mxc display driver ldb
Serial: IMX driver
loop: module loaded
m25p80 spi0.0: found m25p05-nonjedec, expected sst25vf016b
m25p80 spi0.0: m25p05-nonjedec (64 Kbytes)
Creating 2 MTD partitions on "m25p80":
0x000000000000-0x000000100000 : "bootloader"
mtd: partition "bootloader" extends beyond the end of device "m25p80" -- size truncated to 0x10000
0x000000010000-0x000000010000 : "kernel"
mtd: partition "kernel" is out of reach -- disabled
GPMI NAND driver registered. (IMX)
vcan: Virtual CAN interface driver
FEC Ethernet Driver
g_file_storage gadget: controller 'fsl-usb2-udc' not recognized
check_parameters:UTP settings are in place now, overriding defaults
g_file_storage gadget: No serial-number string provided!
g_file_storage gadget: File-backed Storage Gadget, version: 1 September 2010
g_file_storage gadget: Number of LUNs=1
fsl-usb2-udc: bind to driver g_file_storage
egalax_ts 1-0004: egalax_ts: failed to read firmware version
egalax_ts: probe of 1-0004 failed with error -5
Linux video capture interface: v2.00
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video16
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video17
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video18
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video19
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video20
imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=1)
VPU initialized
mxc_asrc registered
ALSA device list:
  No soundcards found.
can: controller area network core (rev 20090105 abi 8)
NET: Registered protocol family 29
can: raw protocol (rev 20090105)
can: broadcast manager protocol (rev 20090105 t)
mxc_dvfs_core_probe
snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 00:00:00 UTC (0)
Freeing init memory: 572K
Starting UTP
ln: /etc/mtab: File exists
disable turn off display
Starting the hotplug events dispatcher udevd
udevd (1988): /proc/1988/oom_adj is deprecated, please use /proc/1988/oom_score_adj instead.
Synthesizing initial hotplug events
g_file_storage gadget: high speed config #1
uuc 0.4 [built Aug 16 2013 01:24:08]
UTP: Waiting for device to appear
UTP: file/device node /dev/utp already exists
cpu_id is 0
UTP: received command '$ ls /dev/*'
UTP: executing "ls /dev/*"
/dev/XOR                 /dev/ptyu7               /dev/ttyda
/dev/apm_bios            /dev/ptyu8               /dev/ttydb
/dev/console             /dev/ptyu9               /dev/ttydc
/dev/cpu_dma_latency     /dev/ptyua               /dev/ttydd
/dev/crypto              /dev/ptyub               /dev/ttyde
/dev/fb                  /dev/ptyuc               /dev/ttydf
/dev/fb0                 /dev/ptyud               /dev/ttye0
/dev/fb1                 /dev/ptyue               /dev/ttye1
/dev/fb2                 /dev/ptyuf               /dev/ttye2
/dev/fb3                 /dev/ptyv0               /dev/ttye3
/dev/fb4                 /dev/ptyv1               /dev/ttye4
/dev/full                /dev/ptyv2               /dev/ttye5
/dev/i2c-0               /dev/ptyv3               /dev/ttye6
/dev/i2c-1 /dev/ptyv4               /dev/ttye7
/dev/i2c-2               /dev/ptyv5               /dev/ttye8
/dev/kmem                /dev/ptyv6               /dev/ttye9
/dev/kmsg                /dev/ptyv7               /dev/ttyea
/dev/loop0               /dev/ptyv8               /dev/ttyeb
/dev/loop1               /dev/ptyv9               /dev/ttyec
/dev/loop2               /dev/ptyva               /dev/ttyed
/dev/loop3               /dev/ptyvb               /dev/ttyee
/dev/loop4               /dev/ptyvc               /dev/ttyef
/dev/loop5               /dev/ptyvd               /dev/ttymxc1
/dev/loop6               /dev/ptyve               /dev/ttymxc2
/dev/loop7               /dev/ptyvf               /dev/ttymxc3
/dev/mem                 /dev/ptyw0               /dev/ttyp0
/dev/mmcblk0             /dev/ptyw1               /dev/ttyp1
/dev/mmcblk0boot0        /dev/ptyw2               /dev/ttyp2
/dev/mmcblk0boot1        /dev/ptyw3               /dev/ttyp3
/dev/mmcblk0p1           /dev/ptyw4               /dev/ttyp4
/dev/mmcblk0p2           /dev/ptyw5               /dev/ttyp5
/dev/mmcblk0p3           /dev/ptyw6               /dev/ttyp6
/dev/mmcblk0p4           /dev/ptyw7               /dev/ttyp7
/dev/mtd0                /dev/ptyw8               /dev/ttyp8
/dev/mtd0ro              /dev/ptyw9               /dev/ttyp9
/dev/mtd1                /dev/ptywa               /dev/ttypa
/dev/mtd1ro              /dev/ptywb               /dev/ttypb
/dev/mtdblock0           /dev/ptywc               /dev/ttypc
/dev/mtdblock1           /dev/ptywd               /dev/ttypd
/dev/mxc_asrc            /dev/ptywe               /dev/ttype
/dev/mxc_hdmi            /dev/ptywf               /dev/ttypf
/dev/mxc_ipu             /dev/ptyx0               /dev/ttyq0
/dev/mxc_mem             /dev/ptyx1               /dev/ttyq1
/dev/mxc_vpu             /dev/ptyx2               /dev/ttyq2
/dev/mxs_viim            /dev/ptyx3               /dev/ttyq3
/dev/network_latency     /dev/ptyx4               /dev/ttyq4
/dev/network_throughput  /dev/ptyx5               /dev/ttyq5
/dev/null                /dev/ptyx6               /dev/ttyq6
/dev/psaux               /dev/ptyx7               /dev/ttyq7
/dev/ptmx                /dev/ptyx8               /dev/ttyq8
/dev/ptya0               /dev/ptyx9               /dev/ttyq9
/dev/ptya1               /dev/ptyxa               /dev/ttyqa
/dev/ptya2               /dev/ptyxb               /dev/ttyqb
/dev/ptya3               /dev/ptyxc               /dev/ttyqc
/dev/ptya4               /dev/ptyxd               /dev/ttyqd
/dev/ptya5               /dev/ptyxe               /dev/ttyqe
/dev/ptya6               /dev/ptyxf               /dev/ttyqf
/dev/ptya7               /dev/ptyy0               /dev/ttyr0
/dev/ptya8               /dev/ptyy1               /dev/ttyr1
/dev/ptya9               /dev/ptyy2               /dev/ttyr2
/dev/ptyaa               /dev/ptyy3               /dev/ttyr3
/dev/ptyab               /dev/ptyy4               /dev/ttyr4
/dev/ptyac               /dev/ptyy5               /dev/ttyr5
/dev/ptyad               /dev/ptyy6               /dev/ttyr6
/dev/ptyae               /dev/ptyy7               /dev/ttyr7
/dev/ptyaf               /dev/ptyy8               /dev/ttyr8
/dev/ptyb0               /dev/ptyy9               /dev/ttyr9
/dev/ptyb1               /dev/ptyya               /dev/ttyra
/dev/ptyb2               /dev/ptyyb               /dev/ttyrb
/dev/ptyb3               /dev/ptyyc               /dev/ttyrc
/dev/ptyb4               /dev/ptyyd               /dev/ttyrd
/dev/ptyb5               /dev/ptyye               /dev/ttyre
/dev/ptyb6               /dev/ptyyf               /dev/ttyrf
/dev/ptyb7               /dev/ptyz0               /dev/ttys0
/dev/ptyb8               /dev/ptyz1               /dev/ttys1
/dev/ptyb9               /dev/ptyz2               /dev/ttys2
/dev/ptyba               /dev/ptyz3               /dev/ttys3
/dev/ptybb               /dev/ptyz4               /dev/ttys4
/dev/ptybc               /dev/ptyz5               /dev/ttys5
/dev/ptybd               /dev/ptyz6               /dev/ttys6
/dev/ptybe               /dev/ptyz7               /dev/ttys7
/dev/ptybf               /dev/ptyz8               /dev/ttys8
/dev/ptyc0               /dev/ptyz9               /dev/ttys9
/dev/ptyc1               /dev/ptyza               /dev/ttysa
/dev/ptyc2               /dev/ptyzb               /dev/ttysb
/dev/ptyc3               /dev/ptyzc               /dev/ttysc
/dev/ptyc4               /dev/ptyzd               /dev/ttysd
/dev/ptyc5               /dev/ptyze               /dev/ttyse
/dev/ptyc6               /dev/ptyzf               /dev/ttysf
/dev/ptyc7               /dev/random              /dev/ttyt0
/dev/ptyc8               /dev/rfkill              /dev/ttyt1
/dev/ptyc9               /dev/rtc                 /dev/ttyt2
/dev/ptyca               /dev/rtc0                /dev/ttyt3
/dev/ptycb               /dev/tracebuf            /dev/ttyt4
/dev/ptycc               /dev/tty                 /dev/ttyt5
/dev/ptycd               /dev/tty0                /dev/ttyt6
/dev/ptyce               /dev/tty1                /dev/ttyt7
/dev/ptycf               /dev/tty10               /dev/ttyt8
/dev/ptyd0               /dev/tty11               /dev/ttyt9
/dev/ptyd1               /dev/tty12               /dev/ttyta
/dev/ptyd2               /dev/tty13               /dev/ttytb
/dev/ptyd3 /dev/tty14               /dev/ttytc
/dev/ptyd4               /dev/tty15               /dev/ttytd
/dev/ptyd5               /dev/tty16               /dev/ttyte
/dev/ptyd6               /dev/tty17               /dev/ttytf
/dev/ptyd7               /dev/tty18               /dev/ttyu0
/dev/ptyd8               /dev/tty19               /dev/ttyu1
/dev/ptyd9               /dev/tty2                /dev/ttyu2
/dev/ptyda               /dev/tty20               /dev/ttyu3
/dev/ptydb               /dev/tty21               /dev/ttyu4
/dev/ptydc               /dev/tty22               /dev/ttyu5
/dev/ptydd               /dev/tty23               /dev/ttyu6
/dev/ptyde               /dev/tty24               /dev/ttyu7
/dev/ptydf               /dev/tty25               /dev/ttyu8
/dev/ptye0               /dev/tty26               /dev/ttyu9
/dev/ptye1               /dev/tty27               /dev/ttyua
/dev/ptye2               /dev/tty28               /dev/ttyub
/dev/ptye3               /dev/tty29               /dev/ttyuc
/dev/ptye4               /dev/tty3                /dev/ttyud
/dev/ptye5               /dev/tty30               /dev/ttyue
/dev/ptye6               /dev/tty31               /dev/ttyuf
/dev/ptye7               /dev/tty32               /dev/ttyv0
/dev/ptye8               /dev/tty33               /dev/ttyv1
/dev/ptye9               /dev/tty34               /dev/ttyv2
/dev/ptyea               /dev/tty35               /dev/ttyv3
/dev/ptyeb               /dev/tty36               /dev/ttyv4
/dev/ptyec               /dev/tty37               /dev/ttyv5
/dev/ptyed               /dev/tty38               /dev/ttyv6
/dev/ptyee               /dev/tty39               /dev/ttyv7
/dev/ptyef               /dev/tty4                /dev/ttyv8
/dev/ptyp0               /dev/tty40               /dev/ttyv9
/dev/ptyp1               /dev/tty41               /dev/ttyva
/dev/ptyp2               /dev/tty42               /dev/ttyvb
/dev/ptyp3               /dev/tty43               /dev/ttyvc
/dev/ptyp4               /dev/tty44               /dev/ttyvd
/dev/ptyp5               /dev/tty45               /dev/ttyve
/dev/ptyp6               /dev/tty46               /dev/ttyvf
/dev/ptyp7               /dev/tty47               /dev/ttyw0
/dev/ptyp8               /dev/tty48               /dev/ttyw1
/dev/ptyp9               /dev/tty49               /dev/ttyw2
/dev/ptypa               /dev/tty5                /dev/ttyw3
/dev/ptypb               /dev/tty50               /dev/ttyw4
/dev/ptypc               /dev/tty51               /dev/ttyw5
/dev/ptypd               /dev/tty52               /dev/ttyw6
/dev/ptype               /dev/tty53               /dev/ttyw7
/dev/ptypf               /dev/tty54               /dev/ttyw8
/dev/ptyq0               /dev/tty55               /dev/ttyw9
/dev/ptyq1               /dev/tty56               /dev/ttywa
/dev/ptyq2               /dev/tty57               /dev/ttywb
/dev/ptyq3               /dev/tty58               /dev/ttywc
/dev/ptyq4               /dev/tty59               /dev/ttywd
/dev/ptyq5               /dev/tty6                /dev/ttywe
/dev/ptyq6               /dev/tty60               /dev/ttywf
/dev/ptyq7               /dev/tty61               /dev/ttyx0
/dev/ptyq8               /dev/tty62               /dev/ttyx1
/dev/ptyq9               /dev/tty63               /dev/ttyx2
/dev/ptyqa               /dev/tty7                /dev/ttyx3
/dev/ptyqb               /dev/tty8                /dev/ttyx4
/dev/ptyqc               /dev/tty9                /dev/ttyx5
/dev/ptyqd               /dev/ttya0               /dev/ttyx6
/dev/ptyqe               /dev/ttya1               /dev/ttyx7
/dev/ptyqf               /dev/ttya2               /dev/ttyx8
/dev/ptyr0               /dev/ttya3               /dev/ttyx9
/dev/ptyr1               /dev/ttya4               /dev/ttyxa
/dev/ptyr2               /dev/ttya5               /dev/ttyxb
/dev/ptyr3               /dev/ttya6               /dev/ttyxc
/dev/ptyr4               /dev/ttya7               /dev/ttyxd
/dev/ptyr5               /dev/ttya8               /dev/ttyxe
/dev/ptyr6               /dev/ttya9               /dev/ttyxf
/dev/ptyr7               /dev/ttyaa               /dev/ttyy0
/dev/ptyr8               /dev/ttyab               /dev/ttyy1
/dev/ptyr9               /dev/ttyac               /dev/ttyy2
/dev/ptyra               /dev/ttyad               /dev/ttyy3
/dev/ptyrb               /dev/ttyae               /dev/ttyy4
/dev/ptyrc               /dev/ttyaf               /dev/ttyy5
/dev/ptyrd               /dev/ttyb0               /dev/ttyy6
/dev/ptyre               /dev/ttyb1               /dev/ttyy7
/dev/ptyrf               /dev/ttyb2               /dev/ttyy8
/dev/ptys0               /dev/ttyb3               /dev/ttyy9
/dev/ptys1               /dev/ttyb4               /dev/ttyya
/dev/ptys2               /dev/ttyb5               /dev/ttyyb
/dev/ptys3               /dev/ttyb6               /dev/ttyyc
/dev/ptys4               /dev/ttyb7               /dev/ttyyd
/dev/ptys5               /dev/ttyb8               /dev/ttyye
/dev/ptys6               /dev/ttyb9               /dev/ttyyf
/dev/ptys7               /dev/ttyba               /dev/ttyz0
/dev/ptys8               /dev/ttybb               /dev/ttyz1
/dev/ptys9               /dev/ttybc               /dev/ttyz2
/dev/ptysa               /dev/ttybd               /dev/ttyz3
/dev/ptysb /dev/ttybe               /dev/ttyz4
/dev/ptysc               /dev/ttybf               /dev/ttyz5
/dev/ptysd               /dev/ttyc0               /dev/ttyz6
/dev/ptyse               /dev/ttyc1               /dev/ttyz7
/dev/ptysf               /dev/ttyc2               /dev/ttyz8
/dev/ptyt0               /dev/ttyc3               /dev/ttyz9
/dev/ptyt1               /dev/ttyc4               /dev/ttyza
/dev/ptyt2               /dev/ttyc5               /dev/ttyzb
/dev/ptyt3               /dev/ttyc6               /dev/ttyzc
/dev/ptyt4               /dev/ttyc7               /dev/ttyzd
/dev/ptyt5               /dev/ttyc8               /dev/ttyze
/dev/ptyt6               /dev/ttyc9               /dev/ttyzf
/dev/ptyt7               /dev/ttyca               /dev/ubi_ctrl
/dev/ptyt8               /dev/ttycb               /dev/urandom
/dev/ptyt9               /dev/ttycc               /dev/utp
/dev/ptyta               /dev/ttycd               /dev/vcs
/dev/ptytb               /dev/ttyce               /dev/vcs1
/dev/ptytc               /dev/ttycf               /dev/vcsa
/dev/ptytd               /dev/ttyd0               /dev/vcsa1
/dev/ptyte               /dev/ttyd1               /dev/vhci
/dev/ptytf               /dev/ttyd2               /dev/video16
/dev/ptyu0               /dev/ttyd3               /dev/video17
/dev/ptyu1               /dev/ttyd4               /dev/video18
/dev/ptyu2               /dev/ttyd5               /dev/video19
/dev/ptyu3               /dev/ttyd6               /dev/video20
/dev/ptyu4               /dev/ttyd7               /dev/watchdog
/dev/ptyu5               /dev/ttyd8               /dev/zero
/dev/ptyu6               /dev/ttyd9
/dev/disk:
by-id by-path  by-uuid
/dev/input:
mice uinput
/dev/pts:
/dev/shm:
/dev/snd:
timer
UTP: sending Success to kernel for command $ ls /dev/*.
utp_poll: pass returned.
UTP: received command '$ dd if=/dev/zero of=/dev/mmcblk0 bs=512 seek=1536 count=16'
UTP: executing "dd if=/dev/zero of=/dev/mmcblk0 bs=512 seek=1536 count=16"
16+0 records in
16+0 records out
8192 bytes (8.0KB) copied, 0.080471 seconds, 99.4KB/s
UTP: sending Success to kernel for command $ dd if=/dev/zero of=/dev/mmcblk0 bs=512 seek=1536 count=16.
UTP: received command '$ dd if=/dev/zero of=/dev/mmcblk0 bs=512 seek=8192 count=3'
UTP: executing "dd if=/dev/zero of=/dev/mmcblk0 bs=512 seek=8192 count=3"
3+0 records in
3+0 records out
1536 bytes (1.5KB) copied, 0.038287 seconds, 39.2KB/s
UTP: sending Success to kernel for command $ dd if=/dev/zero of=/dev/mmcblk0 bs=512 seek=8192 count=3.
UTP: received command '$ echo 0 > /sys/block/mmcblk0boot0/force_ro'
UTP: executing "echo 0 > /sys/block/mmcblk0boot0/force_ro"
UTP: sending Success to kernel for command $ echo 0 > /sys/block/mmcblk0boot0/force_ro.
UTP: received command 'send'
UTP: sending Success to kernel for command send.
UTP: received command '$ dd if=$FILE of=/dev/mmcblk0boot0 bs=512 seek=2 skip=2'
UTP: executing "dd if=$FILE of=/dev/mmcblk0boot0 bs=512 seek=2 skip=2"
844+1 records in
844+1 records out
432224 bytes (422.1KB) copied, 0.766364 seconds, 550.8KB/s
UTP: sending Success to kernel for command $ dd if=$FILE of=/dev/mmcblk0boot0 bs=512 seek=2 skip=2.
UTP: received command '$ echo 1 > /sys/block/mmcblk0boot0/force_ro'
UTP: executing "echo 1 > /sys/block/mmcblk0boot0/force_ro"
UTP: sending Success to kernel for command $ echo 1 > /sys/block/mmcblk0boot0/force_ro.
UTP: received command '$ echo 8 > /sys/devices/platform/sdhci-esdhc-imx.3/mmc_host/mmc0/mmc0:0001/boot_config'
UTP: executing "echo 8 > /sys/devices/platform/sdhci-esdhc-imx.3/mmc_host/mmc0/mmc0:0001/boot_config"
UTP: sending Success to kernel for command $ echo 8 > /sys/devices/platform/sdhci-esdhc-imx.3/mmc_host/mmc0/mmc0:0001/boot_config.
UTP: received command '$ dd if=$FILE of=/dev/mmcblk0 bs=20M seek=1 conv=fsync'
UTP: executing "dd if=$FILE of=/dev/mmcblk0 bs=20M seek=1 conv=fsync"
0+1 records in
0+1 records out
3379420 bytes (3.2MB) copied, 0.776460 seconds, 4.2MB/s
UTP: sending Success to kernel for command $ dd if=$FILE of=/dev/mmcblk0 bs=20M seek=1 conv=fsync.
UTP: received command '$ dd if=$FILE of=/dev/mmcblk0 bs=26M seek=1 conv=fsync'
UTP: executing "dd if=$FILE of=/dev/mmcblk0 bs=26M seek=1 conv=fsync"
0+1 records in
0+1 records out
3379420 bytes (3.2MB) copied, 1.313356 seconds, 2.5MB/s
UTP: sending Success to kernel for command $ dd if=$FILE of=/dev/mmcblk0 bs=26M seek=1 conv=fsync.
UTP: received command '$ tar xf $FILE '
UTP: executing "tar xf $FILE "
UTP: sending Success to kernel for command $ tar xf $FILE .
UTP: received command '$ sh eMMC-Partition.sh /dev/mmcblk0'
UTP: executing "sh eMMC-Partition.sh /dev/mmcblk0"
1+0 records in
1+0 records out
1024 bytes (1.0KB) copied, 0.003856 seconds,  mmcblk0: unknown partition table
  1. 259.3KB/s
Checking that no-one is using this disk right now ...
OK
Disk /dev/mmcblk0: 115456 cylinders, 4 heads, 16 sectors/track
sfdisk: ERROR: sector 0 does not have an msdos signature
/dev/mmcblk0: unrecognized partition table type
Old situation:
No partitions found
New situation:
Units = mebibytes of 1048576 bytes, blocks of 1024 bytes, counting from 0
Device Boot Start   End    MiB #blocks   Id  System
/dev/mmcblk0p1        50 399    350     358400 83  Linux
/dev/mmcblk0p2       450 799    350     358400 83  Linux
/dev/mmcblk0p3       850 1849   1000    1024000 83  Linux
/dev/mmcblk0p4      2000 3607   1608    1646592 83  Linux
Warning: no primary partition is marked bootable (active)
This does not matter for LILO, but the DOS MBR will not boot this disk.
Successfully wrote the new partition table
Re-reading the partition table ...
If you created or changed a DOS partition, /dev/foo7, say, then use dd(1)
to zero the first 512 bytes:  dd if=/dev/zero of=/dev/foo7 bs=512 count=1
(See fdisk(8).)
UTP: sending Success to kernel for command $ sh eMMC-Partition.sh /dev/mmcblk0.
UTP: received command '$ mkfs.ext3 -j /dev/mmcblk0p1'
UTP: executing "mkfs.ext3 -j /dev/mmcblk0p1"
mke2fs 1.41.4 (27-Jan-2009)
Filesystem label=
OS type: Linux
Block size=1024 (log=0)
Fragment size=1024 (log=0)
89760 inodes, 358400 blocks
17920 blocks (5.00%) reserved for the super user
First data block=1
Maximum filesystem blocks=67633152
44 block groups
8192 blocks per group, 8192 fragments per group
2040 inodes per group
Superblock backups stored on blocks:
                8193, 24577, 40961, 57345, 73729, 204801, 221185
Writing inode tables:  0/44 1/44 2/44 3/44 4/44 5/44 6/44 7/44 8/44 9/4410/4411/4412/4413/4414/4415/4416/4417/4418/4419/4420/4421/4422/4423/4424/4425/4426/4427/4428/4429/4430/4431/4432/4433/4434/4435/4436/4437/4438/4439/4440/4441/4442/4443/44done
Creating journal (8192 blocks): done
Writing superblocks and filesystem accounting information: done
This filesystem will be automatically checked every 37 mounts or
180 days, whichever comes first.  Use tune2fs -c or -i to override.
UTP: sending Success to kernel for command $ mkfs.ext3 -j /dev/mmcblk0p1.
UTP: received command '$ mkdir -p /mnt/mmcblk0p1'
UTP: executing "mkdir -p /mnt/mmcblk0p1"
UTP: sending Success to kernel for command $ mkdir -p /mnt/mmcblk0p1.
UTP: received command '$ mount -t ext3 /dev/mmcblk0p1 /mnt/mmcblk0p1'
UTP: executing "mount -t ext3 /dev/mmcblk0p1 /mnt/mmcblk0pEXT3-fs: barriers not enabled
1"
UTP: sending Success to kernel for command $ mount -t ext3 /dev/mmcblk0p1 /mnt/mmcblk0p1.
UTP: received command 'pipe tar -jxv -C /mnt/mmcblk0p1'
pid is 3406, UTP: executing "tar -jxv -C /mnt/mmcblk0p1"
UTP: sending Success to kernel for command pipe tar -jxv -C /mnt/mmcblk0p1.
./home/
./home/sshd/
./home/cardinit.sh
./home/ath6k/
./home/ath6k/AR6003/
./home/ath6k/AR6003/hw2.1.1/
./home/ath6k/AR6003/hw2.1.1/athtcmd_ram.bin
./home/ath6k/AR6003/hw2.1.1/data.patch.hw3_0.bin
./home/ath6k/AR6003/hw2.1.1/athwlan.bin
./home/ath6k/AR6003/hw2.1.1/otp.bin
./home/ath6k/AR6003/hw2.1.1/athwlan_router.bin
./home/ath6k/AR6003/hw2.1.1/athwlan_mobile.bin
./home/ath6k/AR6003/hw2.1.1/fakeBoardData_AR6003_v2_0.bin
./home/CV1/
./home/CV1/lumencert.pem
./home/CV1/CV1_factory_config.bin
./home/CV1/commn_resp.bin
./home/CV1/Lib/
./home/CV1/Lib/libWebMngr.so
./home/CV1/Lib/libDispHndlr_Lib.so
./home/CV1/Lib/libWebMngr_Lib.so
./home/CV1/Lib/libSecCntrlr_Lib.so
./home/CV1/Lib/libFwUtils_Lib.so
./home/CV1/Lib/libPriCntrlr_Lib.so
./home/CV1/Lib/libConfigUtils_Lib.so
./home/CV1/Lib/libIrHndlr_Lib.so
./home/CV1/Lib/libSysUtils_Lib.so
./home/CV1/Lib/libDataIntrptr_Lib.so
./home/CV1/Lib/libErrLogger_Lib.so
./home/CV1/Lib/libDataLogger_Lib.so
./home/CV1/Lib/libStartupDiagUtils_Lib.so
./home/CV1/Lib/libConnMon_Lib.so
./home/CV1/Lib/libCommMngr_Lib.so
./home/CV1/Lib/libCV1_Utils_Lib.so
./home/CV1/CV1_factory_user_info.bin
./home/CV1/web/
./home/CV1/web/htdocs/
./home/CV1/web/htdocs/misc/
./home/CV1/web/htdocs/misc/WebMngr_Interface.c
./home/CV1/web/htdocs/misc/WebMngr_Interface.h
./home/CV1/web/htdocs/static/
./home/CV1/web/htdocs/static/Web.config
./home/CV1/web/htdocs/static/datalog/
./home/CV1/web/htdocs/static/datalog/CV1DATA_0023aeaf8ee1_20140506_181501.csv
./home/CV1/web/htdocs/static/datalog/CV1DATA_0023aeaf8ee1_20140507_184545.csv
./home/CV1/web/htdocs/static/Read Me, Instructions, License, etc/
./home/CV1/web/htdocs/static/Read Me, Instructions, License, etc/License.html
./home/CV1/web/htdocs/static/Read Me, Instructions, License, etc/Premium Templates.url
./home/CV1/web/htdocs/static/Read Me, Instructions, License, etc/Remove Copyright.url
./home/CV1/web/htdocs/static/Read Me, Instructions, License, etc/Free Web Hosting.url
./home/CV1/web/htdocs/static/Read Me, Instructions, License, etc/files/
./home/CV1/web/htdocs/static/Read Me, Instructions, License, etc/files/zymic.gif
./home/CV1/web/htdocs/static/Read Me, Instructions, License, etc/files/background.gif
./home/CV1/web/htdocs/static/Read Me, Instructions, License, etc/files/style.css
./home/CV1/web/htdocs/static/Read Me, Instructions, License, etc/Instructions.html
./home/CV1/web/htdocs/static/Read Me, Instructions, License, etc/Template Customization.url
./home/CV1/web/htdocs/static/styles/
./home/CV1/web/htdocs/static/styles/protoplasm-0.2b2/
./home/CV1/web/htdocs/static/styles/protoplasm-0.2b2/upload/
./home/CV1/web/htdocs/static/styles/protoplasm-0.2b2/upload/.upload.pdoc.yaml
./home/CV1/web/htdocs/static/styles/protoplasm-0.2b2/upload/upload_src.js
./home/CV1/web/htdocs/static/styles/protoplasm-0.2b2/upload/change.png
./home/CV1/web/htdocs/static/styles/protoplasm-0.2b2/upload/remove.png
./home/CV1/web/htdocs/static/styles/protoplasm-0.2b2/upload/progress.gif
./home/CV1/web/htdocs/static/styles/protoplasm-0.2b2/upload/upload.css
./home/CV1/web/htdocs/static/styles/protoplasm-0.2b2/upload/warning.png
./home/CV1/web/htdocs/static/styles/protoplasm-0.2b2/upload/loading.gif
./home/CV1/web/htdocs/static/styles/protoplasm-0.2b2/upload/upload.js
./home/CV1/web/htdocs/static/styles/protoplasm-0.2b2/upload/ok.png
./home/CV1/web/htdocs/static/styles/protoplasm-0.2b2/upload/progress-red.gif
./home/CV1/web/htdocs/static/styles/protoplasm-0.2b2/datepicker/
./home/CV1/web/htdocs/static/styles/protoplasm-0.2b2/datepicker/left-range.png
./home/CV1/web/htdocs/static/styles/protoplasm-0.2b2/datepicker/.datepicker.pdoc.yaml
./home/CV1/web/htdocs/static/styles/protoplasm-0.2b2/datepicker/datepicker.css
./home/CV1/web/htdocs/static/styles/protoplasm-0.2b2/datepicker/datepicker_src.js
./home/CV1/web/htdocs/static/styles/protoplasm-0.2b2/datepicker/svn-commit.tmp
./home/CV1/web/htdocs/static/styles/protoplasm-0.2b2/datepicker/locales/
./home/CV1/web/htdocs/static/styles/protoplasm-0.2b2/datepicker/locales/.pt_BR.pdoc.yaml
./home/CV1/web/htdocs/static/styles/protoplasm-0.2b2/datepicker/locales/.lt_LT.pdoc.yaml
./home/CV1/web/htdocs/static/styles/protoplasm-0.2b2/datepicker/locales/.ru_RU.pdoc.yaml
./home/CV1/web/htdocs/static/styles/protoplasm-0.2b2/datepicker/locales/.nl_NL.pdoc.yaml
./home/CV1/web/htdocs/static/styles/protoplasm-0.2b2/datepicker/locales/nl_NL.js
./home/CV1/web/htdocs/static/styles/protoplasm-0.2b2/datepicker/locales/.cs_CZ.pdoc.yaml
./home/CV1/web/htdocs/static/styles/protoplasm-0.2b2/datepicker/locales/.it_IT.pdoc.yaml
./home/CV1/web/htdocs/static/styles/protoplasm-0.2b2/datepicker/locales/el_GR.js
./home/CV1/web/htdocs/static/styles/protoplasm-0.2b2/datepicker/locales/pl_PL.js
At this point the kernel splash image is loaded
/home/plat_LOCAL_i686-SDIO.sh: exit: line 141: Illegal number: -1
Platform script failed : loadAR6K
loadAR6000.sh: exit: line 344: Illegal number: -1
Image path: /home
Mac address:
sdiostack loading
insmod: can't insert '/home/ar6000.ko': unknown symbol in module, or unknown parameter
*** Failed to install AR6K Module
ifconfig: SIOCGIFFLAGS: No such device
error, Failure parsing line 87 of /etc/udhcpd.uap0.conf
error, Failure parsing line 88 of /etc/udhcpd.uap0.conf
error, SIOCGIFADDR failed, is the interface up and configured?: No such device
Line 3: invalid SSID ''
1 errors found in configuration file '/home/hostapd.conf'
0x0c0001, Invalid argument
0x0c0055, Error in settings station configurations
0x0c006c, Error in setting configuration
0x090063, Error in ConfigUtils_set_nw_conf()
0x0b0005, Error in kill():No such process
killall: dhclient: no process killed
killall: udhcpc: no process killed
0x09002c, Error in CentrlContrlr_init_modules
8e:fa:11:18:ee:c0:6c:75:cb:31:db:33:56:1f:8c:a3 root@SABRE_SDB
+--[RSA1 2048]----+
|           o |
| o +   + o    |
| o o = * o o .   |
|  = o = E   .    |
| . o = o       |
| . o .        |
8c:54:0f:a9:89:b1:13:09:f7:1f:31:bc:ae:6d:ad:f2 root@SABRE_SDB
+--[ DSA 1024]----+
| .+. .o=       |
| =oo...      |
| +.o+..       |
| ...S        |
| o .       |
| o o .      |
| +E.       |
b8:15:0e:66:bd:ac:23:8b:11:63:78:63:1d:eb:25:ac root@SABRE_SDB
+--[ RSA 2048]----+
| . + o        |
| . o = = o       |
|. B = o S        |
| + * o +         |
|  E o +          |
|   o o .         |
f9:d3:f9:ce:63:24:3c:22:4f:cb:fc:68:d5:d2:2b:c5 root@SABRE_SDB
+--[ECDSA 256]---+
| S  . +   |
| ..o.*.E  |
| *o+o* . |
| *o.o+  |
[ OK ]
#-1
Starting /usr/sbin/sshd: killall: udhcpd: no process killed
Could not load host key: /etc/openssh/ssh_host_rsa_key
Could not load host key: /etc/openssh/ssh_host_dsa_key
Could not load host key: /etc/openssh/ssh_host_ecdsa_key
Disabling protocol version 2. Could not load host key
sshd: no hostkeys available -- exiting.
[FAIL]
/etc/init.d/S50-openssh: Error 1 starting /usr/sbin/sshd... bailing.
(20014)Internal error: AH00058: Error retrieving pid file /var/run/httpd.pid
AH00059: Remove it before continuing if it is corrupted.
Any help will be appreciated.
8,140件の閲覧回数
jaymind
Hello Divya,
Thanks for providing the logs..
but you provide 2 boot-up the logs in one :smileysad: create confusion,
but anyhow I find some lines and issues which are may be possible reasons.
At the same time if you provide your boot arguments then it easy to conclude, so please provide your complete boot arguments.
Some lines in your the logs I write it below,
You just find it out in the logs which you provided me.
The main reason why it happen it due to HDMI on fb1 and you ON the fb2 (I don't know you use of it or not but if not use then OFF unnecessary)
My suggestions to you that if you not use HDMI and LDB-XGA on fb2 then OFF that.
1.
--> here problem it with your arguments and also HDMI.
just try it out some below arguments in U-boot and revert back with result. (don't save any argument, just see the result by real time changes in u-boot at the time of every restart.
If you not use HDMI and LDB-XGA then,
setenv bootargs ${bootargs} console=ttymxc1,115200 consoleblank=0 ip=none root=/dev/mmcblk0p1 rootwait video=mxcfb0:dev=adv739x,BT656-NTSC,if=BT656,fbpix=RGB565 video=mxcfb1:off video=mxcfb2:off
setenv bootargs ${bootargs} console=ttymxc1,115200 consoleblank=0 ip=none root=/dev/mmcblk0p1 rootwait video=mxcfb0:dev=adv739x,BT656-NTSC,if=BT656,fbpix=BGR32 video=mxcfb1:off video=mxcfb2:off
not sure about below :smileyconfused:
setenv bootargs ${bootargs} console=ttymxc1,115200 consoleblank=0 ip=none root=/dev/mmcblk0p1 rootwait video=mxcfb0:dev=adv739x,BT656-NTSC,if=BT656,fbpix=RGB565 video=mxcfb1:dev=hdmi,1280x720M@60,if=RGB24,bpp=32 video=mxcfb2:off
2.
--> here due to your arguments it goes to HDMI connection and try to search/read EDID,
so because of this at that time your display gone black and LCD screens disappears.
3.
I also found above line in the logs which would be incorrect, I think.
(You provide U-boot's arguments then after it will give some idea till its not clear)
enable_wait_mode=off is to let user has an options of turning off WAIT mode feature, such as when you suspect that some modules' performance are impacted by WAIT mode, then you can try to disable WAIT mode.
you can find more details about this here.... https://community.freescale.com/thread/307222
4. found 3 lines related to fb.0 which are in sequence as below
1.     mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver adv739x
2.     mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver adv739x
3.     mxc_sdc_fb mxc_sdc_fb.0: NO mxc display driver found!
I don't know why these display twice may be it due to you provide me 2 boot up logs.
If you provide me 2 boot ups logs then 1st is correct in 1st log , 2nd is also correct in 2nd log but what about 3rd ??:smileyplain:
Its a problem here, it not found fb.0 after 2nd, its also a one of reason.
5.     This point no more important anyway I put it here.
Found above lines in end of log(2nd boot up log) which are corrects but in start of log(1st boot log) I also found as below..
May these points helps you.
At the same time possible then please provide me U-boot's argument and try some arguments without saving in U-boot as per I described in point 1. :smileyhappy:
Inform me about your outputs and results.
Hope this will work.
Thanks and Regards
JAYMIN DABHI
8,140件の閲覧回数
divyardharan
Hi Jaymin,
Thank you for the findings.
The boot arguments we used was "setenv bootargs ${bootargs} console=ttymxc1,115200 ip=none root=/dev/mmcblk0p1 rootwait video=mxcfb0:dev=adv739x,BT656-NTSC,if=BT656,fbpix=RGB565 video=mxcfb1:dev=hdmi,1280x720M@60,if=RGB24 video=mxcfb2:dev=ldb,LDB-XGA,if=RGB24,bpp=24,fbpix=BGR32 ldb=dul0 video=mxcfb3:off consoleblank=0"
We tried with the above boot arguments but it didn't solve the issue.We are using lcd display.
when we tried the below arg, the kernel splash screen was loaded after a delay of 5 sec and stayed for 18 sec.But the application crashes. Kindly help..
"setenv bootargs ${bootargs} console=ttymxc1,115200 ip=none root=/dev/mmcblk0p1 rootwait video=mxcfb0:dev=ldb,LDB-XGA,if=RGB24,bpp=24,fbpix=BGR32 ldb=dul0 video=mxcfb1:dev=hdmi,1280x720M@60,if=RGB24 video=mxcfb2:off video=mxcfb3:off consoleblank=0".
Please find the log below:
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 7
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 18
U-Boot 2009.08 (Jan 08 2015 - 18:44:16)
U-Boot code: 27800720 -> 278A7200 BSS: -> 278E11CC
Temperature: 37 C, calibration data 0x5484c469
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
Boot Device: MMC
RAM Configuration:
Bank #0: 10000000 1 GB
*** Warning - bad CRC or MMC, using default environment
lcd_clear[LCD] Drawing the logo...
lcd_logo 0 w <NULL>
splash image not null <NULL>splash_config_screen_align 660606637 w 0,0
splash pos not null 660606637 w 0,0
splash_posi 0
0Display-bmp: 600 x 400 with 256 colors
lcd_clearing
ipu_clk = 260000000
bpp_to_pixfmt: 16
init channel = 9
bpp_to_pixfmt: 16
lcd_enabled
In: serial
Out: serial
Err: serial
FEC0 [PRIME]
*** Image Identifier flag is 1
file name=/
<2, 0, 204>
ext2fs read inode 2
<4, 0, 32>
<524, 128, 128>
<1034, 0, 8>
<1034, 8, 1>
iterate >.<
ext2fs read inode 2
<4, 0, 32>
<524, 128, 128>
<DIR> 1024 .
<1034, 12, 8>
<1034, 20, 2>
iterate >..<
ext2fs read inode 2
<4, 0, 32>
<524, 128, 128>
<DIR> 1024 ..
<1034, 24, 8>
<1034, 32, 10>
<4, 0, 32>
<526, 256, 128>
<1034, 44, 8>
<1034, 52, 4>
iterate >home<
<4, 352, 32>
<180230, 0, 128>
<DIR> 1024 home
<1034, 56, 8>
<1034, 64, 3>
iterate >mnt<
ext2fs read inode 2041
ext2fs read 1 group descriptor (blkno 2 blkoff 32)
<4, 32, 32>
ext2fs read inode blkno 8454 blkoff 0
<16908, 0, 128>
<DIR> 1024 mnt
<1034, 68, 8>
<1034, 76, 3>
iterate >etc<
ext2fs read inode 59161
ext2fs read 29 group descriptor (blkno 2 blkoff 928)
<5, 416, 32>
ext2fs read inode blkno 237571 blkoff 0
<475142, 0, 128>
<DIR> 1024 etc
<1034, 80, 8>
<1034, 88, 3>
iterate >lib<
ext2fs read inode 65281
ext2fs read 32 group descriptor (blkno 3 blkoff 0)
<6, 0, 32>
ext2fs read inode blkno 262147 blkoff 0
<524294, 0, 128>
<DIR> 3072 lib
<1034, 92, 8>
<1034, 100, 4>
iterate >root<
ext2fs read inode 10201
<4, 160, 32>
ext2fs read inode blkno 41222 blkoff 0
<82444, 0, 128>
<DIR> 1024 root
<1034, 104, 8>
<1034, 112, 3>
iterate >dev<
ext2fs read inode 69361
ext2fs read 34 group descriptor (blkno 3 blkoff 64)
<6, 64, 32>
ext2fs read inode blkno 278531 blkoff 0
<557062, 0, 128>
<DIR> 16384 dev
<1034, 116, 8>
<1034, 124, 4>
iterate >sbin<
ext2fs read inode 63241
ext2fs read 31 group descriptor (blkno 2 blkoff 992)
<5, 480, 32>
ext2fs read inode blkno 253955 blkoff 0
<507910, 0, 128>
<DIR> 1024 sbin
<1034, 128, 8>
<1034, 136, 3>
iterate >usr<
<5, 288, 32>
<410124, 0, 128>
<DIR> 1024 usr
<1034, 140, 8>
<1034, 148, 4>
iterate >proc<
<4, 96, 32>
<49676, 0, 128>
<DIR> 1024 proc
<1034, 152, 8>
<1034, 160, 3>
iterate >opt<
ext2fs read inode 12241
ext2fs read 6 group descriptor (blkno 2 blkoff 192)
<4, 192, 32>
ext2fs read inode blkno 49155 blkoff 0
<98310, 0, 128>
<DIR> 1024 opt
<1034, 164, 8>
<1034, 172, 7>
iterate >linuxrc<
ext2fs read inode 6122
<4, 96, 32>
ext2fs read inode blkno 24838 blkoff 128
<49676, 128, 128>
<SYM> 11 linuxrc
<1034, 180, 8>
<1034, 188, 3>
iterate >run<
<4, 128, 32>
<65542, 0, 128>
<DIR> 1024 run
<1034, 192, 8>
<1034, 200, 6>
iterate >config<
<4, 224, 32>
<115212, 0, 128>
<DIR> 1024 config
<1034, 208, 8>
<1034, 216, 3>
iterate >var<
ext2fs read inode 16321
ext2fs read 8 group descriptor (blkno 2 blkoff 256)
<4, 256, 32>
ext2fs read inode blkno 65539 blkoff 0
<131078, 0, 128>
<DIR> 1024 var
<1034, 220, 8>
<1034, 228, 3>
iterate >tmp<
ext2fs read inode 28561
ext2fs read 14 group descriptor (blkno 2 blkoff 448)
<4, 448, 32>
ext2fs read inode blkno 114691 blkoff 0
<229382, 0, 128>
<DIR> 1024 tmp
<1034, 232, 8>
<1034, 240, 3>
iterate >bin<
ext2fs read inode 20401
ext2fs read 10 group descriptor (blkno 2 blkoff 320)
<4, 320, 32>
ext2fs read inode blkno 81923 blkoff 0
<163846, 0, 128>
<DIR> 3072 bin
<1034, 244, 8>
<1034, 252, 3>
iterate >jre<
ext2fs read inode 18361
ext2fs read 9 group descriptor (blkno 2 blkoff 288)
<4, 288, 32>
ext2fs read inode blkno 73990 blkoff 0
<147980, 0, 128>
<DIR> 1024 jre
<1034, 256, 8>
<1034, 264, 3>
iterate >sys<
ext2fs read inode 4081
ext2fs read 2 group descriptor (blkno 2 blkoff 64)
<4, 64, 32>
ext2fs read inode blkno 16387 blkoff 0
<32774, 0, 128>
<DIR> 1024 sys
<1034, 268, 8>
<1034, 276, 5>
iterate >media<
ext2fs read inode 34681
ext2fs read 17 group descriptor (blkno 2 blkoff 544)
<5, 32, 32>
ext2fs read inode blkno 139267 blkoff 0
<278534, 0, 128>
<DIR> 1024 media
  Data Size: 3245188 Bytes = 3.1 MB
  kernel data at 0x10800040, len = 0x00318484 (3245188)
## No init Ramdisk
OK
  kernel loaded at 0x10008000, end = 0x10320484
Starting kernel ****bootm.c******...
[ OK ]
[Fail]
Configuring network interfaces: done
Starting ntpd: [OK]
48
Error count=0****Startup Error logged:19700101, 5:30:20.000, 30
****insmod: can't insert '/home/CV1/Driver/gadgetfs.ko': unknown symbol in module, or unknown parameter
mount: mounting gadgetfs on /dev/gadget failed: No such device
Module Arguments...
Image path: /home
Mac address:
sdiostack loading
Image path: /home
Mac address:
sdiostack loading
Starting /usr/sbin/sshd: ifconfig: SIOCGIFFLAGS: No such device
[ OK ]
ifconfig: SIOCSIFADDR: No such device
ioctl(SIOCGIFINDEX): No such device
ar6000 driver initialization failed.
rmdir[ctrl_interface]: No such file or directory
# httpd not running, trying to start
Could not read interface wlan0 flags: No such device
wlan0: Failed to initialize driver interface
?? don't recognize /dev/gadget bulk device
/dev/gadget/(null) ep1 configured
serial="st3f4m1r8wr1mzay3d06budw4frd9dvyxa6yykjc6vyj70ppqdfln0rofs8cx2m"
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 8
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 10
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 16
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 4
Thanking you,
Divya
8,140件の閲覧回数
alejandrolozan1
Hi Divya,
Were you able to solve this?
Which BSP version are you using? Can you share the steps to reproduce the same in one of our boards?
Alejandro
8,140件の閲覧回数
divyardharan
Hi Alejandro,
We are using version 3.0 for building ltib. The issue is not yet resolved.
divya
8,140件の閲覧回数
jaymind
Hello Divya,
try to use below arguments and let me know your result and observation whatever it is.
setenv bootargs ${bootargs} console=ttymxc1,115200 consoleblank=0 ip=none root=/dev/mmcblk0p1 rootwait video=mxcfb0:dev=adv739x,BT656-NTSC,if=BT656,fbpix=RGB565 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off
NOTE : do it for test purpose,
Also please tell me in details that actually what things are doing at what timing ? (at proper time, what is displaying ?)
Jaymin D
8,140件の閲覧回数
divyardharan
Hi Jaimin,
Any updates on how to load the kernel splash screen once the u-boot splash screen is loaded.
Thanks ,
Divya
8,140件の閲覧回数
divyardharan
Hi Jaymin,
We tried with the above bootargs but nothing is displaying in lcd.Not showing boot loader and kernel splash screen.We tried to optimize the kernel by disabling the drivers.But the delay in loading kernel splash screen reduced to 16sec only from 18sec.
Also kindly help to optimize the kernel boot time of ltib.
Divya
