Why is there a memory leak when using gstreamer on the imx8mm platform?
2,350 次查看
Liubin2
hi:
       Why does the application I wrote with gstreamer run on the imx8mm platform will have a memory leak, the application is as follows:
After about 100 hours, the memory of the development board is exhausted. The memory consumption is shown in the attached screenshot(PlayCameraH265 is my application), What is the reason?2020-12-01.png2020-12-02.png
2,346 次查看
weidong_sun
Hi Liubin2,
   gstreamer是比较容易造成内存泄漏的。
   这里是同行写的注意事项,您可以参考一下。
https://blog.csdn.net/yingmuliuchuan/article/details/79347773?utm_source=blogxgwz8
Have a nice day!
B.R,
weidong
2,319 次查看
Liubin2
hi weidong_sun:
        关于gstreamer内存泄漏的,问题已经查明,是GPU模块的驱动程序有点问题导致的泄漏,打了个补丁更新一下内核就好了。谢谢!
2,326 次查看
Liubin2
您好!
        NXP有gstreamer的一些插件手册吗?我看英伟达都有DeepStream插件手册!
