Where can I obtain the source code mxc_mcc_tty_test.c?
4,390 次查看
jingyangxie
Can anyone can send me source code(mxc_mcc_tty_test.c) of the demo mxc_mcc_tty_test.out ?
标签 (2)
11 回复数
3,936 次查看
qinghuazhu
you can get mxc_mcc_tty_test.c from
tmp/work/imx6ulevk-poky-linux-gnueabi/imx-test/1_5.4.1-r0/imx-test-5.4.1/test/mxc_mcc_tty_test
bitbake imx-test
3,936 次查看
aravinthkumarja
Senior Contributor II
Hi jingyang,
mcc tty driver on latest kernel location :
     => drivers/char/imx_amp/imx_mcc_tty.c
Aravinth
3,936 次查看
jingyangxie
Hi,aravinthkumar
   what's the version of the lastest kernel location you said ? in the BSP 4.1.15,I can't find the imx_mcc_tty.c in the directory drivers/char/imx_amp
3,936 次查看
jingyangxie
Hi,aravinthkumar
   in BSP 4.1.15, the file is list as follow:
Can you tell me which version you use ?
3,936 次查看
aravinthkumarja
Hi jingyang,
kernel version : 3.14.28
Aravinth
3,934 次查看
aravinthkumarja
Attached files are there in new kernel.
Aravinth
3,929 次查看
Hi jingyang
please look at sect.53.3 Source Codes attached Linux Manual
imx6sx mcc tty driver : drivers/char/imx_mcc/imx_mcc_tty.c
3,929 次查看
jingyangxie
Hi,igorpadykov
    what does 53.3 mean? The BSP I use is 4.1.15,and I can't find the file imx_mcc_tty.c in the directory drivers/char/imx_mcc
3,929 次查看
jingyangxie
Hi,igorpadykov
    what's the linux manual you refered to above ,Please give more details,thanks!
3,929 次查看
jingyangxie
没有人做过imx6SX的多核通信吗?M4发给A9的数据,A9核的应用程序如何获取这些数据?
3,929 次查看
jingyangxie
MARK一下
