Using tvp5151 with mxc capture interface
1,953件の閲覧回数
Ananth
Hi All,
interfacing tvp5151 decoder with IMX53 have following issues
1. Currently, I dont have readily available linux driver for tvp5151, instead I can able to locate a driver for tvp5150 driver.
The tvp5150 driver (v4l2_i2c_subdev_init)registering into the platform is done different way compared to IMX provided ov5642 (v4l2_int_device_register) sensor driver.
I did try to detect tvp5151 using tvp5150 code and I got success in detection step of the chip
Log from board
tvp5150 1-005c: chip found @ 0xb8 (imx-i2c)
Based on this, I googled and found a similar compatible decoder
adv7180.c
available in
drivers/media/video/mxc/capture/adv7180.c written for mxc capture framework.
http://forums.freescale.com/t5/i-MX-Microprocessors/iMX515-and-TVP5150-video-decodrer-problem/td-p/6...
My Questions:
1. How to use tvp5150 driver in IMX53 loco board ? is this possible ?
2. I google for this problem and found some similar results. Did any git version of kernel have this support integrated ? If yes, Will you please share the link ...
Thanks and regards,
Ananth.
タグ(1)
0 返答(返信)
