Ltib fails on Bluez
Ltib fails on Bluez
815 次查看
kiranmayineelak
I am a newbie to Linux as well as for LTIB. I have built the LTIB in Ubuntu - 11.04 successfully with the default configurations after a tedious procedure.
Now, I want to configure my ltib with bluez but the build is failing due to the following error:
config.status: executing depfiles commands
+ --with-alsa=/home/infy/new_imx287_ltib/ltib/rootfs/usr/lib/libasound.so --with-usb=/home/infy/new_imx287_ltib/ltib/rootfs/usr/lib/libusb.so --without-openobex --without-dbus --without-fuse --with-bluez=/home/infy/new_imx287_ltib/ltib/rootfs/usr/lib
/home/infy/new_imx287_ltib/ltib/tmp/rpm-tmp.77552: 1: --with-alsa=/home/infy/new_imx287_ltib/ltib/rootfs/usr/lib/libasound.so: not found
error: Bad exit status from /home/infy/new_imx287_ltib/ltib/tmp/rpm-tmp.77552 (%build)
RPM build errors:
Build time for bluez-utils: 12 seconds
Failed building bluez-utils
f_buildrpms() returned an error, exiting
traceback:
 main:560
Started: Sat Nov 19 15:37:35 2011
Ended:   Sat Nov 19 15:50:23 2011
Elapsed: 768 seconds
These packages failed to build:
bluez-utils
Build Failed
Exiting on error or interrupt
Please help me to overcome this issue.
Kiran
标记 (1)
0 回复数
