Using Windows PC How to Copy Images to SDCARD for IMX8M Mini EVK
3,951 次查看
sreedhar_appala
I am working with IMX8M Mini EVK and yocto project build details:
Build Configuration:
BB_VERSION = "1.38.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "ubuntu-16.04"
TARGET_SYS = "aarch64-poky-linux"
MACHINE = "imx8mmevk"
DISTRO = "fsl-imx-xwayland"
DISTRO_VERSION = "4.14-sumo"
TUNE_FEATURES = "aarch64"
TARGET_FPU = ""
I need to copy the build images to sdcard using windows machine now. earlier I was copying using the Linux PC.
Could you please suggest any tool or mechanism to copy the build images to sdcard using windows PC.
Thank you, Sreedhar
3,847 次查看
joanxie
you can download uuu from the link as below:
Releases · NXPmicro/mfgtools · GitHub
uuu.exe is for windows
6 回复数
3,847 次查看
joanxie
you can use uuu tool to download the image to the sd card, the command like:
"uuu -b sd_all imx-boot-imx8mmevk-sd.bin-flash_evk fsl-image-validation-imx-imx8mmevk.sdcard"
3,847 次查看
sreedhar_appala
Hi Joan Xie,
Thank you for the quick response.
You mean: using the below cmd
we can flash the images into the sdcard using "windows PC"
So far I was doing using Linux PC only.
Can you please confirm again: we can flash the images into SDCARD using the uuu tool using windows PC.
Thank you, Sreedhar
3,847 次查看
joanxie
"Can you please confirm again: we can flash the images into SDCARD using the uuu tool using windows PC."
>is it your typo? do you want to confirm linux, right?
uuu has two versions, one for linux and another one for windows, you can download uuu for linux
3,847 次查看
sreedhar_appala
Hi Joan Xie,
Thank you, I want to do using windows, As mentioned I will try with windows version utility.
Thank you, Sreedhar
3,848 次查看
joanxie
3,847 次查看
sreedhar_appala
Thank you Joan Xie
