Using Windows PC How to Copy Images to SDCARD for IMX8M Mini EVK
5,085件の閲覧回数
sreedhar_appala
I am working with IMX8M Mini EVK and yocto project build details:
Build Configuration:
BB_VERSION = "1.38.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "ubuntu-16.04"
TARGET_SYS = "aarch64-poky-linux"
MACHINE = "imx8mmevk"
DISTRO = "fsl-imx-xwayland"
DISTRO_VERSION = "4.14-sumo"
TUNE_FEATURES = "aarch64"
TARGET_FPU = ""
I need to copy the build images to sdcard using windows machine now. earlier I was copying using the Linux PC.
Could you please suggest any tool or mechanism to copy the build images to sdcard using windows PC.
Thank you, Sreedhar
ラベル(3)
4,981件の閲覧回数
joanxie
you can download uuu from the link as below:
Releases · NXPmicro/mfgtools · GitHub
uuu.exe is for windows
6 返答(返信)
4,981件の閲覧回数
joanxie
you can use uuu tool to download the image to the sd card, the command like:
"uuu -b sd_all imx-boot-imx8mmevk-sd.bin-flash_evk fsl-image-validation-imx-imx8mmevk.sdcard"
4,981件の閲覧回数
sreedhar_appala
Hi Joan Xie,
Thank you for the quick response.
You mean: using the below cmd
we can flash the images into the sdcard using "windows PC"
So far I was doing using Linux PC only.
Can you please confirm again: we can flash the images into SDCARD using the uuu tool using windows PC.
Thank you, Sreedhar
4,981件の閲覧回数
joanxie
"Can you please confirm again: we can flash the images into SDCARD using the uuu tool using windows PC."
>is it your typo? do you want to confirm linux, right?
uuu has two versions, one for linux and another one for windows, you can download uuu for linux
4,981件の閲覧回数
sreedhar_appala
Hi Joan Xie,
Thank you, I want to do using windows, As mentioned I will try with windows version utility.
Thank you, Sreedhar
4,982件の閲覧回数
joanxie
4,981件の閲覧回数
sreedhar_appala
Thank you Joan Xie
