Unit Test Source Code in Yocto Project
4,612 次查看
david_ochs1
I'm using an i.MX8M Mini EVK with Linux, and I would like to see the source code for the Unit Tests described in the Linux Reference manual. Is that somewhere in the Yocto directory? If not, where can I find it?
Dave
4,222 次查看
ankitr_patel
Senior Contributor II
Hi David Ochs,
Yes, it will be there after bitbake and yes it will be under <yocto_dir>/tmp/work/<imx_version_build>/imx-test/<imx-test-version>/git/test/
Here under test directory there will be directory for respective unit test inside where you can find the source code.
Ankit Patel
4,222 次查看
david_ochs1
Hi Ankit,
I'm sorry, but I don't see that directory. Is it inside the tmp/work directory somewhere after I bitbake? Also, I don't see anywhere in the reference manual that points me to the source code. I found a link in it to the codeaurora site, but I can't find the source code there either.
Dave
4,223 次查看
ankitr_patel
Hi David Ochs,
Ankit Patel
4,221 次查看
ankitr_patel
Hi David Ochs,
You can find the source code for unit test in yocto in:
<Yocto_BuildDir>/imx-test-"version"/test/
Also in the linux reference manual it is mention where you can find the source code for the particular application.
Ankit Patel
