Unable to set display frame rate for video elementary stream
3,169件の閲覧回数
teranishi_kenji
Hi all,
I am trying a displaying of H.264 elementary stream on i.MX6Q Sabre board using Freescale Yocto Project BSP code (imx-3.14.52-1.1.0_ga).
But, I can not set the display frame rate.
I try folloing command.
  gst-launch-1.0 filesrc location=input.es ! video/x-h264,framerate=15/1,alignment=au,stream-format=avc ! vpudec ! overlaysink
However, this is displayed in 30fps. I would like to display in 15fps.
Do you know how to resolve?
Kenji
8 返答(返信)
2,941件の閲覧回数
jimmychan
please try to add this
! vpudec framedrop=false framerate-nu=15 framerate-de=1 !
2,941件の閲覧回数
teranishi_kenji
Dear jimmychan,
Thank you so much for your advice.
But, I recieved folloing message.
  no property "framerate-nu" in element "vpudec0"
I am using version 4.0.8 for "vpudec". This version don't have this property.
Could you give me some advice about this?
Kenji
2,941件の閲覧回数
jimmychan
the player can adjust the media clock rate for such use case. For example, you can use gplay-1.0 to play the video file, then select "[c]Setting play rate" to set the play rate to 0.5X, then for 30fps video file, it can be played in 15fps.
The gplay code can be found from the released "gst1.0-fsl-plugins-x.x.x.tar.gz".
2,941件の閲覧回数
teranishi_kenji
Dear jimmychan,
I can use "gplay-1.0". But I don't know how to use "[c]Setting play rate".
Could you show sample command?
Kenji
2,941件の閲覧回数
jimmychan
When you using gplay, you will see there is an option "[c]Setting play rate".
For your reference : gplay-1.0 kernel panic imx6q
2,941件の閲覧回数
teranishi_kenji
Dear jimmychan,
I found "[c]Setting play rate".
And, the following command was successful.
  gplay-1.0 input_h264_es.bin
I tried a following command, but not work.
  gplay-1.0 -c=0.5 input_h264_es.bin
Kenji
2,941件の閲覧回数
jimmychan
when you read the source code of gplay.c, there is no "-c" option on command line to set the play rate. You only can use 'c' option after you run the 'gplay'.
2,941件の閲覧回数
teranishi_kenji
Dear jimmychan,
I succeeded. Thank you so much.
However, I would like to know the solution of using "filesrc" or "vpudec".
Please tell me about this if you know.
Kenji
