Strange IfxElementProperty contents when creating plug-in element
749 次查看
YongJunChang
Hi all,
I'm trying to create a buffered-mode plug-in element. I got successfully load the theme in Express as well as the target device with correct preview. As the same as IfxPhotopicker example, the element's size is 144x144. I set the plugin element's property in Express as
In all layouts > Extent Hint > X = 144,
In all layouts > Extent Hint > Y = 144,
In all layouts > Resource > Event Handler = "rearview://"
Everythig looked fine before I checked the pProperty in createElement_rearview(). It says
pProperty has a structure that says mode=0, requiredBufferHeight=0, requiredBufferWidth=144, translucency=144. For some reasons after all, when changeElementMode is called, the pContext has width=1, height=144.
Can anyone have a clue of this problem?
Thanks in advance,
Yong
标记 (2)
0 回复数
