Recommended connection when not used LICELL
1,529 次查看
ko-hey
Senior Contributor II
Hi all
Let me confirm about recommended connection for LICELL in PF3000.
1.
I found the following document which describe about recommended connection for PF0100.
http://cache.freescale.com/files/analog/doc/app_note/AN4717.pdf?fasp=1&WT_TYPE=Application%20Notes&W...
Can the recommended connection also apply for PF3000 ?
2.
According to the Table 1 of AN4717, NXP recommended user to connect "Bypass with 0.1 μF" when not used LICELL.
In my understanding this mean "Bypass with 0.1 μF to ground".
Is it correct ?
Ko-hey
标签 (3)
标记 (3)
1,400 次查看
joanxie
yes, you're right, just bypass through 0.1 μF to ground
1,401 次查看
joanxie
1,400 次查看
ko-hey
Thanks!
Ko-hey
