Hi all
Let me confirm about recommended connection for LICELL in PF3000.
1.
I found the following document which describe about recommended connection for PF0100.
Can the recommended connection also apply for PF3000 ?
2.
According to the Table 1 of AN4717, NXP recommended user to connect "Bypass with 0.1 μF" when not used LICELL.
In my understanding this mean "Bypass with 0.1 μF to ground".
Is it correct ?
Ko-hey
Solved! Go to Solution.
yes, you're right, just bypass through 0.1 μF to ground
Thanks!
Ko-hey
