QSPI for IMX8M Plus
QSPI for IMX8M Plus
1,847 次查看
waynechung2
Could we use the QSPI for IMX8M Plus M7 ?
If it work, where can i find the driver ?
Thanks.
Wayne.
1,842 次查看
AldoG
If you mean that if it is possible that the binary file runs at QSPI/XIP, then yes it is possible, please refer to the getting started with MCUXpresso SDK for EVK-MIMX8MP.
If you mean that M7 has access to the QSPI, then no, usually this peripheral is assigned to the Cortex-A, so we do not provide a driver for cortex-M.
Aldo.
1,843 次查看
AldoG
Aldo.
