Q: IPU + image scrolling [Linux]
1,230 次查看
maxx
Hello!
I need to implement image scrolling under Linux on a imx535.
According to the " i.MX53 Multimedia Applications Processor Reference Manual", 45.3.1.6.2 Update Of The Display Buffer:
"Automatic display of a changing image (animation) or moving image (scrolling) This
is implemented by reading frames (from a full plane buffer) with incremental offset"
Seems that is exactly what I need. I tried to research IPU driver located in $BUILD/linux/drivers/mxc/ipu*, but seems that current implementation of IPU driver and therefore user-space library does not support scrolling feature at all.
Does anybody dig into this field yet? I also tried to search IMX community - no results so far:(
Thanks for any info!
标签 (2)
838 次查看
jimmychan
Unfortunately, there is no example for the moving image (scrolling). For details, please read the i.MX53RM Chapter 45.5.2.7.1 Scrolling support and 45.5.2.10 CPMEM - Channel Parameter Memory.  You may need set the values in cpmem and implement it by yourself.
