I have encountered errors configuring MCIMX7D7DVK10SC using Pins 2.0
Pin assignment issues:
AH01 - VSS-088 (Other VSS pins are X'ed out, should this be X'ed out as well?)
W27 - should be DRAM_DATA16
Y28 - should be DRAM_DATA19
AA26 - should be DRAM_DATA20
AB26 - should be DRAM_DATA21
AB27 - should be DRAM_DATA22
AB28 - should be DRAM_DATA23
Power group issue:
Power group ADC2_VDDA_1P8 doesn't exist for the 12x12 package
I have attached a .mex file with these pins selected. The values shown do not match the datasheet.
What is the proper channel to request a fix for these issues?
Thank you.
Original Attachment has been moved to: MCIMX7D7DVK10SC---errors.mex.zip
