Hi community.
Our customer has question below.
Please tell me about pin processing when not using USB analog interface.
IMX6DQ6SDLHDG does not describe the processing of F9 (VDDUSB_CAP), V5 (USB_OTG_PWR), T4 (USB_OTG_ID).
Could you tell me how to handle the terminals?
As USB is not used, is itcorrect with GND short?
Thank you.
Best Regards.
T.Takahashi
解決済! 解決策の投稿を見る。
Hello
1.
VDDUSB_CAP requires capacitor if the internal regulator is used, otherwise -may be left float.
2.
USB_OTG_PWR, USB_OTG_ID may be left float, assuming default GPIO mode of corresponding pins.
Yuri
Hello
1.
2.
Yuri
