Not getting update in yocto image after changing dtsi file
1,498件の閲覧回数
Prial_03
i am using i.mx6ul SOM and i am baking yocto image, in that i made changes in DTSI file i rebuild image with following commands but image is not being updated.
$ bitbake virtual/kernel -c devshell and amde changes in dts file and did
$ make dtbs / make file.dtsi & exit terminal
$bitbake virtual/kernel -f -c compile
$bitbake virtual/kernel -f -c deploy
$ bitbake <image>
ラベル(5)
4 返答(返信)
1,465件の閲覧回数
Manuel_Salas
Hello @Prial_03
Your device tree updated correctly? (generating the dtb file)
Aso you can try remove the tmp folder and run again the bitbake <image> command.
Salas.
1,455件の閲覧回数
Prial_03
Hello @Manuel_Salas
I already tried this but when i modify dtsi file after this again changes are not reflecting in image
1,440件の閲覧回数
Manuel_Salas
Could you please provide to me your steps to update the device tree?
I would like to try to modify it and recompile with your method.
Salas.
1,413件の閲覧回数
Prial_03
Hello @Manuel_Salas ,
Here are the steps:
$ bitbake virtual/kernel -c devshell and made changes in dts file and did
$ bitbake <image>
