NXP IMX8 Plus "Creating the BSP and Yocto build environment" compile issue
2,335件の閲覧回数
middepogudas
Hi NXP,
Thanks for this form. I am trying to download and build the BSP source code for "I.MX 8M Plus" target.
1. I am referring  this to download and build BSP code "https://docs.nxp.com/bundle/AN13712/page/topics/module_and_board.html"
2. Please find host PC info:
$ uname -a
Linux das-ThinkPad-L14-Gen-1 6.14.0-24-generic #24-Ubuntu SMP PREEMPT_DYNAMIC Sun Jun 15 11:18:07 UTC 2025 x86_64 x86_64 x86_64 GNU/Linux
3. Build and env settings:
das@das-ThinkPad-L14-Gen-1:~$ DISTRO=fsl-imx-xwayland MACHINE=imx8mp-lpddr4-evk source imx-setup-release.sh -b build
das@das-ThinkPad-L14-Gen-1:~$ bitbake imx-image-full -c populate_sdk
das@das-ThinkPad-L14-Gen-1:~/Desktop/das/NXP/Project/nxpevb/imx-yocto-bsp/build$ bitbake imx-image-full -c populate_sdk
das@das-ThinkPad-L14-Gen-1:~/Desktop/das/NXP/Project/nxpevb/imx-yocto-bsp/build$ sudo apt install gawk wget git diffstat unzip texinfo gcc build-essential chrpath socat cpio python3 python3-pip python3-pexpect xz-utils debianutils iputils-ping python3-git python3-jinja2 python3-subunit zstd liblz4-tool file locales libacl1
das@das-ThinkPad-L14-Gen-1:~/Desktop/das/NXP/Project/nxpevb/imx-yocto-bsp/build$ sudo apt install gawk wget git diffstat unzip texinfo gcc build-essential chrpath socat cpio python3 python3-pip python3-pexpect xz-utils debianutils iputils-ping python3-git python3-jinja2 libegl1-mesa libsdl1.2-dev python3-subunit mesa-common-dev zstd liblz4-tool file locales -y
das@das-ThinkPad-L14-Gen-1:~sudo apt install gawk wget git diffstat unzip texinfo gcc build-essential chrpath socat cpio python3 python3-pip python3-pexpect xz-utils debianutils iputils-ping python3-git python3-jinja2 python3-subunit zstd liblz4-tool file locales libacl1
das@das-ThinkPad-L14-Gen-1:~/Desktop/das/NXP/Project/nxpevb/imx-yocto-bsp/build$ sudo apparmor_parser -R /etc/apparmor.d/unprivileged_userns
das@das-ThinkPad-L14-Gen-1:~/Desktop/das/NXP/Project/nxpevb/imx-yocto-bsp/build$ sudo locale-gen en_US.UTF-8
4. build error:
WARNING: Host distribution "ubuntu-25.04" has not been validated with this version of the build system; you may possibly experience unexpected failures. It is recommended that you use a tested distribution.
Loading cache: 100% |####################################################################################################################################################| Time: 0:00:02
Loaded 5449 entries from dependency cache.
NOTE: Resolving any missing task queue dependencies
WARNING: preferred version 17.0.6 of llvm-native not available (for item llvm-native)
WARNING: versions of llvm-native available: 17.0.3
Build Configuration:
BB_VERSION = "2.6.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "ubuntu-25.04"
TARGET_SYS = "aarch64-poky-linux"
MACHINE = "imx8mp-lpddr4-evk"
DISTRO = "fsl-imx-xwayland"
DISTRO_VERSION = "6.6-nanbield"
TUNE_FEATURES = "aarch64 armv8a crc crypto"
TARGET_FPU = ""
meta
meta-poky = "HEAD:046b70083f3bc9e25f547e8026400032f5c563d9"
meta-oe
meta-multimedia
meta-python = "HEAD:1750c66ae8e4268c472c0b2b94748a59d6ef866d"
meta-freescale = "HEAD:0a73d1bdd7713a6189482e463c98043c9939a2a2"
meta-freescale-3rdparty = "HEAD:7725256e3859b62f1ff201db7f2cf7026c17656d"
meta-freescale-distro = "HEAD:4f1f101ebab5eb054bfbed10b247fc0547b30793"
meta-imx-bsp
meta-imx-sdk
meta-imx-ml
meta-imx-v2x = "HEAD:773c0049c3b35af8f5b5bdf8da78a6236a4fc184"
meta-nxp-demo-experience = "HEAD:db34fa86ad5f3c0d9c0a6c68f5f20240c04f2bfb"
meta-arm
meta-arm-toolchain = "HEAD:4d22f982bce8dff6f8c4d11845c47a4d39f961c6"
meta-chromium = "HEAD:dc31889c0899971def535dc1c040edf18bc16691"
meta-clang = "HEAD:9b08495e6bcef524789aefb6a7cc80fdfd2ff409"
meta-gnome
meta-networking
meta-filesystems = "HEAD:1750c66ae8e4268c472c0b2b94748a59d6ef866d"
meta-qt6 = "HEAD:fd054cf5fc1b50d50cd606384ab338c6d9206437"
meta-parsec
meta-tpm = "HEAD:070a1e82cc59424d230a23c0b2a104b01fbaa2ad"
meta-virtualization = "HEAD:9e92984ff47b3ca2106b1d27a93af061b28d1e8a"
WARNING: Your host glibc version (2.41) is newer than that in uninative (2.38). Disabling uninative so that sstate is not corrupted.
Initialising tasks: 100% |###############################################################################################################################################| Time: 0:00:11
Sstate summary: Wanted 7712 Local 0 Mirrors 0 Missed 7712 Current 142 (0% match, 1% complete)
NOTE: Executing Tasks
ERROR: pseudo-native-1.9.0+git-r0 do_compile: ExecutionError('/home/das/Desktop/das/NXP/Project/nxpevb/imx-yocto-bsp/build/tmp/work/x86_64-linux/pseudo-native/1.9.0+git/temp/run.do_compile.28961', 1, None, None)
ERROR: Logfile of failure stored in: /home/das/Desktop/das/NXP/Project/nxpevb/imx-yocto-bsp/build/tmp/work/x86_64-linux/pseudo-native/1.9.0+git/temp/log.do_compile.28961
Log data follows:
| DEBUG: Executing shell function do_compile
| NOTE: Building/installing only 64-bit libpseudo.so for pseudo-native.
| NOTE: If you need to run 32-bit executables, ensure that NO32LIBS is set to 0.
| SQLite header for version 3043001 found in /home/das/Desktop/das/NXP/Project/nxpevb/imx-yocto-bsp/build/tmp/work/x86_64-linux/pseudo-native/1.9.0+git/recipe-sysroot-native/usr.
| Enabling in-memory database by default.
| NOTE: make -j 4 RPATH=-Wl,--rpath=XORIGIN/../../../sqlite3-native/usr/lib/
| make: Nothing to be done for 'all'.
| WARNING: exit code 1 from a shell command.
ERROR: Task (virtual:native:/home/das/Desktop/das/NXP/Project/nxpevb/imx-yocto-bsp/sources/poky/meta/recipes-devtools/pseudo/pseudo_git.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 359 tasks of which 358 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 4 WARNING messages.
Summary: There was 1 ERROR message, returning a non-zero exit code.
Can you please get back how to resolve this BSP and Yacto build issue;
Das
16 返答(返信)
1,842件の閲覧回数
middepogudas
NXP ,
Can you help on this :
dasmiddepogu@dasmiddepogu-ThinkPad-L13-Yoga-Gen-3:~/Desktop/das/project/imx-yocto-bsp/build$ bitbake core-image-minimal
Loading cache: 100% |#######################################################################################################################################################################| Time: 0:00:01
NATIVELSBSTRING = "universal"
TARGET_FPU = ""
meta
meta-oe
meta-multimedia
meta-imx-bsp
meta-imx-sdk
meta-imx-ml
meta-arm
meta-gnome
meta-networking
meta-parsec
Initialising tasks: 100% |##################################################################################################################################################################| Time: 0:00:02
Sstate summary: Wanted 1103 Local 2 Mirrors 0 Missed 1101 Current 1686 (0% match, 60% complete)
ERROR: openssl-3.1.4-r0 do_compile: oe_runmake failed
ERROR: openssl-3.1.4-r0 do_compile: ExecutionError('/home/dasmiddepogu/Desktop/das/project/imx-yocto-bsp/build/tmp/work/armv8a-poky-linux/openssl/3.1.4/temp/run.do_compile.14161', 1, None, None)
ERROR: Logfile of failure stored in: /home/dasmiddepogu/Desktop/das/project/imx-yocto-bsp/build/tmp/work/armv8a-poky-linux/openssl/3.1.4/temp/log.do_compile.14161
Log data follows:
| NOTE: make -j 12
ERROR: Task (/home/dasmiddepogu/Desktop/das/project/imx-yocto-bsp/sources/poky/meta/recipes-connectivity/openssl/openssl_3.1.4.bb:do_compile) failed with exit code '1'
Waiting for 11 running tasks to finish:
0: qemu-native-8.1.2-r0 do_compile - 45s (pid 14162)
1: linux-imx-6.6.3+git-r0 do_fetch - 45s (pid 14185) | <=> |
2: rust-llvm-native-1.70.0-r0 do_compile - 45s (pid 14195) 0% | |
3: icu-73-2-r0 do_compile - 44s (pid 14317)
4: perl-5.38.0-r0 do_compile - 43s (pid 14323)
5: util-linux-2.39.2-r0 do_package - 43s (pid 14318)
6: libical-native-3.0.16-r0 do_compile - 43s (pid 14321) 36% |################################################### |
7: bash-5.2.15-r0 do_configure - 43s (pid 1432^C
Das
1,770件の閲覧回数
Harvey021
The causes for OE_RUNMAKE error can be various. Insufficient DDR can be one.
Make sure that your build Host is set well as required, except for the hardware resources as mentioned.
Harvey
1,842件の閲覧回数
middepogudas
NXP,
can you help below error:
dasmiddepogu@dasmiddepogu-ThinkPad-L13-Yoga-Gen-3:~/Desktop/das/project/imx-yocto-bsp/build$ bitbake -c cleansstate openssl
dasmiddepogu@dasmiddepogu-ThinkPad-L13-Yoga-Gen-3:~/Desktop/das/project/imx-yocto-bsp/build$ bitbake openssl
Loading cache: 100% |#######################################################################################################################################################################| Time: 0:00:00
TARGET_FPU = ""
meta
meta-oe
meta-multimedia
meta-imx-bsp
meta-imx-sdk
meta-imx-ml
meta-arm
meta-gnome
meta-networking
meta-parsec
Initialising tasks: 100% |##################################################################################################################################################################| Time: 0:00:00
Sstate summary: Wanted 100 Local 0 Mirrors 0 Missed 100 Current 616 (0% match, 86% complete)
NOTE: No reply from server in 30s (for command ping at 05:13:49.520202)
Timeout while waiting for a reply from the bitbake server (60s at 05:14:19.561139)
i am holding host pc with  1TB memory , 8GB RAM, 10 CPU core..
ThinkPad-L13-Yoga-Gen-3 5.15.0-139-generic #149~20.04.1-Ubuntu SMP Wed Apr 16 08:29:56 UTC 2025 x86_64 x86_64 x86_64 GNU/Linux
Das
2,079件の閲覧回数
middepogudas
Hi NXP,
Most of the times i am facing issue of bitbake server connectivity while build these images(fsl-image-machine-
test, imx-image-multimedia, imx-image-full) but its ok to build for these images(imx-image-core,core-image-base).
While build these images (fsl-image-machine-test, imx-image-multimedia, imx-image-full) its build for for Vulkan and OpenCV lib, which is unable to build by bitbake server. Do you have any other document how to optimize to build  bitback for Vulkan and OpenCV?
I am holding 4 CPU cores Inter processor.
Can you please  help on this issue?
Please find the logs as below:
******************Logs***********************
NOTE: Your conf/bblayers.conf has been automatically updated.
TARGET_FPU = ""
meta
meta-oe
meta-multimedia
meta-imx-bsp
meta-imx-sdk
meta-imx-ml
meta-arm
meta-gnome
meta-networking
meta-parsec
Initialising tasks: 100% |##################################################################################################################################################################| Time: 0:00:08
Sstate summary: Wanted 1071 Local 2 Mirrors 0 Missed 1069 Current 5652 (0% match, 84% complete)
NOTE: No reply from server in 30s (for command ping at 22:27:39.389536)
Timeout while waiting for a reply from the bitbake server (60s at 22:28:09.428551)
middepogudas@middepogudas-ThinkPad-L14-Gen-1:~/Desktop/das/project/imx-yocto-bsp/build$ bitbake imx-image-multimedia
NOTE: Reconnecting to bitbake server...
NOTE: No reply from server in 30s (for command setFeatures at 22:28:45.138306)
NOTE: Retrying server connection (#1)... (22:29:15.167756)
Das
2,018件の閲覧回数
Harvey021
Your build system doesn't seem to meet the requirements for this build. Here are some configuration recommendations from Yocto.
 Yocto Project Quick Build — The Yocto Project ® 5.2.2 documentation
  • At least 8 Gbytes of RAM, though a modern build host with as much RAM and as many CPU cores as possible is strongly recommended to maximize build performance.
Other recommendations: if you have 4 CPU cores, at least 16GB of RAM is needed. A 1:4 ratio is as follows. You can also refer to https://docs.yoctoproject.org/dev-manual/speeding-up-build.html
If you're building a full image, at least 250GB of disk space required.
I just test the same on my host: 22.04.1-Ubuntu
Loading cache: 100% |##################################################################################################################| Time: 0:00:01
TARGET_FPU = ""
meta
meta-oe
meta-multimedia
meta-imx-bsp
meta-imx-sdk
meta-imx-ml
meta-arm
meta-gnome
meta-networking
meta-parsec
Initialising tasks: 100% |#############################################################################################################| Time: 0:00:06
Sstate summary: Wanted 3349 Local 0 Mirrors 0 Missed 3349 Current 4781 (0% match, 58% complete)
NOTE: Tasks Summary: Attempted 17993 tasks of which 13736 didn't need to be rerun and all succeeded.
Summary: There were 2 WARNING messages.
Harvey
1,965件の閲覧回数
middepogudas
Hello NXP.
Thanks for your support. I am holding 4 CPU, 1TB HDD, 8GB RAM. As per your recommendation i can give a try to increase my RAM to 16 GB+ .
I am trying to build for "MACHINE = "imx8mp-lpddr4-evk""
As per my observation build summery as below:
Able to build :
bitbake imx-image-core
Unable to build:
bitbake fsl-image-machine-test
So from above configure i observe that when ever try to build the "opencv" and "vulkan" i am getting bitbake server connectivity issue. We have any build option where we can comment  or skip the building("opencv" and "vulkan") and proceed further?
Can you please point-out build script name and where to comment to skip the build for opencv" and "vulkan" ?
Das
タグ(1)
1,957件の閲覧回数
Harvey021
These applications are the main components of the full/multimedia image. Instead of skipping the building of these applications, it is better to directly build the imx-image-core. As mentioned, to upgrade your build host.
Harvey
1,952件の閲覧回数
middepogudas
Hello NXP,
While build the below configuration (bitbake fsl-image-machine-test, bitbake imx-image-multimedia, bitbake imx-image-full), is it possible to comment inside build script file for "opencv" or "vulkan" these components for skip the while build? pleas share the file name and where i need to comment the code to skip the build components?
My end goal is to go for full build (bitbake imx-image-full). With above experiment, we can isolate the issue which components causing.
Thank you.
Das
1,924件の閲覧回数
Harvey021
It is possible. You can comment the packages from image recipe or get help from Yocto forum. However, this will be another issue. Please raise a new ticket for further assistance if you need. and as said, if such applications/packages are skipped, then to build full/multimedia will be similar to build other smaller image.
Harvey
2,212件の閲覧回数
middepogudas
Hi NXP,
Thank for come back on this.Still I am facing some build issue... "NOTE: Reconnecting to bitbake server..." .. Please find logs below
Please find the steps which i follow from this link(https://docs.nxp.com/bundle/AN13712/page/topics/create_the_yocto_build_environment.html)
please suggest how to proceed further.
**********************************build logs***************************************
dasmiddepogu@dasmiddepogu-ThinkPad-L14-Gen-1:~/Desktop/das/project/imax8mpluseek/imx-yocto-bsp/build$
dasmiddepogu@dasmiddepogu-ThinkPad-L14-Gen-1:~/Desktop/das/project/imax8mpluseek/imx-yocto-bsp/build$ bitbake imx-image-full -c populate_sdk
NOTE: Retrying server connection (#1)... (Traceback (most recent call last):
File "/home/dasmiddepogu/Desktop/das/project/imax8mpluseek/imx-yocto-bsp/sources/poky/bitbake/lib/bb/main.py", line 487, in setup_bitbake
server_connection = bb.server.process.connectProcessServer(sockname, featureset)
File "/home/dasmiddepogu/Desktop/das/project/imax8mpluseek/imx-yocto-bsp/sources/poky/bitbake/lib/bb/server/process.py", line 686, in connectProcessServer
sock.connect(os.path.basename(sockname))
BlockingIOError: [Errno 11] Resource temporarily unavailable
, 08:00:49.857906)
NOTE: Retrying server connection (#2)... (Traceback (most recent call last):
, 08:00:49.858338)
NOTE: Retrying server connection (#3)... (Traceback (most recent call last):
, 08:00:49.858697)
NOTE: Retrying server connection (#4)... (Traceback (most recent call last):
, 08:00:49.859044)
NOTE: Retrying server connection (#5)... (Traceback (most recent call last):
, 08:00:54.865054)
NOTE: Retrying server connection (#6)... (Traceback (most recent call last):
, 08:00:59.870058)
NOTE: Retrying server connection (#7)... (Traceback (most recent call last):
, 08:01:04.877760)
NOTE: Retrying server connection (#8)... (Traceback (most recent call last):
, 08:01:09.884445)
ERROR: Unable to connect to bitbake server, or start one (server startup failures would be in bitbake-cookerdaemon.log).
Das
2,185件の閲覧回数
Harvey021
The error tells that unable to connect bitbake server, which may be caused by a hung bitbake daemon or leftover socket files. You can try to kill that and clean some lock files under build directory and restart host, then run "bitbake imx-image-full -c populate_sdk" again.
Harvey
2,181件の閲覧回数
middepogudas
NXP,
Thanks for come back, Please find build logs pasted below. Still getting bitback server connectivity issue. I restarted my pc several times,. I did not find any bitbake process. Can you pleas share info how to proceed further.
***********************Logs********
Loading cache: 100% |########################################################################################################################################################################| Time: 0:00:01
TARGET_FPU = ""
meta
meta-oe
meta-multimedia
meta-imx-bsp
meta-imx-sdk
meta-imx-ml
meta-arm
meta-gnome
meta-networking
meta-parsec
Initialising tasks: 100% |###################################################################################################################################################################| Time: 0:00:19
Sstate summary: Wanted 7008 Local 0 Mirrors 0 Missed 7008 Current 1122 (0% match, 13% complete)
WARNING: llvm-project-source-17.0.6-17.0.6-r0 do_fetch: Failed to fetch URL git://github.com/llvm/llvm-project;protocol=https;branch=release/17.x, attempting MIRRORS if available
NOTE: No reply from server in 30s (for command ping at 01:48:27.402426)
Timeout while waiting for a reply from the bitbake server (60s at 01:48:57.437217)
dasmiddepogu@dasmiddepogu-ThinkPad-L14-Gen-1:~/Desktop/das/project/imax8mpluseek/imx-yocto-bsp/build$ ps
PID TTY TIME CMD
2919 pts/0 00:00:00 bash
213920 pts/0 00:00:00 ps
dasmiddepogu@dasmiddepogu-ThinkPad-L14-Gen-1:~/Desktop/das/project/imax8mpluseek/imx-yocto-bsp/build...
Das Middepogu
2,178件の閲覧回数
Harvey021
Please check your network issue for fetching failure, are there security or proxy arising the issue? also check your Host configure as reference to first reply. can also try to start a new build.
Harvey
2,173件の閲覧回数
middepogudas
Hi NXP,
Thanks for your support. Do you have steps or methods to check "security or proxy arising"?
Please help us to share? or guide us.
Das
2,171件の閲覧回数
Harvey021
Hi @middepogudas
If your host is in your company network, please check your company network administrator.
Harvey
2,308件の閲覧回数
Harvey021
Hi @middepogudas
To build the BSP(6.6.3)source code for i.MX8MP, please follow up the Yocto User Guide download from Docs
Please refer to the section Host Setup> for Ubuntu version (Recommend 20.04/22.04) and the section <3.2 Host packages>.
Harvey
%3CLINGO-SUB%20id%3D%22lingo-sub-2141271%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ENXP%20IMX8%20Plus%E3%80%8CBSP%E3%81%A8Yocto%E3%83%93%E3%83%AB%E3%83%89%E7%92%B0%E5%A2%83%E3%81%AE%E4%BD%9C%E6%88%90%E3%80%8D%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2141271%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81NXP%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%80%8CI.MX%208M%20Plus%E3%80%8D%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AE%20BSP%20%E3%82%BD%E3%83%BC%E3%82%B9%20%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E1.BSP%20%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%80%8C%20%3CA%20href%3D%22https%3A%2F%2Fdocs.nxp.com%2Fbundle%2FAN13712%2Fpage%2Ftopics%2Fmodule_and_board.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fdocs.nxp.com%2Fbundle%2FAN13712%2Fpage%2Ftopics%2Fmodule_and_board.html%E3%80%8D%3C%2FA%3E%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E2.%20%E3%83%9B%E3%82%B9%E3%83%88PC%E3%81%AE%E6%83%85%E5%A0%B1%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%24%20uname%20-a%3CBR%20%2F%3E%20Linux%20das-ThinkPad-L14-Gen-1%206.14.0-24-generic%20%2324-Ubuntu%20SMP%20PREEMPT_DYNAMIC%20%E6%97%A5%E6%9B%9C%E6%97%A5%206%E6%9C%8815%E6%97%A5%2011%3A18%3A07%20UTC%202025%20x86_64%20x86_64%20x86_64%20GNU%2FLinux%3C%2FP%3E%3CP%3E3.%20%E3%83%93%E3%83%AB%E3%83%89%E3%81%A8%E7%92%B0%E5%A2%83%E8%A8%AD%E5%AE%9A%3A%3C%2FP%3E%3CP%3Edas%40das-ThinkPad-L14-Gen-1%3A~%24%20DISTRO%3Dfsl-imx-xwayland%20MACHINE%3Dimx8mp-lpddr4-evk%20%E3%82%BD%E3%83%BC%E3%82%B9%20imx-setup-release.sh%20-b%20%E3%83%93%E3%83%AB%E3%83%89%3CBR%20%2F%3Edas%40das-ThinkPad-L14-Gen-1%3A~%24%20bitbake%20imx-image-full%20-c%20populate_sdk%3CBR%20%2F%3E%20das%40das-ThinkPad-L14-Gen-1%3A~%2FDesktop%2Fdas%2FNXP%2FProject%2Fnxpevb%2Fimx-yocto-bsp%2Fbuild%24%20bitbake%20imx-image-full%20-c%20populate_sdk%3CBR%20%2F%3E%20das%40das-ThinkPad-L14-Gen-1%3A%3CBR%20%2F%3E%20das%40das-ThinkPad-L14-Gen-1%3A~%2FDesktop%2Fdas%2FNXP%2FProject%2Fnxpevb%2Fimx-yocto-bsp%2Fbuild%24%20sudo%20apt%20install%20gawk%20wget%20git%20diffstat%20unzip%20texinfo%20gcc%20build-essential%20chrpath%20socat%20cpio%20python3%20python3-pip%20python3-pexpect%20xz-utils%20debianutils%20iputils-ping%20python3-git%20python3-jinja2%20python3-subunit%20zstd%20liblz4-tool%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%83%AD%E3%82%B1%E3%83%BC%E3%83%AB%20libacl1%3CBR%20%2F%3E%20das%40das-ThinkPad-L14-Gen-1%3A~%2FDesktop%2Fdas%2FNXP%2FProject%2Fnxpevb%2Fimx-yocto-bsp%2Fbuild%24%20sudo%20apt%20install%20gawk%20wget%20git%20diffstat%20unzip%20texinfo%20gcc%20build-essential%20chrpath%20socat%20cpio%20python3%20python3-pip%20python3-pexpect%20xz-utils%20debianutils%20iputils-ping%20python3-git%20python3-jinja2%20libegl1-mesa%20libsdl1.2-devpython3-subunit%20mesa-common-dev%20zstd%20liblz4-tool%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%83%AD%E3%82%B1%E3%83%BC%E3%83%AB%20-y%3CBR%20%2F%3E%20das%40das-ThinkPad-L14-Gen-1%3A~sudo%20apt%20install%20gawk%20wget%20git%20diffstat%20unzip%20texinfo%20gcc%20build-essential%20chrpath%20socat%20cpio%20python3%20python3-pip%20python3-pexpect%20xz-utils%20debianutils%20iputils-ping%20python3-git%20python3-jinja2%20python3-subunit%20zstd%20liblz4-tool%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%83%AD%E3%82%B1%E3%83%BC%E3%83%AB%20libacl1%3CBR%20%2F%3E%20das%40das-ThinkPad-L14-Gen-1%3A~%2FDesktop%2Fdas%2FNXP%2FProject%2Fnxpevb%2Fimx-yocto-bsp%2Fbuild%24%20sudo%20apparmor_parser%20-R%20%2Fetc%2Fapparmor.d%2Funprivileged_userns%3CBR%20%2F%3Edas%40das-ThinkPad-L14-Gen-1%3A~%2FDesktop%2Fdas%2FNXP%2FProject%2Fnxpevb%2Fimx-yocto-bsp%2Fbuild%24%20sudo%20locale-gen%20en_US.UTF-8%3C%2FP%3E%3CP%3Edas%40das-ThinkPad-L14-Gen-1%3A~%2FDesktop%2Fdas%2FNXP%2FProject%2Fnxpevb%2Fimx-yocto-bsp%2Fbuild%24%20%3CSTRONG%3Ebitbake%20imx-image-full%20-c%20populate_sdk%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E4.%3CSTRONG%3E%E3%83%93%E3%83%AB%E3%83%89%E3%82%A8%E3%83%A9%E3%83%BC%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Edas%40das-ThinkPad-L14-Gen-1%3A~%2FDesktop%2Fdas%2FNXP%2FProject%2Fnxpevb%2Fimx-yocto-bsp%2Fbuild%24%20bitbake%20imx-image-full%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%3A%20%E3%83%9B%E3%82%B9%E3%83%88%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%8Cubuntu-25.04%E3%80%8D%E3%81%93%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E3%81%AF%E6%A4%9C%E8%A8%BC%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E4%BA%88%E6%9C%9F%E3%81%97%E3%81%AA%E3%81%84%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%86%E3%82%B9%E3%83%88%E6%B8%88%E3%81%BF%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%3A%20100%25%20%7C%23%20...%7C%20%E6%99%82%E9%96%93%3A%200%3A00%3A02%3CBR%20%2F%3E%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8B%E3%82%89%205449%20%E5%80%8B%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E6%B3%A8%3A%20%E4%B8%8D%E8%B6%B3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%3A%20llvm-native%20%E3%81%AE%E6%8E%A8%E5%A5%A8%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%2017.0.6%20%E3%81%AF%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%20(%E3%82%A2%E3%82%A4%E3%83%86%E3%83%A0%20llvm-native)%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%3A%20%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%20llvm-native%20%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%2017.0.3%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%AB%E3%83%89%E6%A7%8B%E6%88%90%3A%3CBR%20%2F%3E%20BB_VERSION%20%3D%20%222.6.0%22%3CBR%20%2F%3EBUILD_SYS%20%3D%20%22x86_64-linux%22%3CBR%20%2F%3E%E3%83%8D%E3%82%A4%E3%83%86%E3%82%A3%E3%83%96LSBSTRING%20%3D%20%22ubuntu-25.04%22%3CBR%20%2F%3ETARGET_SYS%20%3D%20%22aarch64-poky-linux%22%3CBR%20%2F%3E%E3%83%9E%E3%82%B7%E3%83%B3%20%3D%20%22imx8mp-lpddr4-evk%22%3CBR%20%2F%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%3D%20%22fsl-imx-xwayland%22%3CBR%20%2F%3E%20DISTRO_VERSION%20%3D%20%226.6-nanbield%22%3CBR%20%2F%3ETUNE_FEATURES%20%3D%20%22aarch64%20armv8a%20crc%20%E6%9A%97%E5%8F%B7%22%3CBR%20%2F%3E%20TARGET_FPU%20%3D%20%22%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%3CBR%20%2F%3E%20meta-poky%20%3D%20%22HEAD%3A046b70083f3bc9e25f547e8026400032f5c563d9%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BFoe%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%91%E3%82%A4%E3%82%BD%E3%83%B3%20%3D%20%22HEAD%3A1750c66ae8e4268c472c0b2b94748a59d6ef866d%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%20%3D%20%22HEAD%3A0a73d1bdd7713a6189482e463c98043c9939a2a2%22%3CBR%20%2F%3E%20meta-freescale-3rdparty%20%3D%20%22HEAD%3A7725256e3859b62f1ff201db7f2cf7026c17656d%22%3CBR%20%2F%3E%20meta-freescale-distro%20%3D%20%22HEAD%3A4f1f101ebab5eb054bfbed10b247fc0547b30793%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF-imx-bsp%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BFimx-sdk%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BFimx-ml%3CBR%20%2F%3E%20meta-imx-v2x%20%3D%20%22HEAD%3A773c0049c3b35af8f5b5bdf8da78a6236a4fc184%22%3CBR%20%2F%3E%20meta-nxp-demo-experience%20%3D%20%22HEAD%3Adb34fa86ad5f3c0d9c0a6c68f5f20240c04f2bfb%26amp%3BBR%3CBR%20%2F%3E%20%2F%26gt%3Bmeta-Arm%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%82%A2%E3%83%BC%E3%83%A0%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%20%3D%20%22HEAD%3A4d22f982bce8dff6f8c4d11845c47a4d39f961c6%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%82%AF%E3%83%AD%E3%83%9F%E3%82%A6%E3%83%A0%20%3D%20%22HEAD%3Adc31889c0899971def535dc1c040edf18bc16691%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF-clang%20%3D%20%22HEAD%3A9b08495e6bcef524789aefb6a7cc80fdfd2ff409%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%8E%E3%83%BC%E3%83%A0%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AD%E3%83%B3%E3%82%B0%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%3D%20%22HEAD%3A1750c66ae8e4268c472c0b2b94748a59d6ef866d%22%3CBR%20%2F%3E%20meta-qt6%20%3D%20%22HEAD%3Afd054cf5fc1b50d50cd606384ab338c6d9206437%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%91%E3%83%BC%E3%82%BB%E3%82%AF%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BFtpm%20%3D%20%22HEAD%3A070a1e82cc59424d230a23c0b2a104b01fbaa2ad%22%3CBR%20%2F%3E%20meta-%E4%BB%AE%E6%83%B3%E5%8C%96%20%3D%20%22HEAD%3A9e92984ff47b3ca2106b1d27a93af061b28d1e8a%22%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%3A%20%E3%83%9B%E3%82%B9%E3%83%88%E3%81%AE%20glibc%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%20(2.41)%20%E3%81%AF%E3%80%81uninative%20%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%20(2.38)%20%E3%82%88%E3%82%8A%E3%82%82%E6%96%B0%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%80%82sstate%20%E3%81%8C%E7%A0%B4%E6%90%8D%E3%81%97%E3%81%AA%E3%81%84%20SO%20uninative%20%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%3A%20100%25%20%7C%23%20...%7C%20%E6%99%82%E9%96%93%3A%200%3A00%3A11%3CBR%20%2F%3E%20Sstate%20%E3%81%AE%E6%A6%82%E8%A6%81%3A%20%E5%8B%9F%E9%9B%86%207712%20%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%200%20%E3%83%9F%E3%83%A9%E3%83%BC%200%20%E6%AC%A0%E8%90%BD%207712%20%E7%8F%BE%E5%9C%A8%20142%20(%E4%B8%80%E8%87%B4%E7%8E%87%200%25%E3%80%81%E5%AE%8C%E4%BA%86%E7%8E%87%201%25)%3CBR%20%2F%3E%E6%B3%A8%E8%A8%98%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E5%AE%9F%E8%A1%8C%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20pseudo-native-1.9.0%2Bgit-r0%20do_compile%3A%20ExecutionError('%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fdas%2FDesktop%2Fdas%2FNXP%2FProject%2Fnxpevb%2Fimx-Yocto-bsp%2Fbuild%2Ftmp%2Fwork%2Fx86_64-Linux%2Fpseudo-native%2F1.9.0%2Bgit%2Ftemp%2Frun.do_compile.28961'%2C%201%2C%20None%2C%20None)%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E5%A4%B1%E6%95%97%E3%81%AE%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E6%AC%A1%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%20%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fdas%2FDesktop%2Fdas%2FNXP%2FProject%2Fnxpevb%2Fimx-Yocto-bsp%2Fbuild%2Ftmp%2Fwork%2Fx86_64-Linux%2Fpseudo-native%2F1.9.0%2Bgit%2Ftemp%2Flog.do_compile.28961%3CBR%20%2F%3E%E3%83%AD%E3%82%B0%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%3A%3CBR%20%2F%3E%20%7C%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3A%20%E3%82%B7%E3%82%A7%E3%83%AB%E9%96%A2%E6%95%B0%20do_compile%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%7C%20%E6%B3%A8%3A%20%E7%96%91%E4%BC%BC%E3%83%8D%E3%82%A4%E3%83%86%E3%82%A3%E3%83%96%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%2064%20%E3%83%93%E3%83%83%E3%83%88%20libpseudo.SO%20%E3%81%AE%E3%81%BF%E3%82%92%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%2F%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%7C%20%E6%B3%A8%E6%84%8F%3A%2032%20%E3%83%93%E3%83%83%E3%83%88%E5%AE%9F%E8%A1%8C%E5%8F%AF%E8%83%BD%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81NO32LIBS%20%E3%81%8C%200%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%20%7C%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%203043001%20%E3%81%AE%20SQLite%20%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%81%AF%E3%80%81%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fdas%2FDesktop%2Fdas%2FNXP%2FProject%2Fnxpevb%2Fimx-Yocto-bsp%2Fbuild%2Ftmp%2Fwork%2Fx86_64-Linux%2Fpseudo-native%2F1.9.0%2Bgit%2Frecipe-sysroot-native%2Fusr%20%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%7C%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E3%82%A4%E3%83%B3%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%83%87%E3%83%BC%E3%82%BF%E3%83%99%E3%83%BC%E3%82%B9%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%7C%E6%B3%A8%3A%20make%20-j%204%20RPATH%3D-Wl%2C--rpath%3DXORIGIN%2F..%2F..%2F..%2Fsqlite3-native%2Fusr%2Flib%2F%3CBR%20%2F%3E%20%7C%20make%3A%20'all'%20%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E4%BD%95%E3%82%82%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%7C%20%E8%AD%A6%E5%91%8A%3A%20%E3%82%B7%E3%82%A7%E3%83%AB%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8B%E3%82%89%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%201%20%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20(virtual%3Anative%3A%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fdas%2FDesktop%2Fdas%2FNXP%2FProject%2Fnxpevb%2Fimx-yocto-bsp%2Fsources%2Fpoky%2Fmeta%2Frecipes-devtools%2Fpseudo%2Fpseudo_git.bb%3Ado_compile)%20%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%20'1'%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E6%B3%A8%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E6%A6%82%E8%A6%81%3A%20359%20%E5%80%8B%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%92%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%81%AE%E3%81%86%E3%81%A1%20358%20%E5%80%8B%E3%81%AF%E5%86%8D%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%AA%E3%81%8F%E3%80%811%20%E5%80%8B%E3%81%AF%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E6%A6%82%E8%A6%81%3A%201%20%E4%BB%B6%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%E4%BB%AE%E6%83%B3%3A%E3%83%8D%E3%82%A4%E3%83%86%E3%82%A3%E3%83%96%3A%2Fhome%2Fdas%2FDesktop%2Fdas%2FNXP%2FProject%2Fnxpevb%2Fimx-Yocto-bsp%2Fsources%2Fpoky%2Fmeta%2Frecipes-devtools%2Fpseudo%2Fpseudo_git.bb%3Ado_compile%3CBR%20%2F%3E%E6%A6%82%E8%A6%81%3A%20%E8%AD%A6%E5%91%8A%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%204%20%E4%BB%B6%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E6%A6%82%E8%A6%81%3A%201%20%E3%81%A4%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%82%BC%E3%83%AD%E4%BB%A5%E5%A4%96%E3%81%AE%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%81%AE%20BSP%20%E3%81%8A%E3%82%88%E3%81%B3%20Yacto%20%E3%83%93%E3%83%AB%E3%83%89%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%83%80%E3%82%B9%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2158725%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20IMX8%20%20Plus%20%22Creating%20the%20BSP%20and%20Yocto%20build%20environment%22%20%20compile%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2158725%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EOE_RUNMAKE%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%81%AF%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%A7%E3%81%99%E3%80%82DDR%20%E3%81%8C%E4%B8%8D%E5%8D%81%E5%88%86%E3%81%AA%E5%A0%B4%E5%90%88%E3%82%82%E3%81%9D%E3%81%AE%201%20%E3%81%A4%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%89%8D%E8%BF%B0%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%20%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E9%99%A4%E3%81%8D%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%20%E3%83%9B%E3%82%B9%E3%83%88%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E9%81%A9%E5%88%87%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EHarvey%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2157484%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20IMX8%20%20Plus%20%22Creating%20the%20BSP%20and%20Yocto%20build%20environment%22%20%20compile%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2157484%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENXP%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E5%8A%A9%E3%81%91%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3A%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3Edasmiddepogu%40dasmiddepogu-ThinkPad-L13-Yoga-Gen-3%3A~%2FDesktop%2Fdas%2Fproject%2Fimx-yocto-bsp%2Fbuild%24%20bitbake%20core-image-minimal%3CBR%20%2F%3E%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%3A%20100%25%20%7C%23%20...%7C%20%E6%99%82%E9%96%93%3A%200%3A00%3A01%3CBR%20%2F%3E%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8B%E3%82%89%205449%20%E5%80%8B%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E6%B3%A8%3A%20%E4%B8%8D%E8%B6%B3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%3A%20llvm-native%20%E3%81%AE%E6%8E%A8%E5%A5%A8%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%2017.0.6%20%E3%81%AF%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%20(%E3%82%A2%E3%82%A4%E3%83%86%E3%83%A0%20llvm-native)%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%3A%20%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%20llvm-native%20%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%2017.0.3%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%AB%E3%83%89%E6%A7%8B%E6%88%90%3A%3CBR%20%2F%3E%20BB_VERSION%20%3D%20%222.6.0%22%3CBR%20%2F%3EBUILD_SYS%20%3D%20%22x86_64-linux%22%3CBR%20%2F%3E%20NATIVELSBSTRING%20%3D%20%22%E3%83%A6%E3%83%8B%E3%83%90%E3%83%BC%E3%82%B5%E3%83%AB%22%3CBR%20%2F%3E%20TARGET_SYS%20%3D%20%22aarch64-poky-linux%22%3CBR%20%2F%3E%E3%83%9E%E3%82%B7%E3%83%B3%20%3D%20%22imx8mp-lpddr4-evk%22%3CBR%20%2F%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%3D%20%22fsl-imx-xwayland%22%3CBR%20%2F%3E%20DISTRO_VERSION%20%3D%20%226.6-nanbield%22%3CBR%20%2F%3ETUNE_FEATURES%20%3D%20%22aarch64%20armv8a%20crc%20%E6%9A%97%E5%8F%B7%22%3CBR%20%2F%3E%20TARGET_FPU%20%3D%20%22%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%3CBR%20%2F%3E%20meta-poky%20%3D%20%22HEAD%3A046b70083f3bc9e25f547e8026400032f5c563d9%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BFoe%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%91%E3%82%A4%E3%82%BD%E3%83%B3%20%3D%20%22HEAD%3A1750c66ae8e4268c472c0b2b94748a59d6ef866d%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%20%3D%20%22HEAD%3A0a73d1bdd7713a6189482e463c98043c9939a2a2%22%3CBR%20%2F%3E%20meta-freescale-3rdparty%20%3D%20%22HEAD%3A7725256e3859b62f1ff201db7f2cf7026c17656d%22%3CBR%20%2F%3E%20meta-freescale-distro%20%3D%20%22HEAD%3A4f1f101ebab5eb054bfbed10b247fc0547b30793%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF-imx-bsp%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BFimx-sdk%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BFimx-ml%3CBR%20%2F%3E%20meta-imx-v2x%20%3D%20%22HEAD%3A773c0049c3b35af8f5b5bdf8da78a6236a4fc184%22%3CBR%20%2F%3E%20meta-nxp-demo-experience%20%3D%20%22HEAD%3Adb34fa86ad5f3c0d9c0a6c68f5f20240c04f2bfb%26amp%3BBR%3CBR%20%2F%3E%20%2F%26gt%3Bmeta-Arm%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%82%A2%E3%83%BC%E3%83%A0%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%20%3D%20%22HEAD%3A4d22f982bce8dff6f8c4d11845c47a4d39f961c6%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%82%AF%E3%83%AD%E3%83%9F%E3%82%A6%E3%83%A0%20%3D%20%22HEAD%3Adc31889c0899971def535dc1c040edf18bc16691%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF-clang%20%3D%20%22HEAD%3A9b08495e6bcef524789aefb6a7cc80fdfd2ff409%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%8E%E3%83%BC%E3%83%A0%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AD%E3%83%B3%E3%82%B0%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%3D%20%22HEAD%3A1750c66ae8e4268c472c0b2b94748a59d6ef866d%22%3CBR%20%2F%3E%20meta-qt6%20%3D%20%22HEAD%3Afd054cf5fc1b50d50cd606384ab338c6d9206437%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%91%E3%83%BC%E3%82%BB%E3%82%AF%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BFtpm%20%3D%20%22HEAD%3A070a1e82cc59424d230a23c0b2a104b01fbaa2ad%22%3CBR%20%2F%3E%20meta-%E4%BB%AE%E6%83%B3%E5%8C%96%20%3D%20%22HEAD%3A9e92984ff47b3ca2106b1d27a93af061b28d1e8a%22%3C%2FP%3E%3CP%3E%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%3A%20100%25%20%7C%23%20...%7C%20%E6%99%82%E9%96%93%3A%200%3A00%3A02%3CBR%20%2F%3E%20Sstate%20%E3%81%AE%E6%A6%82%E8%A6%81%3A%20%E5%8B%9F%E9%9B%86%201103%20%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%202%20%E3%83%9F%E3%83%A9%E3%83%BC%200%20%E6%AC%A0%E8%90%BD%201101%20%E7%8F%BE%E5%9C%A8%201686%20(%E4%B8%80%E8%87%B4%E7%8E%87%200%25%E3%80%81%E5%AE%8C%E4%BA%86%E7%8E%87%2060%25)%3CBR%20%2F%3E%E6%B3%A8%E8%A8%98%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E5%AE%9F%E8%A1%8C%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20openssl-3.1.4-r0do_compile%3A%20oe_runmake%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20openssl-3.1.4-r0do_compile%3A%20%E5%AE%9F%E8%A1%8C%E3%82%A8%E3%83%A9%E3%83%BC('%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fdasmiddepogu%2FDesktop%2Fdas%2Fproject%2Fimx-Yocto-bsp%2Fbuild%2Ftmp%2Fwork%2Farmv8a-poky-Linux%2Fopenssl%2F3.1.4%2Ftemp%2Frun.do_compile.14161'%2C%201%2C%20%E3%81%AA%E3%81%97%2C%20%E3%81%AA%E3%81%97)%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E5%A4%B1%E6%95%97%E3%81%AE%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E6%AC%A1%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%20%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fdasmiddepogu%2FDesktop%2Fdas%2Fproject%2Fimx-Yocto-bsp%2Fbuild%2Ftmp%2Fwork%2Farmv8a-poky-Linux%2Fopenssl%2F3.1.4%2Ftemp%2Flog.do_compile.14161%3CBR%20%2F%3E%E3%83%AD%E3%82%B0%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%3A%3CBR%20%2F%3E%20%7C%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3A%20%E3%82%B7%E3%82%A7%E3%83%AB%E9%96%A2%E6%95%B0%20do_compile%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%7C%20%E6%B3%A8%E8%A8%98%3A%20make%20-j%2012%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20(%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fdasmiddepogu%2FDesktop%2Fdas%2Fproject%2Fimx-Yocto-bsp%2Fsources%2Fpoky%2Fmeta%2Frecipes-%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%82%A3%E3%83%93%E3%83%86%E3%82%A3%2Fopenssl%2Fopenssl_3.1.4.bb%3Ado_compile)%20%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%20'1'%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E5%AE%9F%E8%A1%8C%E4%B8%AD%E3%81%AE%2011%20%E5%80%8B%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%99%E3%82%8B%E3%81%AE%E3%82%92%E5%BE%85%E6%A9%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%3CBR%20%2F%3E%200%3A%20qemu-native-8.1.2-r0do_compile%20-%2045%E7%A7%92%20(pid%2014162)%3CBR%20%2F%3E%201%3A%20linux-imx-6.6.3%2Bgit-r0do_fetch%20-%2045%20%E7%A7%92%20(pid%2014185)%20%7C%20%26lt%3B%3D%26gt%3B%20%7C%3CBR%20%2F%3E%202%3A%20rust-llvm-native-1.70.0-r0%20do_compile%20-%2045%20%E7%A7%92%20(pid%2014195)%200%25%20%7C%20%7C%3CBR%20%2F%3E%203%3A%20icu-73-2-r0%20do_compile%20-%2044%E7%A7%92%20(pid%2014317)%3CBR%20%2F%3E%204%3A%20perl-5.38.0-r0%20do_compile%20-%2043%E7%A7%92%20(pid%2014323)%3CBR%20%2F%3E%205%3A%20util-linux-2.39.2-r0%20do_package%20-%2043s%20(pid%2014318)%3CBR%20%2F%3E%206%3A%20libical-native-3.0.16-r0%20do_compile%20-%2043%20%E7%A7%92%20(pid%2014321)%2036%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%7C%3CBR%20%2F%3E%207%3A%20bash-5.2.15-r0%20do_configure%20-%2043s%20(pid%201432%5EC%3CBR%20%2F%3E%20%3CA%20href%3D%22mailto%3Adasmiddepogu%40dasmiddepogu-ThinkPad-L13-Yoga-Gen-3%3A~%2FDesktop%2Fdas%2Fproject%2Fimx-y%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Edasmiddepogu%40dasmiddepogu-ThinkPad-L13-Yoga-Gen-3%3A~%2FDesktop%2Fdas%2Fproject%2Fimx-y%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%80%E3%82%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2157483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20IMX8%20%20Plus%20%22Creating%20the%20BSP%20and%20Yocto%20build%20environment%22%20%20compile%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2157483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENXP%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6CAN%E3%82%92%E5%8A%A9%E3%81%91%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3A%3C%2FP%3E%3CP%3E%3CBR%20%2F%3Edasmiddepogu%40dasmiddepogu-ThinkPad-L13-Yoga-Gen-3%3A~%2FDesktop%2Fdas%2Fproject%2Fimx-yocto-bsp%2Fbuild%24%20bitbake%20-c%20cleansstate%20openssl%3C%2FP%3E%3CP%3Edasmiddepogu%40dasmiddepogu-ThinkPad-L13-Yoga-Gen-3%3A~%2FDesktop%2Fdas%2Fproject%2Fimx-yocto-bsp%2Fbuild%24%20bitbake%20openssl%3CBR%20%2F%3E%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%3A%20100%25%20%7C%23%20...%7C%20%E6%99%82%E9%96%93%3A%200%3A00%3A00%3CBR%20%2F%3E%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8B%E3%82%89%205449%20%E5%80%8B%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E6%B3%A8%3A%20%E4%B8%8D%E8%B6%B3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%AB%E3%83%89%E6%A7%8B%E6%88%90%3A%3CBR%20%2F%3E%20BB_VERSION%20%3D%20%222.6.0%22%3CBR%20%2F%3EBUILD_SYS%20%3D%20%22x86_64-linux%22%3CBR%20%2F%3E%20NATIVELSBSTRING%20%3D%20%22%E3%83%A6%E3%83%8B%E3%83%90%E3%83%BC%E3%82%B5%E3%83%AB%22%3CBR%20%2F%3E%20TARGET_SYS%20%3D%20%22aarch64-poky-linux%22%3CBR%20%2F%3E%E3%83%9E%E3%82%B7%E3%83%B3%20%3D%20%22imx8mp-lpddr4-evk%22%3CBR%20%2F%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%3D%20%22fsl-imx-xwayland%22%3CBR%20%2F%3E%20DISTRO_VERSION%20%3D%20%226.6-nanbield%22%3CBR%20%2F%3ETUNE_FEATURES%20%3D%20%22aarch64%20armv8a%20crc%20%E6%9A%97%E5%8F%B7%22%3CBR%20%2F%3E%20TARGET_FPU%20%3D%20%22%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%3CBR%20%2F%3E%20meta-poky%20%3D%20%22HEAD%3A046b70083f3bc9e25f547e8026400032f5c563d9%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BFoe%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%91%E3%82%A4%E3%82%BD%E3%83%B3%20%3D%20%22HEAD%3A1750c66ae8e4268c472c0b2b94748a59d6ef866d%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%20%3D%20%22HEAD%3A0a73d1bdd7713a6189482e463c98043c9939a2a2%22%3CBR%20%2F%3E%20meta-freescale-3rdparty%20%3D%20%22HEAD%3A7725256e3859b62f1ff201db7f2cf7026c17656d%22%3CBR%20%2F%3E%20meta-freescale-distro%20%3D%20%22HEAD%3A4f1f101ebab5eb054bfbed10b247fc0547b30793%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF-imx-bsp%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BFimx-sdk%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BFimx-ml%3CBR%20%2F%3E%20meta-imx-v2x%20%3D%20%22HEAD%3A773c0049c3b35af8f5b5bdf8da78a6236a4fc184%22%3CBR%20%2F%3E%20meta-nxp-demo-experience%20%3D%20%22HEAD%3Adb34fa86ad5f3c0d9c0a6c68f5f20240c04f2bfb%26amp%3BBR%3CBR%20%2F%3E%20%2F%26gt%3Bmeta-Arm%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%82%A2%E3%83%BC%E3%83%A0%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%20%3D%20%22HEAD%3A4d22f982bce8dff6f8c4d11845c47a4d39f961c6%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%82%AF%E3%83%AD%E3%83%9F%E3%82%A6%E3%83%A0%20%3D%20%22HEAD%3Adc31889c0899971def535dc1c040edf18bc16691%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF-clang%20%3D%20%22HEAD%3A9b08495e6bcef524789aefb6a7cc80fdfd2ff409%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%8E%E3%83%BC%E3%83%A0%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AD%E3%83%B3%E3%82%B0%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%3D%20%22HEAD%3A1750c66ae8e4268c472c0b2b94748a59d6ef866d%22%3CBR%20%2F%3E%20meta-qt6%20%3D%20%22HEAD%3Afd054cf5fc1b50d50cd606384ab338c6d9206437%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%91%E3%83%BC%E3%82%BB%E3%82%AF%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BFtpm%20%3D%20%22HEAD%3A070a1e82cc59424d230a23c0b2a104b01fbaa2ad%22%3CBR%20%2F%3E%20meta-%E4%BB%AE%E6%83%B3%E5%8C%96%20%3D%20%22HEAD%3A9e92984ff47b3ca2106b1d27a93af061b28d1e8a%22%3C%2FP%3E%3CP%3E%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%3A%20100%25%20%7C%23%20...%7C%20%E6%99%82%E9%96%93%3A%200%3A00%3A00%3CBR%20%2F%3E%20Sstate%20%E3%81%AE%E6%A6%82%E8%A6%81%3A%20%E5%B8%8C%E6%9C%9B%20100%20%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%200%20%E3%83%9F%E3%83%A9%E3%83%BC%200%20%E6%AC%A0%E8%90%BD%20100%20%E7%8F%BE%E5%9C%A8%20616%20(%E4%B8%80%E8%87%B4%E7%8E%87%200%25%E3%80%81%E5%AE%8C%E4%BA%86%E7%8E%87%2086%25)%3CBR%20%2F%3E%E6%B3%A8%E8%A8%98%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E5%AE%9F%E8%A1%8C%3CBR%20%2F%3E%E6%B3%A8%3A%2030%20%E7%A7%92%E4%BB%A5%E5%86%85%E3%81%AB%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%8B%E3%82%89%E3%81%AE%E5%BF%9C%E7%AD%94%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%20(%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20ping%20%E3%81%AF%2005%3A13%3A49.520202%20%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F)%3CBR%20%2F%3EBitbake%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%8B%E3%82%89%E3%81%AE%E5%BF%9C%E7%AD%94%E3%82%92%E5%BE%85%E6%A9%9F%E4%B8%AD%E3%81%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20(05%3A14%3A19.561139%20%E3%81%AB%2060%20%E7%A7%92)%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%201TB%20%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%80%818GB%20%E3%81%AE%20RAM%E3%80%8110%20%E5%80%8B%E3%81%AE%20CPU%20%E3%82%B3%E3%82%A2%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%83%9B%E3%82%B9%E3%83%88%20PC%20%E3%82%92%E6%89%80%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EThinkPad-L13-Yoga-Gen-3%205.15.0-139-generic%20%23149~20.04.1-UbuntuSMP%20%E6%B0%B4%E6%9B%9C%E6%97%A5%204%E6%9C%8816%E6%97%A5%2008%3A29%3A56%20UTC%202025%20x86_64%20x86_64%20x86_64%20GNU%2FLinux%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%80%E3%82%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2155829%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20IMX8%20%20Plus%20%22Creating%20the%20BSP%20and%20Yocto%20build%20environment%22%20%20compile%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2155829%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%80%82%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%83%AC%E3%82%B7%E3%83%94%E3%81%8B%E3%82%89%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AB%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%97%E3%81%9F%E3%82%8A%E3%80%81Yocto%20%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A9%E3%83%A0%E3%81%8B%E3%82%89%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E5%8F%97%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E3%81%BE%E3%81%9F%E5%88%A5%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%95%E3%82%89%E3%81%AA%E3%82%8B%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%83%81%E3%82%B1%E3%83%83%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E5%89%8D%E8%BF%B0%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%2F%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%95%E3%83%AB%2F%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%81%AF%E4%BB%96%E3%81%AE%E5%B0%8F%E3%81%95%E3%81%AA%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%81%A8%E5%90%8C%E6%A7%98%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EHarvey%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2155195%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20IMX8%20%20Plus%20%22Creating%20the%20BSP%20and%20Yocto%20build%20environment%22%20%20compile%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2155195%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81NXP%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%A7%8B%E6%88%90%20(bitbake%20fsl-image-machine-test%E3%80%81bitbake%20imx-image-multimedia%E3%80%81bitbake%20imx-image-full)%20%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AB%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%86%85%E3%81%A7%3CSTRONG%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%20(%E3%80%8Copencv%E3%80%8D%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%8Cvulkan%E3%80%8D)%20%E3%82%92%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%A6%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%E3%82%92%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%3F%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%90%8D%E3%81%A8%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%20%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%82%92%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%82%A2%E3%82%A6%E3%83%88%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E5%A0%B4%E6%89%80%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3E%E7%A7%81%E3%81%AE%E6%9C%80%E7%B5%82%E7%9B%AE%E6%A8%99%E3%81%AF%E3%80%81%E3%83%95%E3%83%AB%E3%83%93%E3%83%AB%E3%83%89%20(bitbake%20imx-image-full)%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E4%B8%8A%E8%A8%98%E3%81%AE%E5%AE%9F%E9%A8%93%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E3%81%A9%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%81%A8%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%82%92%E7%89%B9%E5%AE%9ACAN%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%83%80%E3%82%B9%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3ESO%E4%B8%8A%E8%A8%98%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%8B%E3%82%89%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%9F%E3%81%B3%E3%81%AB%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3E%E3%80%8Copencv%E3%80%8D%E3%81%A8%E3%80%8Cvulkan%E3%80%8D%E3%81%A7Bitbake%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%B8%E3%81%AE%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%82%A3%E3%83%93%E3%83%86%E3%82%A3%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%93%E3%83%AB%E3%83%89%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%80%8Copencv%E3%80%8D%E3%81%A8%E3%80%8Cvulkan%E3%80%8D%E3%81%AE%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%82%92%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%9F%E3%82%8A%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%9F%E3%82%8A%E3%81%97%E3%81%A6%E3%80%81%E5%85%88%E3%81%AB%E9%80%B2%E3%82%81%E3%81%9F%E3%82%8A%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%82%E3%81%AE%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2155070%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20IMX8%20%20Plus%20%22Creating%20the%20BSP%20and%20Yocto%20build%20environment%22%20%20compile%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2155070%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E3%80%81%E3%83%95%E3%83%AB%2F%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E4%B8%BB%E3%81%AA%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%81%A7%E3%81%99%3C%2FSPAN%3E%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%82%92%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81imx-image-core%20%E3%82%92%E7%9B%B4%E6%8E%A5%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E6%96%B9%E3%81%8C%E9%81%A9%E5%88%87%E3%81%A7%E3%81%99%E3%80%82%E5%89%8D%E8%BF%B0%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%20%E3%83%9B%E3%82%B9%E3%83%88%E3%82%92%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EHarvey%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2154901%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20IMX8%20%20Plus%20%22Creating%20the%20BSP%20and%20Yocto%20build%20environment%22%20%20compile%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2154901%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81NXP%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF4%E3%81%A4%E3%81%AECPU%E3%80%811TB%E3%81%AEHDD%E3%80%818GB%E3%81%AERAM%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%8B%A7%E3%82%81%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81%20RAM%20%E3%82%92%2016%20GB%20%E4%BB%A5%E4%B8%8A%E3%81%AB%E5%A2%97%E3%82%84%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%80%8CMACHINE%20%3D%20%22imx8mp-lpddr4-evk%22%E3%80%8D%3C%2FSTRONG%3E%E7%94%A8%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E8%A6%B3%E5%AF%9F%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%E3%81%AE%E6%A6%82%E8%A6%81%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E6%A7%8B%E7%AF%89%E5%8F%AF%E8%83%BD%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Ebitbake%20imx-image-core%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Ebitbake%20fsl-image-machine-test%3CBR%20%2F%3E%20bitbake%20imx-image-multimedia%3CBR%20%2F%3E%20bitbake%20imx-image-full%3C%2FP%3E%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AEconfigure%E3%81%8B%E3%82%89%3CSTRONG%3E%E3%80%81%E3%80%8Copencv%E3%80%8D%E3%81%A8%E3%80%8Cvulkan%E3%80%8D%E3%82%92%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81Bitbake%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%B8%E3%81%AE%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%82%A3%E3%83%93%E3%83%86%E3%82%A3%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%EF%BC%88%E3%80%8Copencv%E3%80%8D%E3%81%A8%E3%80%8Cvulkan%E3%80%8D%EF%BC%89%E3%82%92%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%9F%E3%82%8A%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%9F%E3%82%8A%E3%81%97%E3%81%A6%E3%80%81%E5%85%88%E3%81%AB%E9%80%B2%E3%82%81%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3ECAN%20%E3%80%8Copencv%E3%80%8D%E3%81%A8%E3%80%8Cvulkan%E3%80%8D%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%82%92%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E5%90%8D%E3%81%A8%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%99%E3%82%8B%E5%A0%B4%E6%89%80%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3E%E3%81%94%E5%AF%BE%E5%BF%9C%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%83%80%E3%82%B9%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2154119%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20IMX8%20%20Plus%20%22Creating%20the%20BSP%20and%20Yocto%20build%20environment%22%20%20compile%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2154119%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22jCAhz%20ChMk0b%22%3E%3CSPAN%20class%3D%22ryNqvb%22%3E%E3%83%93%E3%83%AB%E3%83%89%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E3%81%93%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%81%AE%E8%A6%81%E4%BB%B6%E3%82%92%E6%BA%80%E3%81%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22jCAhz%20ChMk0b%22%3E%3CSPAN%20class%3D%22ryNqvb%22%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%20Yocto%20%E3%81%8B%E3%82%89%E3%81%AE%E6%A7%8B%E6%88%90%E6%8E%A8%E5%A5%A8%E4%BA%8B%E9%A0%85%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fdocs.yoctoproject.org%2F5.2.2%2Fbrief-yoctoprojectqs%2Findex.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EYocto%20Project%20%E3%82%AF%E3%82%A4%E3%83%83%E3%82%AF%E3%83%93%E3%83%AB%E3%83%89%20%E2%80%94%20Yocto%20Project%20%C2%AE%205.2.2%20%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%3C%2FA%3E%3C%2FP%3E%0A%3CUL%20class%3D%22simple%22%3E%0A%3CLI%3E%0A%3CP%3E%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%A8%E3%82%82%208%20GB%20%E3%81%AE%20RAM%20%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%20%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%82%92%E6%9C%80%E5%A4%A7%E9%99%90%E3%81%AB%E9%AB%98%E3%82%81%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A0%E3%81%91%E5%A4%9A%E3%81%8F%E3%81%AE%20RAM%20%E3%81%A8%20CPU%20%E3%82%B3%E3%82%A2%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%E6%9C%80%E6%96%B0%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%20%E3%83%9B%E3%82%B9%E3%83%88%E3%81%AE%E4%BD%BF%E7%94%A8%E3%82%92%E5%BC%B7%E3%81%8F%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSPAN%20class%3D%22jCAhz%20ChMk0b%22%3E%3CSPAN%20class%3D%22ryNqvb%22%3E%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E6%8E%A8%E5%A5%A8%E4%BA%8B%E9%A0%85%3A%20CPU%20%E3%82%B3%E3%82%A2%E3%81%8C%204%20%E3%81%A4%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%A8%E3%82%82%2016%20GB%20%E3%81%AE%20RAM%20%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22jCAhz%20ChMk0b%22%3E%3CSPAN%20class%3D%22ryNqvb%22%3E1%3A4%E3%81%AE%E6%AF%94%E7%8E%87%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22jCAhz%20ChMk0b%22%3E%3CSPAN%20class%3D%22ryNqvb%22%3E%3CA%20href%3D%22https%3A%2F%2Fdocs.yoctoproject.org%2Fdev-manual%2Fspeeding-up-build.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fdocs.yoctoproject.org%2Fdev-manual%2Fspeeding-up-build.html%3C%2FA%3E%E3%82%82%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22jCAhz%20ChMk0b%22%3E%3CSPAN%20class%3D%22ryNqvb%22%3E%E5%AE%8C%E5%85%A8%E3%81%AA%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%A8%E3%82%82%20250%20GB%20%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%E5%AE%B9%E9%87%8F%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22jCAhz%20ChMk0b%22%3E%3CSPAN%20class%3D%22ryNqvb%22%3E%E7%A7%81%E3%81%AF%E8%87%AA%E5%88%86%E3%81%AE%E3%83%9B%E3%82%B9%E3%83%88%E3%81%A7%E5%90%8C%E3%81%98%E3%81%93%E3%81%A8%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%2022.04.1-Ubuntu%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3Ebitbake%20imx-image-full%20-c%20populate_sdk%3CBR%20%2F%3E%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%3A%20100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%20%E6%99%82%E9%96%93%3A%200%3A00%3A01%3CBR%20%2F%3E%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8B%E3%82%89%205449%20%E5%80%8B%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E6%B3%A8%3A%20%E4%B8%8D%E8%B6%B3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%3A%20llvm-native%20%E3%81%AE%E6%8E%A8%E5%A5%A8%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%2017.0.6%20%E3%81%AF%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%20(%E3%82%A2%E3%82%A4%E3%83%86%E3%83%A0%20llvm-native)%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%3A%20%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%20llvm-native%20%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%2017.0.3%3C%2FP%3E%0A%3CP%3E%E3%83%93%E3%83%AB%E3%83%89%E6%A7%8B%E6%88%90%3A%3CBR%20%2F%3E%20BB_VERSION%20%3D%20%222.6.0%22%3CBR%20%2F%3EBUILD_SYS%20%3D%20%22x86_64-linux%22%3CBR%20%2F%3E%20NATIVELSBSTRING%20%3D%20%22%E3%83%A6%E3%83%8B%E3%83%90%E3%83%BC%E3%82%B5%E3%83%AB%22%3CBR%20%2F%3E%20TARGET_SYS%20%3D%20%22aarch64-poky-linux%22%3CBR%20%2F%3E%E3%83%9E%E3%82%B7%E3%83%B3%20%3D%20%22imx8mp-lpddr4-evk%22%3CBR%20%2F%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%3D%20%22fsl-imx-xwayland%22%3CBR%20%2F%3E%20DISTRO_VERSION%20%3D%20%226.6-nanbield%22%3CBR%20%2F%3ETUNE_FEATURES%20%3D%20%22aarch64%20armv8a%20crc%20%E6%9A%97%E5%8F%B7%22%3CBR%20%2F%3E%20TARGET_FPU%20%3D%20%22%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%3CBR%20%2F%3E%20meta-poky%20%3D%20%22HEAD%3A046b70083f3bc9e25f547e8026400032f5c563d9%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BFoe%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%91%E3%82%A4%E3%82%BD%E3%83%B3%20%3D%20%22HEAD%3A1750c66ae8e4268c472c0b2b94748a59d6ef866d%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%20%3D%20%22HEAD%3A0a73d1bdd7713a6189482e463c98043c9939a2a2%22%3CBR%20%2F%3E%20meta-freescale-3rdparty%20%3D%20%22HEAD%3A7725256e3859b62f1ff201db7f2cf7026c17656d%22%3CBR%20%2F%3E%20meta-freescale-distro%20%3D%20%22HEAD%3A4f1f101ebab5eb054bfbed10b247fc0547b30793%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF-imx-bsp%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BFimx-sdk%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BFimx-ml%3CBR%20%2F%3E%20meta-imx-v2x%20%3D%20%22HEAD%3A773c0049c3b35af8f5b5bdf8da78a6236a4fc184%22%3CBR%20%2F%3E%20meta-nxp-demo-experience%20%3D%20%22HEAD%3Adb34fa86ad5f3c0d9c0a6c68f5f20240c04f2bfb%26amp%3BBR%3CBR%20%2F%3E%20%2F%26gt%3Bmeta-Arm%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%82%A2%E3%83%BC%E3%83%A0%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%20%3D%20%22HEAD%3A4d22f982bce8dff6f8c4d11845c47a4d39f961c6%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%82%AF%E3%83%AD%E3%83%9F%E3%82%A6%E3%83%A0%20%3D%20%22HEAD%3Adc31889c0899971def535dc1c040edf18bc16691%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF-clang%20%3D%20%22HEAD%3A9b08495e6bcef524789aefb6a7cc80fdfd2ff409%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%8E%E3%83%BC%E3%83%A0%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AD%E3%83%B3%E3%82%B0%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%3D%20%22HEAD%3A1750c66ae8e4268c472c0b2b94748a59d6ef866d%22%3CBR%20%2F%3E%20meta-qt6%20%3D%20%22HEAD%3Afd054cf5fc1b50d50cd606384ab338c6d9206437%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%91%E3%83%BC%E3%82%BB%E3%82%AF%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BFtpm%20%3D%20%22HEAD%3A070a1e82cc59424d230a23c0b2a104b01fbaa2ad%22%3CBR%20%2F%3E%20meta-%E4%BB%AE%E6%83%B3%E5%8C%96%20%3D%20%22HEAD%3A9e92984ff47b3ca2106b1d27a93af061b28d1e8a%22%3C%2FP%3E%0A%3CP%3E%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%3A%20100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%20%E6%99%82%E9%96%93%3A%200%3A00%3A06%3CBR%20%2F%3E%20Sstate%20%E3%81%AE%E6%A6%82%E8%A6%81%3A%20%E5%8B%9F%E9%9B%86%203349%20%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%200%20%E3%83%9F%E3%83%A9%E3%83%BC%200%20%E6%AC%A0%E8%90%BD%203349%20%E7%8F%BE%E5%9C%A8%204781%20(%E4%B8%80%E8%87%B4%E7%8E%87%200%25%E3%80%81%E5%AE%8C%E4%BA%86%E7%8E%87%2058%25)%3CBR%20%2F%3E%E6%B3%A8%E8%A8%98%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E5%AE%9F%E8%A1%8C%3CBR%20%2F%3E%E6%B3%A8%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E6%A6%82%E8%A6%81%3A%2017%2C993%20%E4%BB%B6%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%92%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%81%AE%E3%81%86%E3%81%A1%2013%2C736%20%E4%BB%B6%E3%81%AF%E5%86%8D%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%AA%E3%81%8F%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%A6%82%E8%A6%81%3A%20%E8%AD%A6%E5%91%8A%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%202%20%E4%BB%B6%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EHarvey%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2153192%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20IMX8%20%20Plus%20%22Creating%20the%20BSP%20and%20Yocto%20build%20environment%22%20%20compile%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2153192%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81NXP%E3%81%95%E3%82%93%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8(fsl-image-machine-)%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E3%80%81Bitbake%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AE%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%82%A3%E3%83%93%E3%83%86%E3%82%A3%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20test%E3%80%81imx-image-multimedia%E3%80%81imx-image-full%20%E3%81%AA%E3%81%A9%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%20(imx-image-core%E3%80%81core-image-base)%20%E7%94%A8%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%A6%E3%82%82%E5%95%8F%E9%A1%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%20(fsl-image-machine-test%E3%80%81imx-image-multimedia%E3%80%81imx-image-full)%20%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81Bitbake%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%A7%E3%81%AF%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%20Vulkan%20%E3%81%8A%E3%82%88%E3%81%B3%20OpenCV%20%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E7%94%A8%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82Vulkan%20%E3%81%8A%E3%82%88%E3%81%B3%20OpenCV%20%E7%94%A8%E3%81%AE%E3%83%93%E3%83%83%E3%83%88%E3%83%90%E3%83%83%E3%82%AF%E3%83%93%E3%83%AB%E3%83%89%E3%82%92%E6%9C%80%E9%81%A9%E5%8C%96%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%9F%E4%BB%96%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E5%86%85%E3%81%AB%204%20%E3%81%A4%E3%81%AE%20CPU%20%E3%82%B3%E3%82%A2%E3%82%92%E4%BF%9D%E6%8C%81%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99CAN%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E3%83%AD%E3%82%B0%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3A%3C%2FP%3E%3CP%3E******************%E3%83%AD%E3%82%B0***********************%3C%2FP%3E%3CP%3E%E6%B3%A8%E6%84%8F%3A%20conf%2Fbblayers.conf%20%E3%81%AF%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%3A%20100%25%20%7C%23%20...%7C%20%E6%99%82%E9%96%93%3A%200%3A00%3A01%3CBR%20%2F%3E%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8B%E3%82%89%205449%20%E5%80%8B%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E6%B3%A8%3A%20%E4%B8%8D%E8%B6%B3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%3A%20llvm-native%20%E3%81%AE%E6%8E%A8%E5%A5%A8%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%2017.0.6%20%E3%81%AF%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%20(%E3%82%A2%E3%82%A4%E3%83%86%E3%83%A0%20llvm-native)%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%3A%20%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%20llvm-native%20%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%2017.0.3%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%AB%E3%83%89%E6%A7%8B%E6%88%90%3A%3CBR%20%2F%3E%20BB_VERSION%20%3D%20%222.6.0%22%3CBR%20%2F%3EBUILD_SYS%20%3D%20%22x86_64-linux%22%3CBR%20%2F%3E%20NATIVELSBSTRING%20%3D%20%22%E3%83%A6%E3%83%8B%E3%83%90%E3%83%BC%E3%82%B5%E3%83%AB%22%3CBR%20%2F%3E%20TARGET_SYS%20%3D%20%22aarch64-poky-linux%22%3CBR%20%2F%3E%E3%83%9E%E3%82%B7%E3%83%B3%20%3D%20%22imx8mp-lpddr4-evk%22%3CBR%20%2F%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%3D%20%22fsl-imx-xwayland%22%3CBR%20%2F%3E%20DISTRO_VERSION%20%3D%20%226.6-nanbield%22%3CBR%20%2F%3ETUNE_FEATURES%20%3D%20%22aarch64%20armv8a%20crc%20%E6%9A%97%E5%8F%B7%22%3CBR%20%2F%3E%20TARGET_FPU%20%3D%20%22%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%3CBR%20%2F%3E%20meta-poky%20%3D%20%22HEAD%3A046b70083f3bc9e25f547e8026400032f5c563d9%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BFoe%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%91%E3%82%A4%E3%82%BD%E3%83%B3%20%3D%20%22HEAD%3A1750c66ae8e4268c472c0b2b94748a59d6ef866d%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%20%3D%20%22HEAD%3A0a73d1bdd7713a6189482e463c98043c9939a2a2%22%3CBR%20%2F%3E%20meta-freescale-3rdparty%20%3D%20%22HEAD%3A7725256e3859b62f1ff201db7f2cf7026c17656d%22%3CBR%20%2F%3E%20meta-freescale-distro%20%3D%20%22HEAD%3A4f1f101ebab5eb054bfbed10b247fc0547b30793%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF-imx-bsp%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BFimx-sdk%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BFimx-ml%3CBR%20%2F%3E%20meta-imx-v2x%20%3D%20%22HEAD%3A773c0049c3b35af8f5b5bdf8da78a6236a4fc184%22%3CBR%20%2F%3E%20meta-nxp-demo-experience%20%3D%20%22HEAD%3Adb34fa86ad5f3c0d9c0a6c68f5f20240c04f2bfb%26amp%3BBR%3CBR%20%2F%3E%20%2F%26gt%3Bmeta-Arm%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%82%A2%E3%83%BC%E3%83%A0%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%20%3D%20%22HEAD%3A4d22f982bce8dff6f8c4d11845c47a4d39f961c6%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%82%AF%E3%83%AD%E3%83%9F%E3%82%A6%E3%83%A0%20%3D%20%22HEAD%3Adc31889c0899971def535dc1c040edf18bc16691%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF-clang%20%3D%20%22HEAD%3A9b08495e6bcef524789aefb6a7cc80fdfd2ff409%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%8E%E3%83%BC%E3%83%A0%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AD%E3%83%B3%E3%82%B0%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%3D%20%22HEAD%3A1750c66ae8e4268c472c0b2b94748a59d6ef866d%22%3CBR%20%2F%3E%20meta-qt6%20%3D%20%22HEAD%3Afd054cf5fc1b50d50cd606384ab338c6d9206437%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%91%E3%83%BC%E3%82%BB%E3%82%AF%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BFtpm%20%3D%20%22HEAD%3A070a1e82cc59424d230a23c0b2a104b01fbaa2ad%22%3CBR%20%2F%3E%20meta-%E4%BB%AE%E6%83%B3%E5%8C%96%20%3D%20%22HEAD%3A9e92984ff47b3ca2106b1d27a93af061b28d1e8a%22%3C%2FP%3E%3CP%3E%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%3A%20100%25%20%7C%23%20...%7C%20%E6%99%82%E9%96%93%3A%200%3A00%3A08%3CBR%20%2F%3E%20Sstate%20%E3%81%AE%E6%A6%82%E8%A6%81%3A%20%E5%8B%9F%E9%9B%86%201071%20%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%202%20%E3%83%9F%E3%83%A9%E3%83%BC%200%20%E6%AC%A0%E8%90%BD%201069%20%E7%8F%BE%E5%9C%A8%205652%20(%E4%B8%80%E8%87%B4%E7%8E%87%200%25%E3%80%81%E5%AE%8C%E4%BA%86%E7%8E%87%2084%25)%3CBR%20%2F%3E%E6%B3%A8%E8%A8%98%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E5%AE%9F%E8%A1%8C%3CBR%20%2F%3E%E6%B3%A8%3A%2030%20%E7%A7%92%E4%BB%A5%E5%86%85%E3%81%AB%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%8B%E3%82%89%E3%81%AE%E5%BF%9C%E7%AD%94%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%20(22%3A27%3A39.389536%20%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20ping%20%E3%81%AE%E5%A0%B4%E5%90%88)%3CBR%20%2F%3EBitbake%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%8B%E3%82%89%E3%81%AE%E5%BF%9C%E7%AD%94%E3%82%92%E5%BE%85%E6%A9%9F%E4%B8%AD%E3%81%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20(22%3A28%3A09.428551%20%E3%81%AB%2060%20%E7%A7%92)%3CBR%20%2F%3EMiddepogudas%40middepogudas-ThinkPad-L14-Gen-1%3A~%2FDesktop%2Fdas%2Fproject%2Fimx-yocto-bsp%2Fbuild%24%20bitbake%20imx-image-multimedia%3CBR%20%2F%3E%E6%B3%A8%3A%20Bitbake%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AB%E5%86%8D%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%E6%B3%A8%3A%2030%20%E7%A7%92%E4%BB%A5%E5%86%85%E3%81%AB%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%8B%E3%82%89%E3%81%AE%E5%BF%9C%E7%AD%94%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%20(%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20setFeatures%E3%80%8122%3A28%3A45.138306)%3CBR%20%2F%3E%E6%B3%A8%E8%A8%98%3A%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E6%8E%A5%E7%B6%9A%E3%82%92%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20(%231)...%20(22%3A29%3A15.167756)%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%80%E3%82%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2150152%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20IMX8%20%20Plus%20%22Creating%20the%20BSP%20and%20Yocto%20build%20environment%22%20%20compile%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150152%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F251894%22%20target%3D%22_blank%22%3E%40middepogudas%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%83%9B%E3%82%B9%E3%83%88%E3%81%8CNXP%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E5%86%85%E3%81%AB%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81NXP%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E7%AE%A1%E7%90%86%E8%80%85%E3%81%AB%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EHarvey%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2150126%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20IMX8%20%20Plus%20%22Creating%20the%20BSP%20and%20Yocto%20build%20environment%22%20%20compile%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150126%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81NXP%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%80%8C%3CSPAN%3E%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%97%E3%83%AD%E3%82%AD%E3%82%B7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%E3%80%8D%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E6%89%8B%E9%A0%86%E3%82%84%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%B7%E3%82%A7%E3%82%A2%E3%82%84%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AB%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%83%80%E3%82%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2150106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20IMX8%20%20Plus%20%22Creating%20the%20BSP%20and%20Yocto%20build%20environment%22%20%20compile%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%8F%96%E5%BE%97%E5%A4%B1%E6%95%97%E3%81%AE%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%97%E3%83%AD%E3%82%AD%E3%82%B7%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E6%9C%80%E5%88%9D%E3%81%AE%E8%BF%94%E4%BF%A1%E3%81%AE%E5%8F%82%E8%80%83%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81%E3%83%9B%E3%82%B9%E3%83%88%E3%81%AE%E6%A7%8B%E6%88%90%E3%82%82%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E6%96%B0%E3%81%97%E3%81%84%E3%83%93%E3%83%AB%E3%83%89%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82CAN%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EHarvey%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2150012%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20IMX8%20%20Plus%20%22Creating%20the%20BSP%20and%20Yocto%20build%20environment%22%20%20compile%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150012%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENXP%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%BB%E3%81%A3%E3%81%A6%E3%81%8D%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%A6%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%E3%83%93%E3%83%AB%E3%83%89%20%E3%83%AD%E3%82%B0%E3%82%92%E4%BB%A5%E4%B8%8B%E3%81%AB%E8%B2%BC%E3%82%8A%E4%BB%98%E3%81%91%E3%81%A6%E3%81%8A%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E4%BE%9D%E7%84%B6%E3%81%A8%E3%81%97%E3%81%A6%E3%83%93%E3%83%83%E3%83%88%E3%83%90%E3%83%83%E3%82%AF%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AE%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%82%A3%E3%83%93%E3%83%86%E3%82%A3%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%BD%95%E5%BA%A6%E3%81%8BPC%E3%82%92%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82Bitbake%20%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E4%BB%8A%E5%BE%8C%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E9%80%B2%E3%82%81%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%8B%E6%83%85%E5%A0%B1%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E**********************%E3%83%AD%E3%82%B0********%3C%2FP%3E%3CP%3Edasmiddepogu%40dasmiddepogu-ThinkPad-L14-Gen-1%3A~%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-yocto-bsp%2Fbuild%24%20bitbake%20imx-image-full%20-c%20populate_sdk%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%3A%20conf%2Fbblayers.conf%20%E3%81%AF%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%3A%20100%25%20%7C%23%20...%7C%20%E6%99%82%E9%96%93%3A%200%3A00%3A01%3CBR%20%2F%3E%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8B%E3%82%89%205449%20%E5%80%8B%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E6%B3%A8%3A%20%E4%B8%8D%E8%B6%B3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%3A%20llvm-native%20%E3%81%AE%E6%8E%A8%E5%A5%A8%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%2017.0.6%20%E3%81%AF%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%20(%E3%82%A2%E3%82%A4%E3%83%86%E3%83%A0%20llvm-native)%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%3A%20%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%20llvm-native%20%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%2017.0.3%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%AB%E3%83%89%E6%A7%8B%E6%88%90%3A%3CBR%20%2F%3E%20BB_VERSION%20%3D%20%222.6.0%22%3CBR%20%2F%3EBUILD_SYS%20%3D%20%22x86_64-linux%22%3CBR%20%2F%3E%20NATIVELSBSTRING%20%3D%20%22%E3%83%A6%E3%83%8B%E3%83%90%E3%83%BC%E3%82%B5%E3%83%AB%22%3CBR%20%2F%3E%20TARGET_SYS%20%3D%20%22aarch64-poky-linux%22%3CBR%20%2F%3E%E3%83%9E%E3%82%B7%E3%83%B3%20%3D%20%22imx8mp-lpddr4-evk%22%3CBR%20%2F%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%3D%20%22fsl-imx-xwayland%22%3CBR%20%2F%3E%20DISTRO_VERSION%20%3D%20%226.6-nanbield%22%3CBR%20%2F%3ETUNE_FEATURES%20%3D%20%22aarch64%20armv8a%20crc%20%E6%9A%97%E5%8F%B7%22%3CBR%20%2F%3E%20TARGET_FPU%20%3D%20%22%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%3CBR%20%2F%3E%20meta-poky%20%3D%20%22HEAD%3A046b70083f3bc9e25f547e8026400032f5c563d9%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BFoe%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%91%E3%82%A4%E3%82%BD%E3%83%B3%20%3D%20%22HEAD%3A1750c66ae8e4268c472c0b2b94748a59d6ef866d%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%20%3D%20%22HEAD%3A0a73d1bdd7713a6189482e463c98043c9939a2a2%22%3CBR%20%2F%3E%20meta-freescale-3rdparty%20%3D%20%22HEAD%3A7725256e3859b62f1ff201db7f2cf7026c17656d%22%3CBR%20%2F%3E%20meta-freescale-distro%20%3D%20%22HEAD%3A4f1f101ebab5eb054bfbed10b247fc0547b30793%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF-imx-bsp%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BFimx-sdk%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BFimx-ml%3CBR%20%2F%3E%20meta-imx-v2x%20%3D%20%22HEAD%3A773c0049c3b35af8f5b5bdf8da78a6236a4fc184%22%3CBR%20%2F%3E%20meta-nxp-demo-experience%20%3D%20%22HEAD%3Adb34fa86ad5f3c0d9c0a6c68f5f20240c04f2bfb%26amp%3BBR%3CBR%20%2F%3E%20%2F%26gt%3Bmeta-Arm%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%82%A2%E3%83%BC%E3%83%A0%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%20%3D%20%22HEAD%3A4d22f982bce8dff6f8c4d11845c47a4d39f961c6%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%82%AF%E3%83%AD%E3%83%9F%E3%82%A6%E3%83%A0%20%3D%20%22HEAD%3Adc31889c0899971def535dc1c040edf18bc16691%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF-clang%20%3D%20%22HEAD%3A9b08495e6bcef524789aefb6a7cc80fdfd2ff409%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%8E%E3%83%BC%E3%83%A0%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AD%E3%83%B3%E3%82%B0%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%3D%20%22HEAD%3A1750c66ae8e4268c472c0b2b94748a59d6ef866d%22%3CBR%20%2F%3E%20meta-qt6%20%3D%20%22HEAD%3Afd054cf5fc1b50d50cd606384ab338c6d9206437%22%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BF%E3%83%91%E3%83%BC%E3%82%BB%E3%82%AF%3CBR%20%2F%3E%20%E3%83%A1%E3%82%BFtpm%20%3D%20%22HEAD%3A070a1e82cc59424d230a23c0b2a104b01fbaa2ad%22%3CBR%20%2F%3E%20meta-%E4%BB%AE%E6%83%B3%E5%8C%96%20%3D%20%22HEAD%3A9e92984ff47b3ca2106b1d27a93af061b28d1e8a%22%3C%2FP%3E%3CP%3E%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%3A%20100%25%20%7C%23%20...%7C%20%E6%99%82%E9%96%93%3A%200%3A00%3A19%3CBR%20%2F%3E%20Sstate%20%E3%81%AE%E6%A6%82%E8%A6%81%3A%20%E5%B8%8C%E6%9C%9B%207008%20%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%200%20%E3%83%9F%E3%83%A9%E3%83%BC%200%20%E6%AC%A0%E8%90%BD%207008%20%E7%8F%BE%E5%9C%A8%201122%20(%E4%B8%80%E8%87%B4%E7%8E%87%200%25%E3%80%81%E5%AE%8C%E4%BA%86%E7%8E%87%2013%25)%3CBR%20%2F%3E%E6%B3%A8%E8%A8%98%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E5%AE%9F%E8%A1%8C%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%3A%20llvm-project-source-17.0.6-17.0.6-r0%20do_fetch%3A%20URL%20git%3A%2F%2Fgithub.com%2Fllvm%2Fllvm-project%3Bprotocol%3Dhttps%3Bbranch%3Drelease%2F17.x%20%E3%81%AE%E5%8F%96%E5%BE%97%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E3%83%9F%E3%83%A9%E3%83%BC%E3%82%92%E8%A9%A6%E3%81%BF%E3%82%8B%3CBR%20%2F%3E%E6%B3%A8%3A%2030%20%E7%A7%92%E4%BB%A5%E5%86%85%E3%81%AB%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%8B%E3%82%89%E3%81%AE%E5%BF%9C%E7%AD%94%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%20(%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20ping%20%E3%81%AF%2001%3A48%3A27.402426%20%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F)%3CBR%20%2F%3EBitbake%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%8B%E3%82%89%E3%81%AE%E5%BF%9C%E7%AD%94%E3%82%92%E5%BE%85%E6%A9%9F%E4%B8%AD%E3%81%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20(01%3A48%3A57.437217%20%E3%81%A7%2060%20%E7%A7%92)%3CBR%20%2F%3Edasmiddepogu%40dasmiddepogu-ThinkPad-L14-Gen-1%3A~%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-yocto-bsp%2Fbuild%24%20ps%3CBR%20%2F%3E%20PID%20TTY%20%E6%99%82%E9%96%93%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3CBR%20%2F%3E2919%20%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%2F0%2000%3A00%3A00%20%E3%83%90%E3%83%83%E3%82%B7%E3%83%A5%3CBR%20%2F%3E213920%20%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%2F0%2000%3A00%3A00%20ps%3CBR%20%2F%3E%20%3CA%20href%3D%22mailto%3Adasmiddepogu%40dasmiddepogu-ThinkPad-L14-Gen-1%3A~%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-yocto-bsp%2Fbuild%24%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Edasmiddepogu%40dasmiddepogu-ThinkPad-L14-Gen-1%3A~%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-yocto-bsp%2Fbuild%24%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%83%80%E3%82%B9%E3%83%BB%E3%83%9F%E3%83%87%E3%83%9D%E3%82%B0%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2149634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20IMX8%20%20Plus%20%22Creating%20the%20BSP%20and%20Yocto%20build%20environment%22%20%20compile%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2149634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E3%80%81Bitbake%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%83%8F%E3%83%B3%E3%82%B0%E3%81%97%E3%81%9F%20Bitbake%20%E3%83%87%E3%83%BC%E3%83%A2%E3%83%B3%E3%81%BE%E3%81%9F%E3%81%AF%E6%AE%8B%E3%81%A3%E3%81%9F%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%92%E5%BC%B7%E5%88%B6%E7%B5%82%E4%BA%86%E3%81%97%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AE%E4%B8%8B%E3%81%AE%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%83%AD%E3%83%83%E3%82%AF%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%B6%88%E5%8E%BB%E3%81%97%E3%81%A6%E3%83%9B%E3%82%B9%E3%83%88%E3%82%92%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%8B%E3%82%89%E3%80%81%E5%86%8D%E5%BA%A6%E3%80%8C%20%3CSPAN%3Ebitbake%20imx-image-full%20-c%20populate_sdk%3C%2FSPAN%3E%20%E3%80%8D%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6CAN%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EHarvey%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2149497%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20IMX8%20%20Plus%20%22Creating%20the%20BSP%20and%20Yocto%20build%20environment%22%20%20compile%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2149497%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81NXP%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%BE%E3%81%9F%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%A0%E3%83%93%E3%83%AB%E3%83%89%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%E3%80%8C%E6%B3%A8%3A%20Bitbake%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AB%E5%86%8D%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%E3%80%8D...%20%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%AD%E3%82%B0%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF(%20%3CA%20href%3D%22https%3A%2F%2Fdocs.nxp.com%2Fbundle%2FAN13712%2Fpage%2Ftopics%2Fcreate_the_yocto_build_environment.html)%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fdocs.nxp.com%2Fbundle%2FAN13712%2Fpage%2Ftopics%2Fcreate_the_yocto_build_environment.html)%3C%2FA%3E%E3%81%8B%E3%82%89%E7%A7%81%E3%81%8C%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%9F%E6%89%8B%E9%A0%86%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%8A%E5%BE%8C%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E9%80%B2%E3%82%81%E3%81%A6%E3%81%84%E3%81%8F%E3%81%B9%E3%81%8D%E3%81%8B%E3%81%94%E6%8F%90%E6%A1%88%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E**************************************%E3%83%93%E3%83%AB%E3%83%89%E3%83%AD%E3%82%B0********************************************%3C%2FP%3E%3CP%3Edasmiddepogu%40dasmiddepogu-ThinkPad-L14-Gen-1%3A~%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-Yocto-bsp%2Fbuild%24%3CBR%20%2F%3E%20dasmiddepogu%40dasmiddepogu-ThinkPad-L14-Gen-1%3A~%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-Yocto-bsp%2Fbuild%24%20bitbake%20imx-image-full%20-c%20populate_sdk%3CBR%20%2F%3E%E6%B3%A8%3A%20Bitbake%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AB%E5%86%8D%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%E6%B3%A8%3A%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E6%8E%A5%E7%B6%9A%E3%82%92%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20(%231)...%20(%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%90%E3%83%83%E3%82%AF%20(%E6%9C%80%E5%BE%8C%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%8C%E6%9C%80%E5%BE%8C)%3A%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fdasmiddepogu%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-Yocto-bsp%2Fsources%2Fpoky%2Fbitbake%2Flib%2Fbb%2Fmain.py%E3%80%8D%E3%80%81%E8%A1%8C%E7%95%AA%E5%8F%B7%20487%E3%80%81setup_bitbake%3CBR%20%2F%3E%20server_connection%20%3D%20bb.server.process.connectProcessServer(sockname%2C%E6%A9%9F%E8%83%BD%E3%82%BB%E3%83%83%E3%83%88%EF%BC%89%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fdasmiddepogu%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-Yocto-bsp%2Fsources%2Fpoky%2Fbitbake%2Flib%2Fbb%2Fserver%2Fprocess.py%E3%80%8D%E3%80%81%E8%A1%8C%E7%95%AA%E5%8F%B7686%E3%80%81connectProcessServer%3CBR%20%2F%3E%20sock.connect(os.path.basename(sockname))%3CBR%20%2F%3EBlockingIOError%3A%20%5BErrno%2011%5D%20%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8C%E4%B8%80%E6%99%82%E7%9A%84%E3%81%AB%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%80%8108%3A00%3A49.857906)%3CBR%20%2F%3E%E6%B3%A8%3A%20Bitbake%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AB%E5%86%8D%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%E6%B3%A8%3A%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E6%8E%A5%E7%B6%9A%E3%82%92%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20(%232)...%20(%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%90%E3%83%83%E3%82%AF%20(%E6%9C%80%E5%BE%8C%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%8C%E6%9C%80%E5%BE%8C)%3A%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fdasmiddepogu%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-Yocto-bsp%2Fsources%2Fpoky%2Fbitbake%2Flib%2Fbb%2Fmain.py%E3%80%8D%E3%80%81%E8%A1%8C%E7%95%AA%E5%8F%B7%20487%E3%80%81setup_bitbake%3CBR%20%2F%3E%20server_connection%20%3D%20bb.server.process.connectProcessServer(sockname%2C%E6%A9%9F%E8%83%BD%E3%82%BB%E3%83%83%E3%83%88%EF%BC%89%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fdasmiddepogu%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-Yocto-bsp%2Fsources%2Fpoky%2Fbitbake%2Flib%2Fbb%2Fserver%2Fprocess.py%E3%80%8D%E3%80%81%E8%A1%8C%E7%95%AA%E5%8F%B7686%E3%80%81connectProcessServer%3CBR%20%2F%3E%20sock.connect(os.path.basename(sockname))%3CBR%20%2F%3EBlockingIOError%3A%20%5BErrno%2011%5D%20%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8C%E4%B8%80%E6%99%82%E7%9A%84%E3%81%AB%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%80%8108%3A00%3A49.858338)%3CBR%20%2F%3E%E6%B3%A8%3A%20Bitbake%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AB%E5%86%8D%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%E6%B3%A8%3A%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E6%8E%A5%E7%B6%9A%E3%82%92%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20(%233)...%20(%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%90%E3%83%83%E3%82%AF%20(%E6%9C%80%E5%BE%8C%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%8C%E6%9C%80%E5%BE%8C)%3A%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fdasmiddepogu%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-Yocto-bsp%2Fsources%2Fpoky%2Fbitbake%2Flib%2Fbb%2Fmain.py%E3%80%8D%E3%80%81%E8%A1%8C%E7%95%AA%E5%8F%B7%20487%E3%80%81setup_bitbake%3CBR%20%2F%3E%20server_connection%20%3D%20bb.server.process.connectProcessServer(sockname%2C%E6%A9%9F%E8%83%BD%E3%82%BB%E3%83%83%E3%83%88%EF%BC%89%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fdasmiddepogu%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-Yocto-bsp%2Fsources%2Fpoky%2Fbitbake%2Flib%2Fbb%2Fserver%2Fprocess.py%E3%80%8D%E3%80%81%E8%A1%8C%E7%95%AA%E5%8F%B7686%E3%80%81connectProcessServer%3CBR%20%2F%3E%20sock.connect(os.path.basename(sockname))%3CBR%20%2F%3EBlockingIOError%3A%20%5BErrno%2011%5D%20%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8C%E4%B8%80%E6%99%82%E7%9A%84%E3%81%AB%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%80%8108%3A00%3A49.858697)%3CBR%20%2F%3E%E6%B3%A8%3A%20Bitbake%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AB%E5%86%8D%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%E6%B3%A8%3A%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E6%8E%A5%E7%B6%9A%E3%82%92%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20(%234)...%20(%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%90%E3%83%83%E3%82%AF%20(%E6%9C%80%E5%BE%8C%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%8C%E6%9C%80%E5%BE%8C)%3A%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fdasmiddepogu%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-Yocto-bsp%2Fsources%2Fpoky%2Fbitbake%2Flib%2Fbb%2Fmain.py%E3%80%8D%E3%80%81%E8%A1%8C%E7%95%AA%E5%8F%B7%20487%E3%80%81setup_bitbake%3CBR%20%2F%3E%20server_connection%20%3D%20bb.server.process.connectProcessServer(sockname%2C%E6%A9%9F%E8%83%BD%E3%82%BB%E3%83%83%E3%83%88%EF%BC%89%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fdasmiddepogu%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-Yocto-bsp%2Fsources%2Fpoky%2Fbitbake%2Flib%2Fbb%2Fserver%2Fprocess.py%E3%80%8D%E3%80%81%E8%A1%8C%E7%95%AA%E5%8F%B7686%E3%80%81connectProcessServer%3CBR%20%2F%3E%20sock.connect(os.path.basename(sockname))%3CBR%20%2F%3EBlockingIOError%3A%20%5BErrno%2011%5D%20%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8C%E4%B8%80%E6%99%82%E7%9A%84%E3%81%AB%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%80%8108%3A00%3A49.859044)%3CBR%20%2F%3E%E6%B3%A8%3A%20Bitbake%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AB%E5%86%8D%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%E6%B3%A8%3A%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E6%8E%A5%E7%B6%9A%E3%82%92%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20(%235)...%20(%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%90%E3%83%83%E3%82%AF%20(%E6%9C%80%E5%BE%8C%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%8C%E6%9C%80%E5%BE%8C)%3A%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fdasmiddepogu%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-yocto-bsp%2Fsources%2Fpoky%2Fbitbake%2Flib%2Fbb%2Fmain.py%E3%80%8D%E3%80%81%E8%A1%8C%E7%95%AA%E5%8F%B7%20487%E3%80%81setup_bitbake%3CBR%20%2F%3E%20server_connection%20%3D%20bb.server.process.connectProcessServer(sockname%2C%E6%A9%9F%E8%83%BD%E3%82%BB%E3%83%83%E3%83%88%EF%BC%89%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fdasmiddepogu%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-Yocto-bsp%2Fsources%2Fpoky%2Fbitbake%2Flib%2Fbb%2Fserver%2Fprocess.py%E3%80%8D%E3%80%81%E8%A1%8C%E7%95%AA%E5%8F%B7686%E3%80%81connectProcessServer%3CBR%20%2F%3E%20sock.connect(os.path.basename(sockname))%3CBR%20%2F%3EBlockingIOError%3A%20%5BErrno%2011%5D%20%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8C%E4%B8%80%E6%99%82%E7%9A%84%E3%81%AB%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%80%8108%3A00%3A54.865054)%3CBR%20%2F%3E%E6%B3%A8%3A%20Bitbake%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AB%E5%86%8D%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%E6%B3%A8%3A%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E6%8E%A5%E7%B6%9A%E3%82%92%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20(%236)...%20(%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%90%E3%83%83%E3%82%AF%20(%E6%9C%80%E5%BE%8C%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%8C%E6%9C%80%E5%BE%8C)%3A%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fdasmiddepogu%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-Yocto-bsp%2Fsources%2Fpoky%2Fbitbake%2Flib%2Fbb%2Fmain.py%E3%80%8D%E3%80%81%E8%A1%8C%E7%95%AA%E5%8F%B7%20487%E3%80%81setup_bitbake%3CBR%20%2F%3E%20server_connection%20%3D%20bb.server.process.connectProcessServer(sockname%2C%E6%A9%9F%E8%83%BD%E3%82%BB%E3%83%83%E3%83%88%EF%BC%89%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fdasmiddepogu%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-Yocto-bsp%2Fsources%2Fpoky%2Fbitbake%2Flib%2Fbb%2Fserver%2Fprocess.py%E3%80%8D%E3%80%81%E8%A1%8C%E7%95%AA%E5%8F%B7686%E3%80%81connectProcessServer%3CBR%20%2F%3E%20sock.connect(os.path.basename(sockname))%3CBR%20%2F%3EBlockingIOError%3A%20%5BErrno%2011%5D%20%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8C%E4%B8%80%E6%99%82%E7%9A%84%E3%81%AB%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%80%8108%3A00%3A59.870058)%3CBR%20%2F%3E%E6%B3%A8%3A%20Bitbake%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AB%E5%86%8D%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%E6%B3%A8%3A%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E6%8E%A5%E7%B6%9A%E3%82%92%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20(%237)...%20(%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%90%E3%83%83%E3%82%AF%20(%E6%9C%80%E5%BE%8C%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%8C%E6%9C%80%E5%BE%8C)%3A%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fdasmiddepogu%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-Yocto-bsp%2Fsources%2Fpoky%2Fbitbake%2Flib%2Fbb%2Fmain.py%E3%80%8D%E3%80%81%E8%A1%8C%E7%95%AA%E5%8F%B7%20487%E3%80%81setup_bitbake%3CBR%20%2F%3E%20server_connection%20%3D%20bb.server.process.connectProcessServer(sockname%2C%E6%A9%9F%E8%83%BD%E3%82%BB%E3%83%83%E3%83%88%EF%BC%89%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fdasmiddepogu%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-Yocto-bsp%2Fsources%2Fpoky%2Fbitbake%2Flib%2Fbb%2Fserver%2Fprocess.py%E3%80%8D%E3%80%81%E8%A1%8C%E7%95%AA%E5%8F%B7686%E3%80%81connectProcessServer%3CBR%20%2F%3E%20sock.connect(os.path.basename(sockname))%3CBR%20%2F%3EBlockingIOError%3A%20%5BErrno%2011%5D%20%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8C%E4%B8%80%E6%99%82%E7%9A%84%E3%81%AB%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%80%8108%3A01%3A04.877760)%3CBR%20%2F%3E%E6%B3%A8%3A%20Bitbake%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AB%E5%86%8D%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%E6%B3%A8%3A%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E6%8E%A5%E7%B6%9A%E3%82%92%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20(%238)...%20(%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%90%E3%83%83%E3%82%AF%20(%E6%9C%80%E5%BE%8C%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%8C%E6%9C%80%E5%BE%8C)%3A%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fdasmiddepogu%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-Yocto-bsp%2Fsources%2Fpoky%2Fbitbake%2Flib%2Fbb%2Fmain.py%E3%80%8D%E3%80%81%E8%A1%8C%E7%95%AA%E5%8F%B7%20487%E3%80%81setup_bitbake%3CBR%20%2F%3E%20server_connection%20%3D%20bb.server.process.connectProcessServer(sockname%2C%E6%A9%9F%E8%83%BD%E3%82%BB%E3%83%83%E3%83%88%EF%BC%89%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8C%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fdasmiddepogu%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-Yocto-bsp%2Fsources%2Fpoky%2Fbitbake%2Flib%2Fbb%2Fserver%2Fprocess.py%E3%80%8D%E3%80%81%E8%A1%8C%E7%95%AA%E5%8F%B7686%E3%80%81connectProcessServer%3CBR%20%2F%3E%20sock.connect(os.path.basename(sockname))%3CBR%20%2F%3EBlockingIOError%3A%20%5BErrno%2011%5D%20%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8C%E4%B8%80%E6%99%82%E7%9A%84%E3%81%AB%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%80%8108%3A01%3A09.884445)%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20bitbake%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%8B%E3%80%81%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%20(%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AE%E8%B5%B7%E5%8B%95%E3%81%AE%E5%A4%B1%E6%95%97%E3%81%AF%20bitbake-cookerdaemon.log%20%E3%81%AB%E8%A8%98%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99)%E3%80%82%3CBR%20%2F%3Edasmiddepogu%40dasmiddepogu-ThinkPad-L14-Gen-1%3A~%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-yocto-bsp%2Fbuild%24%3C%2FP%3E%3CP%3E**************************************************************%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%80%E3%82%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2141752%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20IMX8%20%20Plus%20%22Creating%20the%20BSP%20and%20Yocto%20build%20environment%22%20%20compile%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2141752%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F251894%22%20target%3D%22_blank%22%3E%40middepogudas%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EBSP(6.6.3)%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AFi.MX8MP%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DL6.6.3_1.0.0_Docs%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EDocs%3C%2FA%3E%E3%81%8B%E3%82%89Yocto%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%20%3CLI-EMOJI%20id%3D%22lia_red-heart%22%20title%3D%22%3Ared_heart%3A%22%3E%3C%2FLI-EMOJI%3E%20%E3%83%9B%E3%82%B9%E3%83%88%E8%A8%AD%E5%AE%9A%26gt%3B%20Ubuntu%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%20(20.04%2F22.04%20%E3%82%92%E6%8E%A8%E5%A5%A8)%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%26lt%3B3.2%E3%83%9B%E3%82%B9%E3%83%88%20%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%26gt%3B%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EHarvey%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
