NXP IMX8 Plus "Creating the BSP and Yocto build environment" compile issue
2,090 次查看
middepogudas
Hi NXP,
Thanks for this form. I am trying to download and build the BSP source code for "I.MX 8M Plus" target.
1. I am referring  this to download and build BSP code "https://docs.nxp.com/bundle/AN13712/page/topics/module_and_board.html"
2. Please find host PC info:
$ uname -a
Linux das-ThinkPad-L14-Gen-1 6.14.0-24-generic #24-Ubuntu SMP PREEMPT_DYNAMIC Sun Jun 15 11:18:07 UTC 2025 x86_64 x86_64 x86_64 GNU/Linux
3. Build and env settings:
das@das-ThinkPad-L14-Gen-1:~$ DISTRO=fsl-imx-xwayland MACHINE=imx8mp-lpddr4-evk source imx-setup-release.sh -b build
das@das-ThinkPad-L14-Gen-1:~$ bitbake imx-image-full -c populate_sdk
das@das-ThinkPad-L14-Gen-1:~/Desktop/das/NXP/Project/nxpevb/imx-yocto-bsp/build$ bitbake imx-image-full -c populate_sdk
das@das-ThinkPad-L14-Gen-1:~/Desktop/das/NXP/Project/nxpevb/imx-yocto-bsp/build$ sudo apt install gawk wget git diffstat unzip texinfo gcc build-essential chrpath socat cpio python3 python3-pip python3-pexpect xz-utils debianutils iputils-ping python3-git python3-jinja2 python3-subunit zstd liblz4-tool file locales libacl1
das@das-ThinkPad-L14-Gen-1:~/Desktop/das/NXP/Project/nxpevb/imx-yocto-bsp/build$ sudo apt install gawk wget git diffstat unzip texinfo gcc build-essential chrpath socat cpio python3 python3-pip python3-pexpect xz-utils debianutils iputils-ping python3-git python3-jinja2 libegl1-mesa libsdl1.2-dev python3-subunit mesa-common-dev zstd liblz4-tool file locales -y
das@das-ThinkPad-L14-Gen-1:~sudo apt install gawk wget git diffstat unzip texinfo gcc build-essential chrpath socat cpio python3 python3-pip python3-pexpect xz-utils debianutils iputils-ping python3-git python3-jinja2 python3-subunit zstd liblz4-tool file locales libacl1
das@das-ThinkPad-L14-Gen-1:~/Desktop/das/NXP/Project/nxpevb/imx-yocto-bsp/build$ sudo apparmor_parser -R /etc/apparmor.d/unprivileged_userns
das@das-ThinkPad-L14-Gen-1:~/Desktop/das/NXP/Project/nxpevb/imx-yocto-bsp/build$ sudo locale-gen en_US.UTF-8
4. build error:
WARNING: Host distribution "ubuntu-25.04" has not been validated with this version of the build system; you may possibly experience unexpected failures. It is recommended that you use a tested distribution.
Loading cache: 100% |####################################################################################################################################################| Time: 0:00:02
Loaded 5449 entries from dependency cache.
NOTE: Resolving any missing task queue dependencies
WARNING: preferred version 17.0.6 of llvm-native not available (for item llvm-native)
WARNING: versions of llvm-native available: 17.0.3
Build Configuration:
BB_VERSION = "2.6.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "ubuntu-25.04"
TARGET_SYS = "aarch64-poky-linux"
MACHINE = "imx8mp-lpddr4-evk"
DISTRO = "fsl-imx-xwayland"
DISTRO_VERSION = "6.6-nanbield"
TUNE_FEATURES = "aarch64 armv8a crc crypto"
TARGET_FPU = ""
meta
meta-poky = "HEAD:046b70083f3bc9e25f547e8026400032f5c563d9"
meta-oe
meta-multimedia
meta-python = "HEAD:1750c66ae8e4268c472c0b2b94748a59d6ef866d"
meta-freescale = "HEAD:0a73d1bdd7713a6189482e463c98043c9939a2a2"
meta-freescale-3rdparty = "HEAD:7725256e3859b62f1ff201db7f2cf7026c17656d"
meta-freescale-distro = "HEAD:4f1f101ebab5eb054bfbed10b247fc0547b30793"
meta-imx-bsp
meta-imx-sdk
meta-imx-ml
meta-imx-v2x = "HEAD:773c0049c3b35af8f5b5bdf8da78a6236a4fc184"
meta-nxp-demo-experience = "HEAD:db34fa86ad5f3c0d9c0a6c68f5f20240c04f2bfb"
meta-arm
meta-arm-toolchain = "HEAD:4d22f982bce8dff6f8c4d11845c47a4d39f961c6"
meta-chromium = "HEAD:dc31889c0899971def535dc1c040edf18bc16691"
meta-clang = "HEAD:9b08495e6bcef524789aefb6a7cc80fdfd2ff409"
meta-gnome
meta-networking
meta-filesystems = "HEAD:1750c66ae8e4268c472c0b2b94748a59d6ef866d"
meta-qt6 = "HEAD:fd054cf5fc1b50d50cd606384ab338c6d9206437"
meta-parsec
meta-tpm = "HEAD:070a1e82cc59424d230a23c0b2a104b01fbaa2ad"
meta-virtualization = "HEAD:9e92984ff47b3ca2106b1d27a93af061b28d1e8a"
WARNING: Your host glibc version (2.41) is newer than that in uninative (2.38). Disabling uninative so that sstate is not corrupted.
Initialising tasks: 100% |###############################################################################################################################################| Time: 0:00:11
Sstate summary: Wanted 7712 Local 0 Mirrors 0 Missed 7712 Current 142 (0% match, 1% complete)
NOTE: Executing Tasks
ERROR: pseudo-native-1.9.0+git-r0 do_compile: ExecutionError('/home/das/Desktop/das/NXP/Project/nxpevb/imx-yocto-bsp/build/tmp/work/x86_64-linux/pseudo-native/1.9.0+git/temp/run.do_compile.28961', 1, None, None)
ERROR: Logfile of failure stored in: /home/das/Desktop/das/NXP/Project/nxpevb/imx-yocto-bsp/build/tmp/work/x86_64-linux/pseudo-native/1.9.0+git/temp/log.do_compile.28961
Log data follows:
| DEBUG: Executing shell function do_compile
| NOTE: Building/installing only 64-bit libpseudo.so for pseudo-native.
| NOTE: If you need to run 32-bit executables, ensure that NO32LIBS is set to 0.
| SQLite header for version 3043001 found in /home/das/Desktop/das/NXP/Project/nxpevb/imx-yocto-bsp/build/tmp/work/x86_64-linux/pseudo-native/1.9.0+git/recipe-sysroot-native/usr.
| Enabling in-memory database by default.
| NOTE: make -j 4 RPATH=-Wl,--rpath=XORIGIN/../../../sqlite3-native/usr/lib/
| make: Nothing to be done for 'all'.
| WARNING: exit code 1 from a shell command.
ERROR: Task (virtual:native:/home/das/Desktop/das/NXP/Project/nxpevb/imx-yocto-bsp/sources/poky/meta/recipes-devtools/pseudo/pseudo_git.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 359 tasks of which 358 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 4 WARNING messages.
Summary: There was 1 ERROR message, returning a non-zero exit code.
Can you please get back how to resolve this BSP and Yacto build issue;
Das
16 回复数
1,597 次查看
middepogudas
NXP ,
Can you help on this :
dasmiddepogu@dasmiddepogu-ThinkPad-L13-Yoga-Gen-3:~/Desktop/das/project/imx-yocto-bsp/build$ bitbake core-image-minimal
Loading cache: 100% |#######################################################################################################################################################################| Time: 0:00:01
NATIVELSBSTRING = "universal"
TARGET_FPU = ""
meta
meta-oe
meta-multimedia
meta-imx-bsp
meta-imx-sdk
meta-imx-ml
meta-arm
meta-gnome
meta-networking
meta-parsec
Initialising tasks: 100% |##################################################################################################################################################################| Time: 0:00:02
Sstate summary: Wanted 1103 Local 2 Mirrors 0 Missed 1101 Current 1686 (0% match, 60% complete)
ERROR: openssl-3.1.4-r0 do_compile: oe_runmake failed
ERROR: openssl-3.1.4-r0 do_compile: ExecutionError('/home/dasmiddepogu/Desktop/das/project/imx-yocto-bsp/build/tmp/work/armv8a-poky-linux/openssl/3.1.4/temp/run.do_compile.14161', 1, None, None)
ERROR: Logfile of failure stored in: /home/dasmiddepogu/Desktop/das/project/imx-yocto-bsp/build/tmp/work/armv8a-poky-linux/openssl/3.1.4/temp/log.do_compile.14161
Log data follows:
| NOTE: make -j 12
ERROR: Task (/home/dasmiddepogu/Desktop/das/project/imx-yocto-bsp/sources/poky/meta/recipes-connectivity/openssl/openssl_3.1.4.bb:do_compile) failed with exit code '1'
Waiting for 11 running tasks to finish:
0: qemu-native-8.1.2-r0 do_compile - 45s (pid 14162)
1: linux-imx-6.6.3+git-r0 do_fetch - 45s (pid 14185) | <=> |
2: rust-llvm-native-1.70.0-r0 do_compile - 45s (pid 14195) 0% | |
3: icu-73-2-r0 do_compile - 44s (pid 14317)
4: perl-5.38.0-r0 do_compile - 43s (pid 14323)
5: util-linux-2.39.2-r0 do_package - 43s (pid 14318)
6: libical-native-3.0.16-r0 do_compile - 43s (pid 14321) 36% |################################################### |
7: bash-5.2.15-r0 do_configure - 43s (pid 1432^C
Das
1,525 次查看
Harvey021
The causes for OE_RUNMAKE error can be various. Insufficient DDR can be one.
Make sure that your build Host is set well as required, except for the hardware resources as mentioned.
Harvey
1,597 次查看
middepogudas
NXP,
can you help below error:
dasmiddepogu@dasmiddepogu-ThinkPad-L13-Yoga-Gen-3:~/Desktop/das/project/imx-yocto-bsp/build$ bitbake -c cleansstate openssl
dasmiddepogu@dasmiddepogu-ThinkPad-L13-Yoga-Gen-3:~/Desktop/das/project/imx-yocto-bsp/build$ bitbake openssl
Loading cache: 100% |#######################################################################################################################################################################| Time: 0:00:00
TARGET_FPU = ""
meta
meta-oe
meta-multimedia
meta-imx-bsp
meta-imx-sdk
meta-imx-ml
meta-arm
meta-gnome
meta-networking
meta-parsec
Initialising tasks: 100% |##################################################################################################################################################################| Time: 0:00:00
Sstate summary: Wanted 100 Local 0 Mirrors 0 Missed 100 Current 616 (0% match, 86% complete)
NOTE: No reply from server in 30s (for command ping at 05:13:49.520202)
Timeout while waiting for a reply from the bitbake server (60s at 05:14:19.561139)
i am holding host pc with  1TB memory , 8GB RAM, 10 CPU core..
ThinkPad-L13-Yoga-Gen-3 5.15.0-139-generic #149~20.04.1-Ubuntu SMP Wed Apr 16 08:29:56 UTC 2025 x86_64 x86_64 x86_64 GNU/Linux
Das
1,834 次查看
middepogudas
Hi NXP,
Most of the times i am facing issue of bitbake server connectivity while build these images(fsl-image-machine-
test, imx-image-multimedia, imx-image-full) but its ok to build for these images(imx-image-core,core-image-base).
While build these images (fsl-image-machine-test, imx-image-multimedia, imx-image-full) its build for for Vulkan and OpenCV lib, which is unable to build by bitbake server. Do you have any other document how to optimize to build  bitback for Vulkan and OpenCV?
I am holding 4 CPU cores Inter processor.
Can you please  help on this issue?
Please find the logs as below:
******************Logs***********************
NOTE: Your conf/bblayers.conf has been automatically updated.
TARGET_FPU = ""
meta
meta-oe
meta-multimedia
meta-imx-bsp
meta-imx-sdk
meta-imx-ml
meta-arm
meta-gnome
meta-networking
meta-parsec
Initialising tasks: 100% |##################################################################################################################################################################| Time: 0:00:08
Sstate summary: Wanted 1071 Local 2 Mirrors 0 Missed 1069 Current 5652 (0% match, 84% complete)
NOTE: No reply from server in 30s (for command ping at 22:27:39.389536)
Timeout while waiting for a reply from the bitbake server (60s at 22:28:09.428551)
middepogudas@middepogudas-ThinkPad-L14-Gen-1:~/Desktop/das/project/imx-yocto-bsp/build$ bitbake imx-image-multimedia
NOTE: Reconnecting to bitbake server...
NOTE: No reply from server in 30s (for command setFeatures at 22:28:45.138306)
NOTE: Retrying server connection (#1)... (22:29:15.167756)
Das
1,773 次查看
Harvey021
Your build system doesn't seem to meet the requirements for this build. Here are some configuration recommendations from Yocto.
 Yocto Project Quick Build — The Yocto Project ® 5.2.2 documentation
  • At least 8 Gbytes of RAM, though a modern build host with as much RAM and as many CPU cores as possible is strongly recommended to maximize build performance.
Other recommendations: if you have 4 CPU cores, at least 16GB of RAM is needed. A 1:4 ratio is as follows. You can also refer to https://docs.yoctoproject.org/dev-manual/speeding-up-build.html
If you're building a full image, at least 250GB of disk space required.
I just test the same on my host: 22.04.1-Ubuntu
Loading cache: 100% |##################################################################################################################| Time: 0:00:01
TARGET_FPU = ""
meta
meta-oe
meta-multimedia
meta-imx-bsp
meta-imx-sdk
meta-imx-ml
meta-arm
meta-gnome
meta-networking
meta-parsec
Initialising tasks: 100% |#############################################################################################################| Time: 0:00:06
Sstate summary: Wanted 3349 Local 0 Mirrors 0 Missed 3349 Current 4781 (0% match, 58% complete)
NOTE: Tasks Summary: Attempted 17993 tasks of which 13736 didn't need to be rerun and all succeeded.
Summary: There were 2 WARNING messages.
Harvey
1,720 次查看
middepogudas
Hello NXP.
Thanks for your support. I am holding 4 CPU, 1TB HDD, 8GB RAM. As per your recommendation i can give a try to increase my RAM to 16 GB+ .
I am trying to build for "MACHINE = "imx8mp-lpddr4-evk""
As per my observation build summery as below:
Able to build :
bitbake imx-image-core
Unable to build:
bitbake fsl-image-machine-test
So from above configure i observe that when ever try to build the "opencv" and "vulkan" i am getting bitbake server connectivity issue. We have any build option where we can comment  or skip the building("opencv" and "vulkan") and proceed further?
Can you please point-out build script name and where to comment to skip the build for opencv" and "vulkan" ?
Das
标记 (1)
1,712 次查看
Harvey021
These applications are the main components of the full/multimedia image. Instead of skipping the building of these applications, it is better to directly build the imx-image-core. As mentioned, to upgrade your build host.
Harvey
1,707 次查看
middepogudas
Hello NXP,
While build the below configuration (bitbake fsl-image-machine-test, bitbake imx-image-multimedia, bitbake imx-image-full), is it possible to comment inside build script file for "opencv" or "vulkan" these components for skip the while build? pleas share the file name and where i need to comment the code to skip the build components?
My end goal is to go for full build (bitbake imx-image-full). With above experiment, we can isolate the issue which components causing.
Thank you.
Das
1,679 次查看
Harvey021
It is possible. You can comment the packages from image recipe or get help from Yocto forum. However, this will be another issue. Please raise a new ticket for further assistance if you need. and as said, if such applications/packages are skipped, then to build full/multimedia will be similar to build other smaller image.
Harvey
1,967 次查看
middepogudas
Hi NXP,
Thank for come back on this.Still I am facing some build issue... "NOTE: Reconnecting to bitbake server..." .. Please find logs below
Please find the steps which i follow from this link(https://docs.nxp.com/bundle/AN13712/page/topics/create_the_yocto_build_environment.html)
please suggest how to proceed further.
**********************************build logs***************************************
dasmiddepogu@dasmiddepogu-ThinkPad-L14-Gen-1:~/Desktop/das/project/imax8mpluseek/imx-yocto-bsp/build$
dasmiddepogu@dasmiddepogu-ThinkPad-L14-Gen-1:~/Desktop/das/project/imax8mpluseek/imx-yocto-bsp/build$ bitbake imx-image-full -c populate_sdk
NOTE: Retrying server connection (#1)... (Traceback (most recent call last):
File "/home/dasmiddepogu/Desktop/das/project/imax8mpluseek/imx-yocto-bsp/sources/poky/bitbake/lib/bb/main.py", line 487, in setup_bitbake
server_connection = bb.server.process.connectProcessServer(sockname, featureset)
File "/home/dasmiddepogu/Desktop/das/project/imax8mpluseek/imx-yocto-bsp/sources/poky/bitbake/lib/bb/server/process.py", line 686, in connectProcessServer
sock.connect(os.path.basename(sockname))
BlockingIOError: [Errno 11] Resource temporarily unavailable
, 08:00:49.857906)
NOTE: Retrying server connection (#2)... (Traceback (most recent call last):
, 08:00:49.858338)
NOTE: Retrying server connection (#3)... (Traceback (most recent call last):
, 08:00:49.858697)
NOTE: Retrying server connection (#4)... (Traceback (most recent call last):
, 08:00:49.859044)
NOTE: Retrying server connection (#5)... (Traceback (most recent call last):
, 08:00:54.865054)
NOTE: Retrying server connection (#6)... (Traceback (most recent call last):
, 08:00:59.870058)
NOTE: Retrying server connection (#7)... (Traceback (most recent call last):
, 08:01:04.877760)
NOTE: Retrying server connection (#8)... (Traceback (most recent call last):
, 08:01:09.884445)
ERROR: Unable to connect to bitbake server, or start one (server startup failures would be in bitbake-cookerdaemon.log).
Das
1,940 次查看
Harvey021
The error tells that unable to connect bitbake server, which may be caused by a hung bitbake daemon or leftover socket files. You can try to kill that and clean some lock files under build directory and restart host, then run "bitbake imx-image-full -c populate_sdk" again.
Harvey
1,936 次查看
middepogudas
NXP,
Thanks for come back, Please find build logs pasted below. Still getting bitback server connectivity issue. I restarted my pc several times,. I did not find any bitbake process. Can you pleas share info how to proceed further.
***********************Logs********
Loading cache: 100% |########################################################################################################################################################################| Time: 0:00:01
TARGET_FPU = ""
meta
meta-oe
meta-multimedia
meta-imx-bsp
meta-imx-sdk
meta-imx-ml
meta-arm
meta-gnome
meta-networking
meta-parsec
Initialising tasks: 100% |###################################################################################################################################################################| Time: 0:00:19
Sstate summary: Wanted 7008 Local 0 Mirrors 0 Missed 7008 Current 1122 (0% match, 13% complete)
WARNING: llvm-project-source-17.0.6-17.0.6-r0 do_fetch: Failed to fetch URL git://github.com/llvm/llvm-project;protocol=https;branch=release/17.x, attempting MIRRORS if available
NOTE: No reply from server in 30s (for command ping at 01:48:27.402426)
Timeout while waiting for a reply from the bitbake server (60s at 01:48:57.437217)
dasmiddepogu@dasmiddepogu-ThinkPad-L14-Gen-1:~/Desktop/das/project/imax8mpluseek/imx-yocto-bsp/build$ ps
PID TTY TIME CMD
2919 pts/0 00:00:00 bash
213920 pts/0 00:00:00 ps
dasmiddepogu@dasmiddepogu-ThinkPad-L14-Gen-1:~/Desktop/das/project/imax8mpluseek/imx-yocto-bsp/build...
Das Middepogu
1,933 次查看
Harvey021
Please check your network issue for fetching failure, are there security or proxy arising the issue? also check your Host configure as reference to first reply. can also try to start a new build.
Harvey
1,928 次查看
middepogudas
Hi NXP,
Thanks for your support. Do you have steps or methods to check "security or proxy arising"?
Please help us to share? or guide us.
Das
1,926 次查看
Harvey021
Hi @middepogudas
If your host is in your company network, please check your company network administrator.
Harvey
2,063 次查看
Harvey021
Hi @middepogudas
To build the BSP(6.6.3)source code for i.MX8MP, please follow up the Yocto User Guide download from Docs
Please refer to the section Host Setup> for Ubuntu version (Recommend 20.04/22.04) and the section <3.2 Host packages>.
Harvey
%3CLINGO-SUB%20id%3D%22lingo-sub-2141271%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ENXP%20IMX8%20Plus%20%22%E5%88%9B%E5%BB%BA%20%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%E3%80%82%20%E5%92%8C%20Yocto%20%E7%89%88%E6%9C%AC%20%E7%8E%AF%E5%A2%83%20%22%20%E7%BC%96%E8%AF%91%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2141271%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%81%A9%E6%99%BA%E6%B5%A6%E3%80%81%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E8%BF%99%E4%BB%BD%E8%A1%A8%E6%A0%BC%E3%80%82%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E4%B8%8B%E8%BD%BD%E5%B9%B6%E6%9E%84%E5%BB%BA%20%22%20I.MX%208M%20Plus%20%22%20%E7%9B%AE%E6%A0%87%E7%9A%84%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%E6%BA%90%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E1.%E6%88%91%E6%8C%87%E7%9A%84%E6%98%AF%E4%B8%8B%E8%BD%BD%E5%92%8C%E7%89%88%E6%9C%AC%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%E4%BB%A3%E7%A0%81%20%22%3CA%20href%3D%22https%3A%2F%2Fdocs.nxp.com%2Fbundle%2FAN13712%2Fpage%2Ftopics%2Fmodule_and_board.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fdocs.nxp.com%2Fbundle%2FAN13712%2Fpage%2Ftopics%2Fmodule_and_board.html%22%3C%2FA%3E%E3%80%82%3C%2FP%3E%3CP%3E2.%E8%AF%B7%E6%9F%A5%E6%89%BE%E4%B8%BB%E6%9C%BA%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%24%20uname%20-a%3CBR%20%2F%3ELinux%20das-ThinkPad-L14-Gen-1%206.14.0-24-generic%20%2324-Ubuntu%20SMP%20PREEMPT_DYNAMIC%20Sun%20Jun%2015%2011%3A18%3A07%20UTC%202025%20x86_64%20x86_64%20x86_64%20GNU%2FLinux%3C%2FP%3E%3CP%3E3.%20%E7%89%88%E6%9C%AC%E5%92%8C%E7%8E%AF%E5%A2%83%E8%AE%BE%E7%BD%AE%EF%BC%9A%3C%2FP%3E%3CP%3Edas%20%3Ca%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F31769%22%3E%40das%3C%2Fa%3E-ThinkPad-L14-Gen-1%EF%BC%9A~%24%20%E5%8F%91%E8%A1%8C%E7%89%88%3Dfsl-imx-xwayland%20machine%3Dimx8mp-lpddr4-EVK%20%E6%9D%A5%E6%BA%90%20imx-setup-%E7%89%88%E6%9C%AC.sh-b%20%E7%89%88%E6%9C%AC%20das%20%3Ca%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F31769%22%3E%40das%3C%2Fa%3E-ThinkPad-l14-gen-1%EF%BC%9A~%24%20bitbake%20imx-limage-full-c%20populate_sdk%20das%20%3Ca%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F31769%22%3E%40das%3C%2Fa%3E-Thinkpad-L14-gen-1%EF%BC%9A~%2Fdesktop%2Fdas%2Fnxp%2FProject%2Fnxp%2FProject%2Fnxpevproject%2FnxpevProject%2Fnxpevpject%2Fnxpimx-yocto-%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%2F%E7%89%88%E6%9C%AC%24%20bitbake%20imx-image-full-c%20populate_sdk%20d%20%3CBR%20%2F%3E%20as%20%3Ca%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F31769%22%3E%40das%3C%2Fa%3E-ThinkPad-l14-gen-1%EF%BC%9Adasktop%2Fdask%2Fdas%2Fnxp%2Fproject%2Fnxp%2Fproject%2Fnxp%2F%E7%89%88%E6%9C%AC%24%20sudo%20apt%20%E5%AE%89%E8%A3%85gawk%20wget%20git%20diffstat%20%E8%A7%A3%E5%8E%8Btexinfo%20gcc%20build-essential%20chrpath%20socat%20cpio%20python3%20python3-pip%20python3-pexpect%20xz-%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%40dasutils%20debianutils%20iputils-ping%20python3-git%20python3-jinja2%20python3-subunit%20zstd%20liblz4-tool%20%E6%96%87%E4%BB%B6%E8%AF%AD%E8%A8%80%E7%8E%AF%E5%A2%83%20libacl1%20das%20%3Ca%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F31769%22%3E%40das%3C%2Fa%3E-thinkpad-l14-gen-1%EF%BC%9A~%2Fdesktop%2Fdas%2Fnxp%2Fproject%2Fnxp%2Fproject%2Fnxp%2Fimx-yocto-%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%2F%E7%89%88%E6%9C%AC%24%20sudo%20apt%20install%20git%20git%20diffstat%20unzip%20texzip%20install%20git%20diffstat%20unzip%20texinfo%20gcc%20build-essential%20chrpath%20socat%20cpio%20python3%20pip%20python3-pip%20python3-pexpect%20xz-utils%20debianutils%20iputils-ping%20python3-git%20python3-jinja2%20libegl1-mesa%20libsdl1.%20%3CBR%20%2F%3E%202-devpython3-subunit%20mesa-common-dev%20zstd%20liblz4-tool%20%E6%96%87%E4%BB%B6%E8%AF%AD%E8%A8%80%E7%8E%AF%E5%A2%83-y%20d%20%3CBR%20%2F%3E%20as%20%3Ca%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F31769%22%3E%40das%3C%2Fa%3E-ThinkPad-l14-gen-1%EF%BC%9A~sudo%20apt%20install%20git%20git%20diffstat%20%E8%A7%A3%E5%8E%8Btexinfo%20gcc%20build-essential%20chrpath%20socat%20cpio%20python3-pip%20python3-pip%20xz-utils%20debianutils%20iputils-ping%20python3-git%20python3-git%20python3-git%20python3-git%20python3-git%20python3-git%20python3-git%20pjinja2%20python3-subunit%20zstd%20liblz4%20%E5%B7%A5%E5%85%B7%E6%96%87%E4%BB%B6%E6%9C%AC%E5%9C%B0%E5%8C%96%20libacl1%20das%20%3Ca%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F31769%22%3E%40das%3C%2Fa%3E-ThinkPad-L14-gen-1%EF%BC%9A~%2Fdesktop%2Fdas%2Fnxp%2Fproject%2Fnxp%2Fproject%2Fnxpevb%2Fimx-yocto-bsp%2Fbuild%24%20sudo%20apparmor_parser-R%20%2Fetc%2Fapparmor.d%2Funprivileged_userns%20%3CBR%20%2F%3E%20%3CBR%20%2F%3Edas%20%3Ca%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F31769%22%3E%40das%3C%2Fa%3E-ThinkPad-L14-gen-1%EF%BC%9A~%2Fdesktop%2Fdas%2Fnxp%2FProject%2Fnxp%2Fproject%2Fnxpevb%2Fimx-yocto-%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%2Fbuild%24%20sudo%20locale-gen%20en_US.UTF-8%3C%2FP%3E%3CP%3E%3CSTRONG%3Edas%20%3Ca%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F31769%22%3E%40das%3C%2Fa%3E-ThinkPad-L14-Gen-1%EF%BC%9A~%2Fdesktop%2Fdas%2Fnxp%2FProject%2Fnxpevb%2Fimx-yocto-%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%2Fbuild%24%20bitbake%20imx-image-full-c%20populate_sdk%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E4%E3%80%82%3CSTRONG%3E%E7%89%88%E6%9C%AC%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Edas%20%3Ca%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F31769%22%3E%40das%3C%2Fa%3E-ThinkPad-L14-gen-1%EF%BC%9A~%2Fdesktop%2Fdas%2Fnxp%2FProject%2Fnxpevb%2Fimx-yocto-bsp%2Fbuild%24%20bitbake%20imx-image-full%20%E8%AD%A6%E5%91%8A%EF%BC%9A%E4%B8%BB%E6%9C%BA%E5%88%86%E5%8F%91%20%22%20ubuntu-25.04%20%22%20%3CBR%20%2F%3E%E5%B0%9A%E6%9C%AA%E4%BD%BF%E7%94%A8%E6%AD%A4%E7%89%88%E6%9C%AC%E7%9A%84%E7%BC%96%E8%AF%91%E7%B3%BB%E7%BB%9F%E8%BF%9B%E8%A1%8C%E9%AA%8C%E8%AF%81%EF%BC%9B%E6%82%A8%E5%8F%AF%E8%83%BD%E4%BC%9A%E9%81%87%E5%88%B0%E6%84%8F%E5%A4%96%E6%95%85%E9%9A%9C%E3%80%82%E5%BB%BA%E8%AE%AE%E4%BD%BF%E7%94%A8%E7%BB%8F%E8%BF%87%E6%B5%8B%E8%AF%95%E7%9A%84%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%82%3CBR%20%2F%3E%E5%8A%A0%E8%BD%BD%E7%BC%93%E5%AD%98%EF%BC%9A100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%20%E6%97%B6%E9%97%B4%EF%BC%9A0%3A00%3A02%3CBR%20%2F%3E%E4%BB%8E%E4%BE%9D%E8%B5%96%E5%85%B3%E7%B3%BB%E7%BC%93%E5%AD%98%E4%B8%AD%E5%8A%A0%E8%BD%BD%E4%BA%86%205449%20%E4%B8%AA%E6%9D%A1%E7%9B%AE%E3%80%82%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E8%A7%A3%E5%86%B3%E4%BB%BB%E4%BD%95%E7%BC%BA%E5%A4%B1%E7%9A%84%E4%BB%BB%E5%8A%A1%E9%98%9F%E5%88%97%E4%BE%9D%E8%B5%96%E5%85%B3%E7%B3%BB%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E9%A6%96%E9%80%89%E7%9A%84%20llvm-native%2017.0.6%20%E7%89%88%E6%9C%AC%E4%B8%8D%E5%8F%AF%E7%94%A8%EF%BC%88%E9%92%88%E5%AF%B9%20llvm-native%20%E9%A1%B9%E7%9B%AE%EF%BC%89%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E5%8F%AF%E7%94%A8%E7%9A%84%20llvm-native%20%E7%89%88%E6%9C%AC%EF%BC%9A17.0.3%3C%2FP%3E%3CP%3E%E7%89%88%E6%9C%AC%E9%85%8D%E7%BD%AE%EF%BC%9A%3CBR%20%2F%3EBB_VERSION%20%3D%20%22%202.6.0%20%22%20%3CBR%20%2F%3EBUILD_SYS%20%3D%22x86_64-linux%22%3CBR%20%2F%3E%20NATIVELSBSTRING%20%3D%22ubuntu-25.04%22%3CBR%20%2F%3ETARGET_SYS%20%3D%20%22aarch64-poky-linux%22%3CBR%20%2F%3EMACHINE%20%3D%20%22imx8mp-lpddr4-evk%22%3CBR%20%2F%3E%E5%8F%91%E8%A1%8C%E7%89%88%20%3D%20%22fsl-imx-xwayland%22%3CBR%20%2F%3EDISTRO_VERSION%20%3D%20%226.6-nanbield%22%3CBR%20%2F%3ETUNE_FEATURES%20%3D%20%22%20aarch64%20armv8a%20crcrypto%20%22%20TAR%20%3CBR%20%2F%3E%20GET_FPU%20%3D%20%22%20%22%20meta%20meta-p%20%3CBR%20%2F%3E%20oky%20%3D%20%22%20Head%3A%20046b70083f3f3bc9e25f547e8026400032f563d9%20%22%20meta-oe%20%E5%85%83%E5%A4%9A%E5%AA%92%E4%BD%93%20meta-python%20%3D%20%22%20Head%3A%201750c66ae8e4268c472c0b2b94748AD59AD9c0b2b94748AD59AD%206ef866D%20%22%20%3CBR%20%2F%3E%20meta-freescale%20%3D%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%22%20%E5%A4%B4%3A0a73d1bdd7713a6189482e463c98043c9939a2a2%20%22%20meta-freescale-3rdparty%20%3D%20%22%20%E5%A4%B4%3A7725256e3859b62f1ff201db7f2cf7026c17656D%20%22%20meta-freescale-distro%20distro%20meta-freescale-3rdparty%20%3D%20%E5%A4%B4%3A4f1f101ebab5eb054bbedbedbedbed10b247fc0547b30793%20%22%20meta-imx-bsp%20meta-imx-sdk%20meta-imx-ml%20meta-imx-v2x%20%3D%20%22%20%E5%A4%B4%3A773c0049c3b35af8f5b5bdf8da78%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%22a6236a4fc184%20%22%20%3CBR%20%2F%3E%20meta-nxp-demo-experience%20%3D%20%22%20%E5%A4%B4%3Adb34fa86ad5f3c0d9c0a68f5f5f20240c04f2bfb%20%22%20meta-arm%20meta-arm%20meta-arm-toolchain%20%3D%20%22%20head%3A%204d22f982bce8df6f6f6f8f8c4d11845c47a4d39f961cc47a4d39f961cc4c961cc47a4d39f961cc4c961cc47a4d39f961cc4c966%20%22%20meta-chromium%20%3D%20%22%20%E5%A4%B4%3Adc31889c0899971def535dc1c040edf18bc16691%20%22%20meta-clang%20%3D%20%22%20HEAD%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3A9b08495e6bcef524789aefb6a7cc80fdfd2ff409%20%22%20%E5%85%83%E5%9C%B0%E7%B2%BE%E5%85%83%E7%BD%91%E7%BB%9C%E5%85%83%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%20%3D%20%22%20head%3A%201750c66ae8e4268c472c0b2b94748a59d6ef866D%20%22%20meta-qt6%20%3D%20head%20%22%3A%20fd054cf5fc1b50df6d%2050cd606384ab338c6d9206437%20%22%20meta-parsec%20meta-tpm%20%3D%20%22%20%E5%A4%B4%3A070a1e82cc59424d230a23c0b2a104b01fbaa2AD%20%2030%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3Espan%26gt%3B%20%3CBR%20%2F%3E%20meta-virtualization%20%3D%20%22%20head%3A%209e92984ff47b3ca2106b1d27a93af061b28d1e8a%20%22%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%82%A8%E7%9A%84%E4%B8%BB%E6%9C%BA%20glibc%20%E7%89%88%E6%9C%AC%EF%BC%882.41%EF%BC%89%E6%AF%94%20uninative%20%E7%9A%84%E7%89%88%E6%9C%AC%EF%BC%882.38%EF%BC%89%E6%96%B0%E3%80%82%E7%A6%81%E7%94%A8%20uninative%EF%BC%8C%E4%BB%A5%E5%85%8D%E6%8D%9F%E5%9D%8F%20sstate%E3%80%82%3CBR%20%2F%3E%E5%88%9D%E5%A7%8B%E5%8C%96%E4%BB%BB%E5%8A%A1%EF%BC%9A100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%20%E6%97%B6%E9%97%B4%EF%BC%9A0%3A00%3A11%3CBR%20%2F%3E%E7%8A%B6%E6%80%81%E6%91%98%E8%A6%81%EF%BC%9A%E6%83%B3%E8%A6%81%207712%20%E6%9C%AC%E5%9C%B0%200%20%E9%95%9C%E5%83%8F%200%20%E9%94%99%E8%BF%87%E4%BA%86%207712%20%E5%BD%93%E5%89%8D%20142%20%E4%B8%AA%EF%BC%880%25%20%E5%8C%B9%E9%85%8D%EF%BC%8C1%25%20%E5%B7%B2%E5%AE%8C%E6%88%90%EF%BC%89%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E6%AD%A3%E5%9C%A8%E6%89%A7%E8%A1%8C%E4%BB%BB%E5%8A%A1%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E4%BC%AA%E5%8E%9F%E7%94%9F%201.9.0%2Bgit-r0%20do_compile%EF%BC%9A%E6%89%A7%E8%A1%8C%E9%94%99%E8%AF%AF%EF%BC%88'%2Fhome%2Fdas%2FDesktop%2Fdas%2FNXP%2FProject%2Fnxpevb%2Fimx-yocto-%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%E3%80%82%2F%E7%89%88%E6%9C%AC%2Ftmp%2Fwork%2Fx86_64-linux%2Fpseudo-native%2F1.9.0%2Bgit%2Ftemp%2Frun.do_compile.28961'%EF%BC%8C1%EF%BC%8C%E6%97%A0%EF%BC%8C%E6%97%A0%EF%BC%89%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E6%95%85%E9%9A%9C%E6%97%A5%E5%BF%97%E6%96%87%E4%BB%B6%E5%AD%98%E5%82%A8%E5%9C%A8%EF%BC%9A%2Fhome%2Fdas%2FDesktop%2Fdas%2FNXP%2FProject%2Fnxpevb%2Fimx-yocto-%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%E3%80%82%2F%E7%89%88%E6%9C%AC%2Ftmp%2Fwork%2Fx86_64-linux%2Fpseudo-native%2F1.9.0%2Bgit%2Ftemp%2Flog.do_compile.28961%3CBR%20%2F%3E%E6%97%A5%E5%BF%97%E6%95%B0%E6%8D%AE%E5%A6%82%E4%B8%8B%EF%BC%9A%3CBR%20%2F%3E%7C%20DEBUG%EF%BC%9AExecuting%20shell%20function%20do_compile%3CBR%20%2F%3E%7C%20NOTE%3A%20Building%2Finstalling%20only%2064-bit%20libpseudo.so%20for%20pseudo-native.%3CBR%20%2F%3E%7C%20%E6%B3%A8%E6%84%8F%EF%BC%9A%E5%A6%82%E6%9E%9C%E4%BD%A0%E9%9C%80%E8%A6%81%E8%BF%90%E8%A1%8C%2032%20%E4%BD%8D%E5%8F%AF%E6%89%A7%E8%A1%8C%E6%96%87%E4%BB%B6%EF%BC%8C%E8%AF%B7%E7%A1%AE%E4%BF%9D%E5%B0%86%20NO32LIBS%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%200%E3%80%82%3CBR%20%2F%3E%7C%20%E5%9C%A8%20%2FHOME%2Fdas%2Fdesktop%2Fdas%2Fnxp%2Fproject%2Fnxp%2Fproject%2Fnxp%2Fproject%2Fnxpevb%2Fimx-yocto-bsp%2F%E7%89%88%E6%9C%AC%2Ftmp%2Fwork%2Fx86_64-Linux%2Fpeudo-native%2F1.9.0%2Bgit%2Frecipe-sysroot-native%2FUSR%20%E4%B8%AD%E6%89%BE%E5%88%B0%203043001%20%E7%89%88%E6%9C%AC%E7%9A%84%20SQLite%20%E6%A0%87%E5%A4%B4%E3%80%82%3CBR%20%2F%3E%7C%20%E9%BB%98%E8%AE%A4%E5%90%AF%E7%94%A8%E5%86%85%E5%AD%98%E6%95%B0%E6%8D%AE%E5%BA%93%E3%80%82%3CBR%20%2F%3E%7C%20%E6%B3%A8%E6%84%8F%EF%BC%9Amake%20-j%204%20RPATH%3D-Wl%2C--rpath%3DXORIGIN%2F..%2F..%2F..%2Fsqlite3-native%2Fusr%2Flib%2F%3CBR%20%2F%3E%7C%20make%EF%BC%9A%E5%AF%B9%20'all'%20%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E6%93%8D%E4%BD%9C%E3%80%82%3CBR%20%2F%3E%7C%20%E8%AD%A6%E5%91%8A%EF%BC%9AShell%20%E5%91%BD%E4%BB%A4%E7%9A%84%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%E4%B8%BA%201%E3%80%82%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E4%BB%BB%E5%8A%A1%EF%BC%88%E8%99%9A%E6%8B%9F%EF%BC%9A%E5%8E%9F%E7%94%9F%EF%BC%9A%2FHOME%2Fdas%2Fdesktop%2Fdas%2Fnxp%2FProject%2Fnxp%2Fproject%2Fnxp%2Fimx-yocto-bsp%2Fsources%2F%E5%8F%82%E8%80%83%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%81%E7%B3%BB%E7%BB%9F%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E3%80%82%2Fmeta%2F%E9%85%8D%E6%96%B9-devTools%2Fpeudo_GIT.bb%3A%20do_compile%EF%BC%89%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%E4%B8%BA%20%E2%80%9C1%E2%80%9D%20%E6%B3%A8%E6%84%8F%EF%BC%9A%E4%BB%BB%E5%8A%A1%E6%91%98%E8%A6%81%EF%BC%9A%E5%B0%9D%E8%AF%95%E4%BA%86%20359%20%E4%B8%AA%E4%BB%BB%E5%8A%A1%EF%BC%8C%E5%85%B6%E4%B8%AD%20358%20%E4%B8%AA%E4%B8%8D%E9%9C%80%E8%A6%81%E9%87%8D%E6%96%B0%E8%BF%90%E8%A1%8C%EF%BC%8C1%20%E4%B8%AA%E4%BB%BB%E5%8A%A1%E5%A4%B1%E8%B4%A5%E3%80%82%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E6%91%98%E8%A6%81%EF%BC%9A1%20%E9%A1%B9%E4%BB%BB%E5%8A%A1%E5%A4%B1%E8%B4%A5%EF%BC%9A%3CBR%20%2F%3Evirtual%3A%20native%3A%20%2FHOME%2Fdas%2Fdesktop%2Fdas%2Fnxp%2Fproject%2Fnxpevb%2Fimx-yocto-bsp%2Fsources%2F%E5%8F%82%E8%80%83%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%81%E7%B3%BB%E7%BB%9F%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E3%80%82%2Fmeta%2Frecipes-devTools%2Fpeudo_GIT.bb%3A%20do_compile%20%3CBR%20%2F%3E%E6%91%98%E8%A6%81%EF%BC%9A%E5%85%B1%E6%9C%89%204%20%E6%9D%A1%E8%AD%A6%E5%91%8A%E4%BF%A1%E6%81%AF%E3%80%82%3CBR%20%2F%3E%E6%91%98%E8%A6%81%EF%BC%9A%E6%9C%89%201%20%E6%9D%A1%20ERROR%20%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%BF%94%E5%9B%9E%E9%9D%9E%E9%9B%B6%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%A0%E8%83%BD%E5%90%A6%E5%9B%9E%E8%BF%87%E5%A4%B4%E6%9D%A5%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%E5%92%8C%20Yacto%20%E7%89%88%E6%9C%AC%E9%97%AE%E9%A2%98%EF%BC%9B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E8%BE%BE%E6%96%AF%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2158725%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20IMX8%20%20Plus%20%22Creating%20the%20BSP%20and%20Yocto%20build%20environment%22%20%20compile%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2158725%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%AF%BC%E8%87%B4%20OE_RUNMAKE%20%E9%94%99%E8%AF%AF%E7%9A%84%E5%8E%9F%E5%9B%A0%E5%A4%9A%E7%A7%8D%E5%A4%9A%E6%A0%B7%E3%80%82DDR%20%E4%B8%8D%E8%B6%B3%E5%8F%AF%E8%83%BD%E6%98%AF%E5%85%B6%E4%B8%AD%E4%B9%8B%E4%B8%80%E3%80%82%20%3C%2FP%3E%0A%3CP%3E%E7%A1%AE%E4%BF%9D%E6%A0%B9%E6%8D%AE%E9%9C%80%E8%A6%81%E6%AD%A3%E7%A1%AE%E8%AE%BE%E7%BD%AE%E6%82%A8%E7%9A%84%E5%BC%80%E5%8F%91%E4%B8%BB%E6%9C%BA%EF%BC%8C%E4%B8%8A%E8%BF%B0%E7%A1%AC%E4%BB%B6%E8%B5%84%E6%BA%90%E9%99%A4%E5%A4%96%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%0A%3CP%3E%E5%93%88%E7%BB%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2157484%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20IMX8%20%20Plus%20%22Creating%20the%20BSP%20and%20Yocto%20build%20environment%22%20%20compile%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2157484%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%81%A9%E6%99%BA%E6%B5%A6%20%E3%80%81%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%9C%A8%E8%BF%99%E6%96%B9%E9%9D%A2%E6%8F%90%E4%BE%9B%E5%B8%AE%E5%8A%A9%E5%90%97%20%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3Edasmiddepogu%20%40dasmiddepogu-ThinkPad-L13-Yoga-gen-3%EF%BC%9A~%2Fdesktop%2Fdas%2Fproject%2Fimx-yocto-bsp%2Fbuild%24%20bitbake%20core-image-minimal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llvm-native%2017.0.6%20%E7%89%88%E6%9C%AC%E4%B8%8D%E5%8F%AF%E7%94%A8%EF%BC%88%E9%92%88%E5%AF%B9%20llvm-native%20%E9%A1%B9%E7%9B%AE%EF%BC%89%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E5%8F%AF%E7%94%A8%E7%9A%84%20llvm-native%20%E7%89%88%E6%9C%AC%EF%BC%9A17.0.3%3C%2FP%3E%3CP%3E%E7%89%88%E6%9C%AC%E9%85%8D%E7%BD%AE%EF%BC%9A%3CBR%20%2F%3EBB_VERSION%20%3D%20%22%202.6.0%20%22%20%3CBR%20%2F%3EBUILD_SYS%20%3D%20%22x86_64-linux%22%3CBR%20%2F%3ENATIVELSBSTRING%20%3D%20%22%E9%80%9A%E7%94%A8%22%3CBR%20%2F%3ETARGET_SYS%20%3D%20%22aarch64-poky-linux%22%3CBR%20%2F%3EMACHINE%20%3D%20%22imx8mp-lpddr4-evk%22%3CBR%20%2F%3EDISTRO%20%3D%20%22fsl-imx-xwayland%22%3CBR%20%2F%3EDISTRO_VERSION%20%3D%20%226.6-nanbield%22%3CBR%20%2F%3ETUNE_FEATURES%20%3D%20%22%20aarch64%20armv8a%20crcrypto%20%22%20%3CBR%20%2F%3ETARGET_FPU%20%3D%20%22%20%22%20meta%20%3CBR%20%2F%3E%20meta-poky%20%3D%20%22%20Head%3A%20046b70083f3f3bc9e25f547e8026400032f563d9%20%22%20meta-oe%20%E5%85%83%E5%A4%9A%E5%AA%92%E4%BD%93%20meta-python%20%3D%20%22%20Head%3A%201750c66ae8e4268c472c0b2b94748AD59AD9c0b2b94748AD59AD%206ef866D%20%22%20%3CBR%20%2F%3E%20meta-freescale%20%3D%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%22%20%E5%A4%B4%3A0a73d1bdd7713a6189482e463c98043c9939a2a2%20%22%20meta-freescale-3rdparty%20%3D%20%22%20%E5%A4%B4%3A7725256e3859b62f1ff201db7f2cf7026c17656D%20%22%20meta-freescale-%E5%8F%91%E8%A1%8C%E7%89%88%20%3D%20%E5%A4%B4%3A4f1f101ebab5eb054bbedbedbedbed10b247fc0547b30793%20%22%20meta-imx-bsp%20meta-imx-sdk%20meta-imx-ml%20meta-imx-v2x%20%3D%20%22%20%E5%A4%B4%3A773c0049c3b35af8f5b5bdf8da78%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%22a6236a4fc184%20%22%20%3CBR%20%2F%3E%20meta-nxp-demo-experience%20%3D%20%22%20%E5%A4%B4%3Adb34fa86ad5f3c0d9c0a68f5f5f20240c04f2bfb%20%22%20meta-Arm%20meta-Arm%20meta-Arm-toolchain%20%3D%20%22%20head%3A%204d22f982bce8df6f6f6f8f8c4d11845c47a4d39f961cc47a4d39f961cc4c961cc47a4d39f961cc4c966%20%22%20meta-chromium%20%3D%20%22%20%E5%A4%B4%3Adc31889c0899971def535dc1c040edf18bc16691%20%22%20meta-clang%20%3D%20%22%20HEAD%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3A9b08495e6bcef524789aefb6a7cc80fdfd2ff409%20%22%20%E5%85%83%E5%9C%B0%E7%B2%BE%E5%85%83%E7%BD%91%E7%BB%9C%E5%85%83%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%20%3D%20%22%20head%3A%201750c66ae8e4268c472c0b2b94748a59d6ef866D%20%22%20meta-qt6%20%3D%20head%20%22%3A%20fd054cf5fc1b50df6d%2050cd606384ab338c6d9206437%20%22%20meta-parsec%20meta-tpm%20%3D%20%22%20%E5%A4%B4%3A070a1e82cc59424d230a23c0b2a104b01fbaa2AD%20%2030%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3Espan%26gt%3B%20%3CBR%20%2F%3E%20meta-virtualization%20%3D%20%22%20head%3A%209e92984ff47b3ca2106b1d27a93af061b28d1e8a%20%22%3C%2FP%3E%3CP%3E%E5%88%9D%E5%A7%8B%E5%8C%96%E4%BB%BB%E5%8A%A1%EF%BC%9A100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%20Time%3A%200%3A00%3A02%3CBR%20%2F%3ESstate%20summary%3A%20Wanted%201103%20Local%202%20Mirrors%200%20Missed%201101%20Current%201686%20(0%25%20match%2C%2060%25%20complete)%3CBR%20%2F%3ENOTE%3A%20Executing%20Tasks%3CBR%20%2F%3EERROR%3A%20openssl-3.1.4-r0do_compile%3A%20oe_runmake%20%E5%A4%B1%E8%B4%A5%3CBR%20%2F%3EERROR%3A%20openssl-3.1.4-r0do_compile%EF%BC%9A%E6%89%A7%E8%A1%8C%E9%94%99%E8%AF%AF%EF%BC%88'%2FHOME%2Fdasmiddepogu%2Fdas%2Fproject%2Fimx-yocto-bsp%2F%E7%89%88%E6%9C%AC%2Ftmp%2Fwork%2Farmv8a-%E5%8F%82%E8%80%83%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%81%E7%B3%BB%E7%BB%9F%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E3%80%82-linux%2FopenSSL%2F3.1.4%2Ftemp%2Frun.do_compile.14161%20'%EF%BC%8C1%EF%BC%8C%E6%97%A0%EF%BC%8C%E6%97%A0%EF%BC%89%E9%94%99%E8%AF%AF%EF%BC%9A%E6%95%85%E9%9A%9C%E6%97%A5%E5%BF%97%E6%96%87%E4%BB%B6%E5%AD%98%E5%82%A8%E5%9C%A8%EF%BC%9A%2FHOME%2Fdasmiddepogu%2Fdas%2FProject%2Fdesktop%2Fdas%2FProject%2Fdesktop%2Fdas%2FProject%2Fdesktop%2Fdas%2FProject%2Fdesktop%2Fdas%2Fimx-yocto-bsp%2F%E7%89%88%E6%9C%AC%2Ftmp%2Fwork%2Farmv8a-%E5%8F%82%E8%80%83%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%81%E7%B3%BB%E7%BB%9F%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E3%80%82-linux%2FopenSSL%2F3.1.4%2Ftemp%2Flog.do_compile.14161%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%E6%97%A5%E5%BF%97%E6%95%B0%E6%8D%AE%E5%A6%82%E4%B8%8B%EF%BC%9A%3CBR%20%2F%3E%7C%20DEBUG%EF%BC%9A%E6%89%A7%E8%A1%8C%20shell%20%E5%87%BD%E6%95%B0%20do_compile%3CBR%20%2F%3E%7C%20%E6%B3%A8%E6%84%8F%EF%BC%9Amake%20-j%2012%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E4%BB%BB%E5%8A%A1%EF%BC%88%2FHOME%2Fdasmiddepogu%2Fdesktop%2Fdas%2Fproject%2Fimx-yocto-bsp%2Fsources%2F%E5%8F%82%E8%80%83%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%81%E7%B3%BB%E7%BB%9F%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E3%80%82%2Fmeta%2F%E9%85%8D%E6%96%B9-%E8%BF%9E%E6%8E%A5%2FopenSSL_3.1.4.bb%3A%20do_compile%EF%BC%89%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%E4%B8%BA%20%E2%80%9C1%E2%80%9D%20%E7%AD%89%E5%BE%85%2011%20%E4%B8%AA%E6%AD%A3%E5%9C%A8%E8%BF%90%E8%A1%8C%E7%9A%84%E4%BB%BB%E5%8A%A1%E5%AE%8C%E6%88%90%EF%BC%9A0%EF%BC%9Aqemu-native-8.1.2-r0%20%3CBR%20%2F%3E%20%3CBR%20%2F%3Edo_compile%20-%2045s%20(pid%2014162)%3CBR%20%2F%3E1%3A%20linux-imx-6.6.3%2Bgit-r0do_fetch%20-%2045s%20(pid%2014185)%20%7C%26lt%3B%3D%26gt%3B%20%7C%3CBR%20%2F%3E2%3A%20rust-llvm-native-1.70.0-r0%20do_compile%20-%2045s%20(pid%2014195)%200%25%20%7C%20%7C%3CBR%20%2F%3E3%3A%20icu-73-2-r0%20do_compile%20-%2044s%20(pid%2014317)%3CBR%20%2F%3E4%3A%20perl-5.38.0-r0%20do_compile%20-%2043s%20(pid%2014323)%3CBR%20%2F%3E5%3A%20util-linux-2.39.2-r0%20do_package%20-%2043s%20(pid%2014318)%3CBR%20%2F%3E6%3A%20libical-native-3.0.16-r0%20do_compile%20-%2043s%20(pid%2014321)%2036%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%20%7C%3CBR%20%2F%3E7%3A%20bash-5.2.15-r0%20do_configure%20-%2043s%20(pid%201432%5EC%3CBR%20%2F%3E%20dasmiddepogu%40dasmiddepogu-ThinkPad-L13-Yoga-Gen-3%3CA%20href%3D%22mailto%3Adasmiddepogu%40dasmiddepogu-ThinkPad-L13-Yoga-Gen-3%3A~%2FDesktop%2Fdas%2Fproject%2Fimx-y%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3A~%2FDesktop%2Fdas%2Fproject%2Fimx-y%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E8%BE%BE%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2157483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20IMX8%20%20Plus%20%22Creating%20the%20BSP%20and%20Yocto%20build%20environment%22%20%20compile%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2157483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%81%A9%E6%99%BA%E6%B5%A6%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%AF%B7%E5%B8%AE%E5%8A%A9%E8%A7%A3%E5%86%B3%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3CBR%20%2F%3Edasmiddepogu%20%40dasmiddepogu-ThinkPad-L13-Yoga-gen-3%EF%BC%9A~%2Fdesktop%2Fdas%2Fproject%2Fimx-yocto-bsp%2Fbuild%24%20bitbake-c%20cleansstate%20openssl%3C%2FP%3E%3CP%3Edasmiddepogu%20%40dasmiddepogu-ThinkPad-L13-Yoga-gen-3%EF%BC%9A~%2Fdesktop%2Fdas%2Fproject%2Fimx-yocto-bsp%2Fbuild%24%20bitbake%20openssl%3CBR%20%2F%3E%E5%8A%A0%E8%BD%BD%E7%BC%93%E5%AD%98%EF%BC%9A100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%20%E6%97%B6%E9%97%B4%EF%BC%9A0%3A00%3A00%3CBR%20%2F%3E%E4%BB%8E%E4%BE%9D%E8%B5%96%E7%BC%93%E5%AD%98%E4%B8%AD%E5%8A%A0%E8%BD%BD%E4%BA%86%205449%20%E4%B8%AA%E6%9D%A1%E7%9B%AE%E3%80%82%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E8%A7%A3%E5%86%B3%E4%BB%BB%E4%BD%95%E7%BC%BA%E5%A4%B1%E7%9A%84%E4%BB%BB%E5%8A%A1%E9%98%9F%E5%88%97%E4%BE%9D%E8%B5%96%E5%85%B3%E7%B3%BB%3C%2FP%3E%3CP%3E%E7%89%88%E6%9C%AC%E9%85%8D%E7%BD%AE%EF%BC%9A%3CBR%20%2F%3EBB_VERSION%20%3D%20%22%202.6.0%20%22%20%3CBR%20%2F%3EBUILD_SYS%20%3D%20%22x86_64-linux%22%3CBR%20%2F%3ENATIVELSBSTRING%20%3D%20%22%E9%80%9A%E7%94%A8%22%3CBR%20%2F%3ETARGET_SYS%20%3D%20%22aarch64-poky-linux%22%3CBR%20%2F%3EMACHINE%20%3D%20%22imx8mp-lpddr4-evk%22%3CBR%20%2F%3EDISTRO%20%3D%20%22fsl-imx-xwayland%22%3CBR%20%2F%3EDISTRO_VERSION%20%3D%20%226.6-nanbield%22%3CBR%20%2F%3ETUNE_FEATURES%20%3D%20%22%20aarch64%20armv8a%20crcrypto%20%22%20%3CBR%20%2F%3ETARGET_FPU%20%3D%20%22%20%22%20meta%20%3CBR%20%2F%3E%20meta-poky%20%3D%20%22%20Head%3A%20046b70083f3f3bc9e25f547e8026400032f563d9%20%22%20meta-oe%20%E5%85%83%E5%A4%9A%E5%AA%92%E4%BD%93%20meta-python%20%3D%20%22%20Head%3A%201750c66ae8e4268c472c0b2b94748AD59AD9c0b2b94748AD59AD%206ef866D%20%22%20%3CBR%20%2F%3E%20meta-freescale%20%3D%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%22%20%E5%A4%B4%3A0a73d1bdd7713a6189482e463c98043c9939a2a2%20%22%20meta-freescale-3rdparty%20%3D%20%22%20%E5%A4%B4%3A7725256e3859b62f1ff201db7f2cf7026c17656D%20%22%20meta-freescale-%E5%8F%91%E8%A1%8C%E7%89%88%20%3D%20%E5%A4%B4%3A4f1f101ebab5eb054bbedbedbedbed10b247fc0547b30793%20%22%20meta-imx-bsp%20meta-imx-sdk%20meta-imx-ml%20meta-imx-v2x%20%3D%20%22%20%E5%A4%B4%3A773c0049c3b35af8f5b5bdf8da78%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%22a6236a4fc184%20%22%20%3CBR%20%2F%3E%20meta-nxp-demo-experience%20%3D%20%22%20%E5%A4%B4%3Adb34fa86ad5f3c0d9c0a68f5f5f20240c04f2bfb%20%22%20meta-Arm%20meta-Arm%20meta-Arm-toolchain%20%3D%20%22%20head%3A%204d22f982bce8df6f6f6f8f8c4d11845c47a4d39f961cc47a4d39f961cc4c961cc47a4d39f961cc4c966%20%22%20meta-chromium%20%3D%20%22%20%E5%A4%B4%3Adc31889c0899971def535dc1c040edf18bc16691%20%22%20meta-clang%20%3D%20%22%20HEAD%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3A9b08495e6bcef524789aefb6a7cc80fdfd2ff409%20%22%20%E5%85%83%E5%9C%B0%E7%B2%BE%E5%85%83%E7%BD%91%E7%BB%9C%E5%85%83%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%20%3D%20%22%20head%3A%201750c66ae8e4268c472c0b2b94748a59d6ef866D%20%22%20meta-qt6%20%3D%20head%20%22%3A%20fd054cf5fc1b50df6d%2050cd606384ab338c6d9206437%20%22%20meta-parsec%20meta-tpm%20%3D%20%22%20%E5%A4%B4%3A070a1e82cc59424d230a23c0b2a104b01fbaa2AD%20%2030%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3Espan%26gt%3B%20%3CBR%20%2F%3E%20meta-virtualization%20%3D%20%22%20head%3A%209e92984ff47b3ca2106b1d27a93af061b28d1e8a%20%22%3C%2FP%3E%3CP%3E%E5%88%9D%E5%A7%8B%E5%8C%96%E4%BB%BB%E5%8A%A1%EF%BC%9A100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%20Time%3A%200%3A00%3A00%3CBR%20%2F%3ESstate%20summary%3A%20Wanted%20100%20Local%200%20Mirrors%200%20Missed%20100%20Current%20616%20(0%25%20match%2C%2086%25%20complete)%3CBR%20%2F%3ENOTE%3A%20Executing%20Tasks%3CBR%20%2F%3ENOTE%3A%20No%20reply%20from%20server%20in%2030s%20(for%20command%20ping%20at%2005%3A13%3A49.520202)%3CBR%20%2F%3E%E7%AD%89%E5%BE%85%20bitbake%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E5%9B%9E%E5%A4%8D%E6%97%B6%E8%B6%85%E6%97%B6%20(60s%20at%2005%3A14%3A19.561139)%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E4%B8%BB%E6%9C%BA%E6%9C%89%201TB%20%E5%86%85%E5%AD%98%E3%80%818GB%20%E5%86%85%E5%AD%98%E5%92%8C%2010%20%E4%B8%AA%20CPU%20%E5%86%85%E6%A0%B8%E3%80%82%3C%2FP%3E%3CP%3EThinkPad-L13-Yoga-Gen-3%205.15.0-139-generic%20%23149~20.04.1-UbuntuSMP%20Wed%20Apr%2016%2008%3A29%3A56%20UTC%202025%20x86_64%20x86_64%20x86_64%20GNU%2FLinux%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E8%BE%BE%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2155829%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20IMX8%20%20Plus%20%22Creating%20the%20BSP%20and%20Yocto%20build%20environment%22%20%20compile%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2155829%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%99%E6%98%AF%E5%8F%AF%E8%83%BD%E7%9A%84%E3%80%82%E4%BD%A0%E5%8F%AF%E4%BB%A5%E8%AF%84%E8%AE%BA%E5%9B%BE%E7%89%87%E9%85%8D%E6%96%B9%E4%B8%AD%E7%9A%84%E4%BB%A3%E7%A0%81%E5%8C%85%EF%BC%8C%E4%B9%9F%E5%8F%AF%E4%BB%A5%E4%BB%8EYocto%E8%AE%BA%E5%9D%9B%E8%8E%B7%E5%BE%97%E5%B8%AE%E5%8A%A9%E3%80%82%E4%B8%8D%E8%BF%87%EF%BC%8C%E8%BF%99%E5%B0%86%E6%98%AF%E5%8F%A6%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E5%A6%82%E6%9E%9C%E9%9C%80%E8%A6%81%E8%BF%9B%E4%B8%80%E6%AD%A5%E5%B8%AE%E5%8A%A9%EF%BC%8C%E8%AF%B7%E6%8F%90%E5%87%BA%E6%96%B0%E7%9A%84%E9%97%AE%E9%A2%98%E5%8D%95%E3%80%82%E5%A6%82%E5%89%8D%E6%89%80%E8%BF%B0%EF%BC%8C%E5%A6%82%E6%9E%9C%E8%B7%B3%E8%BF%87%E6%AD%A4%E7%B1%BB%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%2F%E4%BB%A3%E7%A0%81%E5%8C%85%EF%BC%8C%E5%88%99%E7%89%88%E6%9C%AC%E5%AE%8C%E6%95%B4%2F%E5%A4%9A%E5%AA%92%E4%BD%93%E5%B0%86%E7%B1%BB%E4%BC%BC%E4%BA%8E%E7%89%88%E6%9C%AC%E5%85%B6%E4%BB%96%E8%BE%83%E5%B0%8F%E7%9A%84%E5%9B%BE%E5%83%8F%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%0A%3CP%3E%E5%93%88%E7%BB%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2155195%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20IMX8%20%20Plus%20%22Creating%20the%20BSP%20and%20Yocto%20build%20environment%22%20%20compile%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2155195%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%81%A9%E6%99%BA%E6%B5%A6%E3%80%81%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E5%9C%A8%E7%89%88%E6%9C%AC%E4%BB%A5%E4%B8%8B%E9%85%8D%E7%BD%AE%EF%BC%88bitbake%20fsl-image-machine-test%E3%80%81bitbake%20imx-image-mage-full%E3%80%81bitbake%20imx-image-full%EF%BC%89%E6%97%B6%EF%BC%8C%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E5%9C%A8%E7%89%88%E6%9C%AC%20%22%20opencv%20%22%20%E6%88%96%20%22%20vulkan%20%22%20%E8%BF%99%E4%BA%9B%E5%85%83%E5%99%A8%E4%BB%B6%E7%9A%84%E7%89%88%E6%9C%AC%E8%84%9A%E6%9C%AC%E6%96%87%E4%BB%B6%E4%B8%AD%E6%B3%A8%E9%87%8A%E4%BB%A5%E8%B7%B3%E8%BF%87%E7%89%88%E6%9C%AC%E8%BF%87%E7%A8%8B%EF%BC%9F%E8%AF%B7%E5%88%86%E4%BA%AB%E6%96%87%E4%BB%B6%E5%90%8D%E4%BB%A5%E5%8F%8A%E6%88%91%E9%9C%80%E8%A6%81%E5%9C%A8%E5%93%AA%E9%87%8C%E6%B3%A8%E9%87%8A%E4%BB%A3%E7%A0%81%E6%89%8D%E8%83%BD%E8%B7%B3%E8%BF%87%E7%89%88%E6%9C%AC%E5%85%83%E5%99%A8%E4%BB%B6%EF%BC%9F%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3E%E6%88%91%E7%9A%84%E6%9C%80%E7%BB%88%E7%9B%AE%E6%A0%87%E6%98%AF%E8%BF%9B%E8%A1%8C%E5%AE%8C%E6%95%B4%E7%89%88%E6%9C%AC%EF%BC%88bitbake%20imx-image-full%EF%BC%89%E3%80%82%E9%80%9A%E8%BF%87%E4%B8%8A%E8%BF%B0%E5%AE%9E%E9%AA%8C%EF%BC%8C%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E6%89%BE%E5%87%BA%E7%94%B1%E5%85%83%E5%99%A8%E4%BB%B6%E9%80%A0%E6%88%90%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E8%BE%BE%E6%96%AF%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E4%BB%8E%E4%B8%8A%E9%9D%A2%E7%9A%84%E9%85%8D%E7%BD%AE%E4%B8%AD%E6%88%91%E8%A7%82%E5%AF%9F%E5%88%B0%EF%BC%8C%E6%AF%8F%E5%BD%93%E5%B0%9D%E8%AF%95%E6%9E%84%E5%BB%BA%3CSPAN%3E%3C%2FSPAN%3E%20%3CSTRONG%3E%22%20opencv%20%22%20%E5%92%8C%20%22%20vulkan%20%22%20%E6%97%B6%EF%BC%8C%E6%88%91%E9%83%BD%E4%BC%9A%E9%81%87%E5%88%B0%20bitbake%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E8%BF%9E%E6%8E%A5%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E4%BB%AC%E6%9C%89%E4%BB%BB%E4%BD%95%E6%9E%84%E5%BB%BA%E9%80%89%E9%A1%B9%E5%8F%AF%E4%BB%A5%E8%AF%84%E8%AE%BA%E6%88%96%E8%B7%B3%E8%BF%87%E5%BB%BA%E7%AD%91%E7%89%A9%EF%BC%88%22%20opencv%20%22%20%E5%92%8C%20%22%20vulkan%20%22%EF%BC%89%E7%84%B6%E5%90%8E%E7%BB%A7%E7%BB%AD%E6%93%8D%E4%BD%9C%E5%90%97%EF%BC%9F%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2155070%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20IMX8%20%20Plus%20%22Creating%20the%20BSP%20and%20Yocto%20build%20environment%22%20%20compile%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2155070%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E8%BF%99%E4%BA%9B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%98%AF%E5%AE%8C%E6%95%B4%2F%E5%A4%9A%E5%AA%92%E4%BD%93%E5%9B%BE%E5%83%8F%E7%9A%84%E4%B8%BB%E8%A6%81%E5%85%83%E5%99%A8%E4%BB%B6%3C%2FSPAN%3E%E3%80%82%E4%B8%8E%E5%85%B6%E8%B7%B3%E8%BF%87%E8%BF%99%E4%BA%9B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E7%89%88%E6%9C%AC%EF%BC%8C%E4%B8%8D%E5%A6%82%E7%9B%B4%E6%8E%A5%E7%89%88%E6%9C%AC%20imx-image-core%E3%80%82%E5%A6%82%E5%89%8D%E6%89%80%E8%BF%B0%EF%BC%8C%E5%8D%87%E7%BA%A7%E6%82%A8%E7%9A%84%E5%BC%80%E5%8F%91%E4%B8%BB%E6%9C%BA%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%0A%3CP%3E%E5%93%88%E7%BB%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2154901%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20IMX8%20%20Plus%20%22Creating%20the%20BSP%20and%20Yocto%20build%20environment%22%20%20compile%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2154901%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%81%A9%E6%99%BA%E6%B5%A6%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%E6%88%91%E7%8E%B0%E5%9C%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%204%20CPU%E3%80%811TB%20%E7%A1%AC%E7%9B%98%E5%92%8C%208GB%20%E5%86%85%E5%AD%98%E3%80%82%E6%A0%B9%E6%8D%AE%E6%82%A8%E7%9A%84%E5%BB%BA%E8%AE%AE%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E5%B0%86%E5%86%85%E5%AD%98%E5%A2%9E%E8%87%B3%2016%20GB%20%E4%BB%A5%E4%B8%8A%E3%80%82%20%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E7%89%88%E6%9C%AC%E4%B8%BA%20%3CSTRONG%3E%22MACHINE%20%3D%20%22imx8mp-lpddr4-evk%22%22%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%A0%B9%E6%8D%AE%E6%88%91%E7%9A%84%E8%A7%82%E5%AF%9F%EF%BC%8C%E7%89%88%E6%9C%AC%20summery%20%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E8%83%BD%E5%A4%9F%E7%89%88%E6%9C%AC%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Ebitbake%20imx-image-core%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E6%97%A0%E6%B3%95%E7%89%88%E6%9C%AC%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Ebitbake%20fsl-image-machine-test%3CBR%20%2F%3Ebitbake%20imx-image-multimedia%3CBR%20%2F%3Ebitbake%20imx-image-full%3C%2FP%3E%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E4%BB%8E%E4%B8%8A%E9%9D%A2%E7%9A%84%E9%85%8D%E7%BD%AE%E4%B8%AD%E6%88%91%E8%A7%82%E5%AF%9F%E5%88%B0%EF%BC%8C%E6%AF%8F%E5%BD%93%E5%B0%9D%E8%AF%95%E7%89%88%E6%9C%AC%20%3CSTRONG%3E%22%20opencv%20%22%20%E5%92%8C%20%22%20vulkan%20%22%20%E6%97%B6%EF%BC%8C%E6%88%91%E9%83%BD%E4%BC%9A%E9%81%87%E5%88%B0%20bitbake%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E8%BF%9E%E6%8E%A5%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E4%BB%AC%E6%9C%89%E4%BB%BB%E4%BD%95%E7%89%88%E6%9C%AC%E9%80%89%E9%A1%B9%E5%8F%AF%E4%BB%A5%E8%AF%84%E8%AE%BA%E6%88%96%E8%B7%B3%E8%BF%87%E5%BB%BA%E7%AD%91%E7%89%A9%EF%BC%88%22%20opencv%20%22%20%E5%92%8C%20%22%20vulkan%20%22%EF%BC%89%E7%84%B6%E5%90%8E%E7%BB%A7%E7%BB%AD%E6%93%8D%E4%BD%9C%E5%90%97%EF%BC%9F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E4%BD%A0%E8%83%BD%E5%90%A6%E6%8C%87%E5%87%BA%E7%BC%96%E8%AF%91%E8%84%9A%E6%9C%AC%E5%90%8D%E7%A7%B0%E4%BB%A5%E5%8F%8A%E5%9C%A8%E5%93%AA%E9%87%8C%E5%8F%91%E8%A1%A8%E8%AF%84%E8%AE%BA%E4%BB%A5%E8%B7%B3%E8%BF%87%20opencv%20%22%20%E5%92%8C%20%22%20vulkan%20%22%20%E7%9A%84%E7%89%88%E6%9C%AC%EF%BC%9F%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3E%E6%84%9F%E8%B0%A2%E4%BD%A0%E7%9A%84%E6%94%AF%E6%8C%81%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E8%BE%BE%E6%96%AF%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2154119%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20IMX8%20%20Plus%20%22Creating%20the%20BSP%20and%20Yocto%20build%20environment%22%20%20compile%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2154119%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%20%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22jCAhz%20ChMk0b%22%3E%3CSPAN%20class%3D%22ryNqvb%22%3E%E6%82%A8%E7%9A%84%E7%BC%96%E8%AF%91%E7%B3%BB%E7%BB%9F%E4%BC%BC%E4%B9%8E%E4%B8%8D%E7%AC%A6%E5%90%88%E6%AD%A4%E7%89%88%E6%9C%AC%E7%9A%84%E8%A6%81%E6%B1%82%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22jCAhz%20ChMk0b%22%3E%3CSPAN%20class%3D%22ryNqvb%22%3E%E4%B8%8B%E9%9D%A2%E6%98%AF%20Yocto%20%E6%8F%90%E5%87%BA%E7%9A%84%E4%B8%80%E4%BA%9B%E9%85%8D%E7%BD%AE%E5%BB%BA%E8%AE%AE%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fdocs.yoctoproject.org%2F5.2.2%2Fbrief-yoctoprojectqs%2Findex.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EYocto%20Project%20%E5%BF%AB%E9%80%9F%E7%89%88%E6%9C%AC%20%E2%80%94%20Yocto%20Project%C2%AE%205.2.2%20%E6%96%87%E6%A1%A3%3C%2FA%3E%3C%2FP%3E%0A%3CUL%20class%3D%22simple%22%3E%0A%3CLI%3E%0A%3CP%3E%E8%87%B3%E5%B0%91%208%20GB%20%E7%9A%84%20RAM%EF%BC%8C%E4%BD%86%E5%BC%BA%E7%83%88%E5%BB%BA%E8%AE%AE%E4%BD%BF%E7%94%A8%E5%85%B7%E6%9C%89%E5%B0%BD%E5%8F%AF%E8%83%BD%E5%A4%9A%20RAM%20%E5%92%8C%20CPU%20%E5%86%85%E6%A0%B8%E7%9A%84%E7%8E%B0%E4%BB%A3%E5%BC%80%E5%8F%91%E4%B8%BB%E6%9C%BA%EF%BC%8C%E4%BB%A5%E6%9C%80%E5%A4%A7%E9%99%90%E5%BA%A6%E5%9C%B0%E6%8F%90%E9%AB%98%E7%89%88%E6%9C%AC%E6%80%A7%E8%83%BD%E3%80%82%3C%2FP%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSPAN%20class%3D%22jCAhz%20ChMk0b%22%3E%3CSPAN%20class%3D%22ryNqvb%22%3E%E5%85%B6%E4%BB%96%E5%BB%BA%E8%AE%AE%EF%BC%9A%E5%A6%82%E6%9E%9C%E6%9C%89%204%20%E4%B8%AA%20CPU%20%E5%86%85%E6%A0%B8%EF%BC%8C%E8%87%B3%E5%B0%91%E9%9C%80%E8%A6%81%2016GB%20%E5%86%85%E5%AD%98%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22jCAhz%20ChMk0b%22%3E%3CSPAN%20class%3D%22ryNqvb%22%3E1%3A4%20%E7%9A%84%E6%AF%94%E4%BE%8B%E5%A6%82%E4%B8%8B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22jCAhz%20ChMk0b%22%3E%3CSPAN%20class%3D%22ryNqvb%22%3E%E6%82%A8%E8%BF%98%E5%8F%AF%E4%BB%A5%E5%8F%82%E8%80%83%3CA%20href%3D%22https%3A%2F%2Fdocs.yoctoproject.org%2Fdev-manual%2Fspeeding-up-build.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fdocs.yoctoproject.org%2Fdev-manual%2Fspeeding-up-build.html%20%3C%2FA%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22jCAhz%20ChMk0b%22%3E%3CSPAN%20class%3D%22ryNqvb%22%3E%E5%A6%82%E6%9E%9C%E8%A6%81%E5%88%9B%E5%BB%BA%E5%AE%8C%E6%95%B4%E9%95%9C%E5%83%8F%EF%BC%8C%E8%87%B3%E5%B0%91%E9%9C%80%E8%A6%81%20250GB%20%E7%A3%81%E7%9B%98%E7%A9%BA%E9%97%B4%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22jCAhz%20ChMk0b%22%3E%3CSPAN%20class%3D%22ryNqvb%22%3E%E6%88%91%E5%88%9A%E5%88%9A%E5%9C%A8%E6%88%91%E7%9A%84%E4%B8%BB%E6%9C%BA%E4%B8%8A%E8%BF%9B%E8%A1%8C%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E6%B5%8B%E8%AF%95%EF%BC%9A22.04.1-Ubuntu%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3Ebitbake%20imx-image-full%20-c%20populate_sdk%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%8A%A0%E8%BD%BD%E7%BC%93%E5%AD%98%EF%BC%9A100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%20%E6%97%B6%E9%97%B4%EF%BC%9A0%3A00%3A01%3CBR%20%2F%3E%E4%BB%8E%E4%BE%9D%E8%B5%96%E7%BC%93%E5%AD%98%E4%B8%AD%E5%8A%A0%E8%BD%BD%E4%BA%86%205449%20%E4%B8%AA%E6%9D%A1%E7%9B%AE%E3%80%82%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E8%A7%A3%E5%86%B3%E4%BB%BB%E4%BD%95%E7%BC%BA%E5%A4%B1%E7%9A%84%E4%BB%BB%E5%8A%A1%E9%98%9F%E5%88%97%E4%BE%9D%E8%B5%96%E5%85%B3%E7%B3%BB%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E9%A6%96%E9%80%89%E7%9A%84%20llvm-native%2017.0.6%20%E7%89%88%E6%9C%AC%E4%B8%8D%E5%8F%AF%E7%94%A8%EF%BC%88%E9%92%88%E5%AF%B9%20llvm-native%20%E9%A1%B9%E7%9B%AE%EF%BC%89%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E5%8F%AF%E7%94%A8%E7%9A%84%20llvm-native%20%E7%89%88%E6%9C%AC%EF%BC%9A17.0.3%3C%2FP%3E%0A%3CP%3E%E7%89%88%E6%9C%AC%E9%85%8D%E7%BD%AE%EF%BC%9A%3CBR%20%2F%3EBB_VERSION%20%3D%20%22%202.6.0%20%22%20%3CBR%20%2F%3EBUILD_SYS%20%3D%20%22x86_64-linux%22%3CBR%20%2F%3ENATIVELSBSTRING%20%3D%20%22%E9%80%9A%E7%94%A8%22%3CBR%20%2F%3ETARGET_SYS%20%3D%20%22aarch64-poky-linux%22%3CBR%20%2F%3EMACHINE%20%3D%20%22imx8mp-lpddr4-evk%22%3CBR%20%2F%3EDISTRO%20%3D%20%22fsl-imx-xwayland%22%3CBR%20%2F%3EDISTRO_VERSION%20%3D%20%226.6-nanbield%22%3CBR%20%2F%3ETUNE_FEATURES%20%3D%20%22%20aarch64%20armv8a%20crcrypto%20%22%20%3CBR%20%2F%3ETARGET_FPU%20%3D%20%22%20%22%20meta%20%3CBR%20%2F%3E%20meta-poky%20%3D%20%22%20Head%3A%20046b70083f3f3bc9e25f547e8026400032f563d9%20%22%20meta-oe%20%E5%85%83%E5%A4%9A%E5%AA%92%E4%BD%93%20meta-python%20%3D%20%22%20Head%3A%201750c66ae8e4268c472c0b2b94748AD59AD9c0b2b94748AD59AD%206ef866D%20%22%20%3CBR%20%2F%3E%20meta-freescale%20%3D%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%22%20%E5%A4%B4%3A0a73d1bdd7713a6189482e463c98043c9939a2a2%20%22%20meta-freescale-3rdparty%20%3D%20%22%20%E5%A4%B4%3A7725256e3859b62f1ff201db7f2cf7026c17656D%20%22%20meta-freescale-%E5%8F%91%E8%A1%8C%E7%89%88%20%3D%20%E5%A4%B4%3A4f1f101ebab5eb054bbedbedbedbed10b247fc0547b30793%20%22%20meta-imx-bsp%20meta-imx-sdk%20meta-imx-ml%20meta-imx-v2x%20%3D%20%22%20%E5%A4%B4%3A773c0049c3b35af8f5b5bdf8da78%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%22a6236a4fc184%20%22%20%3CBR%20%2F%3E%20meta-nxp-demo-experience%20%3D%20%22%20%E5%A4%B4%3Adb34fa86ad5f3c0d9c0a68f5f5f20240c04f2bfb%20%22%20meta-Arm%20meta-Arm%20meta-Arm-toolchain%20%3D%20%22%20head%3A%204d22f982bce8df6f6f6f8f8c4d11845c47a4d39f961cc47a4d39f961cc4c961cc47a4d39f961cc4c966%20%22%20meta-chromium%20%3D%20%22%20%E5%A4%B4%3Adc31889c0899971def535dc1c040edf18bc16691%20%22%20meta-clang%20%3D%20%22%20HEAD%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3A9b08495e6bcef524789aefb6a7cc80fdfd2ff409%20%22%20%E5%85%83%E5%9C%B0%E7%B2%BE%E5%85%83%E7%BD%91%E7%BB%9C%E5%85%83%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%20%3D%20%22%20head%3A%201750c66ae8e4268c472c0b2b94748a59d6ef866D%20%22%20meta-qt6%20%3D%20head%20%22%3A%20fd054cf5fc1b50df6d%2050cd606384ab338c6d9206437%20%22%20meta-parsec%20meta-tpm%20%3D%20%22%20%E5%A4%B4%3A070a1e82cc59424d230a23c0b2a104b01fbaa2AD%20%2030%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3Espan%26gt%3B%20%3CBR%20%2F%3E%20meta-virtualization%20%3D%20%22%20head%3A%209e92984ff47b3ca2106b1d27a93af061b28d1e8a%20%22%3C%2FP%3E%0A%3CP%3E%E5%88%9D%E5%A7%8B%E5%8C%96%E4%BB%BB%E5%8A%A1%EF%BC%9A100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%20Time%3A%200%3A00%3A06%3CBR%20%2F%3ESstate%20summary%3A%20Wanted%203349%20Local%200%20Mirrors%200%20Missed%203349%20Current%204781%20(0%25%20match%2C%2058%25%20complete)%3CBR%20%2F%3ENOTE%3A%20Executing%20Tasks%3CBR%20%2F%3ENOTE%3A%20Tasks%20Summary%3A%20Attempted%2017993%20tasks%20of%20which%2013736%20didn't%20need%20to%20be%20run%20and%20all%20succeeded.%3C%2FP%3E%0A%3CP%3E%E6%91%98%E8%A6%81%EF%BC%9A%20%E6%9C%89%202%20%E6%9D%A1%E8%AD%A6%E5%91%8A%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%0A%3CP%3E%E5%93%88%E7%BB%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2153192%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20IMX8%20%20Plus%20%22Creating%20the%20BSP%20and%20Yocto%20build%20environment%22%20%20compile%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2153192%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%81%A9%E6%99%BA%E6%B5%A6%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%A4%A7%E5%A4%9A%E6%95%B0%E6%97%B6%E5%80%99%EF%BC%8C%E6%88%91%E5%9C%A8%E7%89%88%E6%9C%AC%E8%BF%99%E4%BA%9B%E9%95%9C%E5%83%8F%EF%BC%88fsl-image-machine-t%20%3CBR%20%2F%3E%20est%E3%80%81imx-image-mage-mage-full%E3%80%81imx-image-full%EF%BC%89%E6%97%B6%E9%83%BD%E4%BC%9A%E9%81%87%E5%88%B0%20bitbake%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E8%BF%9E%E6%8E%A5%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%86%E6%98%AF%E4%B8%BA%E8%BF%99%E4%BA%9B%E5%9B%BE%E5%83%8F%EF%BC%88imx-image-core%E3%80%81core-image-base%EF%BC%89%E7%89%88%E6%9C%AC%E6%98%AF%E5%8F%AF%E4%BB%A5%E7%9A%84%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%9C%A8%E7%89%88%E6%9C%AC%E8%BF%99%E4%BA%9B%E6%98%A0%E5%83%8F%EF%BC%88fsl-image-mache-machine-test%E3%80%81imx-image-full%EF%BC%89%E6%97%B6%EF%BC%8C%E5%AE%83%E6%98%AF%E4%B8%BA%20Vulkan%20%E5%92%8C%20OpenCV%20lib%20%E7%89%88%E6%9C%AC%EF%BC%8C%E5%90%8E%E8%80%85%E6%97%A0%E6%B3%95%E7%94%B1%20bitbake%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E7%89%88%E6%9C%AC%E3%80%82%E4%BD%A0%E8%BF%98%E6%9C%89%E5%85%B6%E4%BB%96%E5%A6%82%E4%BD%95%E8%BF%9B%E8%A1%8C%E4%BC%98%E5%8C%96%E4%BB%A5%E4%B8%BA%20Vulkan%20%E5%92%8C%20OpenCV%20%E7%89%88%E6%9C%AC%E4%BD%8D%E5%9B%9E%E7%9A%84%E6%96%87%E6%A1%A3%E5%90%97%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E7%9A%84%E5%A4%84%E7%90%86%E5%99%A8%E6%9C%89%204%20%E4%B8%AA%20CPU%20%E5%86%85%E6%A0%B8%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%9C%A8%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E4%B8%8A%E6%8F%90%E4%BE%9B%E5%B8%AE%E5%8A%A9%E5%90%97%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E8%AF%B7%E6%9F%A5%E7%9C%8B%E4%BB%A5%E4%B8%8B%E6%97%A5%E5%BF%97%EF%BC%9A%3C%2FP%3E%3CP%3E******************Logs***********************%3C%2FP%3E%3CP%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E6%82%A8%E7%9A%84%20conf%2Fbblayers.conf%20%E5%B7%B2%E8%87%AA%E5%8A%A8%E6%9B%B4%E6%96%B0%E3%80%82%3CBR%20%2F%3E%E5%8A%A0%E8%BD%BD%E7%BC%93%E5%AD%98%EF%BC%9A100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%20%E6%97%B6%E9%97%B4%EF%BC%9A0%3A00%3A01%3CBR%20%2F%3E%E4%BB%8E%E4%BE%9D%E8%B5%96%E5%85%B3%E7%B3%BB%E7%BC%93%E5%AD%98%E4%B8%AD%E5%8A%A0%E8%BD%BD%E4%BA%86%205449%20%E4%B8%AA%E6%9D%A1%E7%9B%AE%E3%80%82%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E8%A7%A3%E5%86%B3%E4%BB%BB%E4%BD%95%E7%BC%BA%E5%A4%B1%E7%9A%84%E4%BB%BB%E5%8A%A1%E9%98%9F%E5%88%97%E4%BE%9D%E8%B5%96%E5%85%B3%E7%B3%BB%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E9%A6%96%E9%80%89%E7%9A%84%20llvm-native%2017.0.6%20%E7%89%88%E6%9C%AC%E4%B8%8D%E5%8F%AF%E7%94%A8%EF%BC%88%E9%92%88%E5%AF%B9%20llvm-native%20%E9%A1%B9%E7%9B%AE%EF%BC%89%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E5%8F%AF%E7%94%A8%E7%9A%84%20llvm-native%20%E7%89%88%E6%9C%AC%EF%BC%9A17.0.3%3C%2FP%3E%3CP%3E%E7%89%88%E6%9C%AC%E9%85%8D%E7%BD%AE%EF%BC%9A%3CBR%20%2F%3EBB_VERSION%20%3D%20%22%202.6.0%20%22%20%3CBR%20%2F%3EBUILD_SYS%20%3D%20%22x86_64-linux%22%3CBR%20%2F%3ENATIVELSBSTRING%20%3D%20%22%E9%80%9A%E7%94%A8%22%3CBR%20%2F%3ETARGET_SYS%20%3D%20%22aarch64-poky-linux%22%3CBR%20%2F%3EMACHINE%20%3D%20%22imx8mp-lpddr4-evk%22%3CBR%20%2F%3EDISTRO%20%3D%20%22fsl-imx-xwayland%22%3CBR%20%2F%3EDISTRO_VERSION%20%3D%20%226.6-nanbield%22%3CBR%20%2F%3ETUNE_FEATURES%20%3D%20%22%20aarch64%20armv8a%20crcrypto%20%22%20%3CBR%20%2F%3ETARGET_FPU%20%3D%20%22%20%22%20meta%20%3CBR%20%2F%3E%20meta-poky%20%3D%20%22%20Head%3A%20046b70083f3f3bc9e25f547e8026400032f563d9%20%22%20meta-oe%20%E5%85%83%E5%A4%9A%E5%AA%92%E4%BD%93%20meta-python%20%3D%20%22%20Head%3A%201750c66ae8e4268c472c0b2b94748AD59AD9c0b2b94748AD59AD%206ef866D%20%22%20%3CBR%20%2F%3E%20meta-freescale%20%3D%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%22%20%E5%A4%B4%3A0a73d1bdd7713a6189482e463c98043c9939a2a2%20%22%20meta-freescale-3rdparty%20%3D%20%22%20%E5%A4%B4%3A7725256e3859b62f1ff201db7f2cf7026c17656D%20%22%20meta-freescale-%E5%8F%91%E8%A1%8C%E7%89%88%20%3D%20%E5%A4%B4%3A4f1f101ebab5eb054bbedbedbedbed10b247fc0547b30793%20%22%20meta-imx-bsp%20meta-imx-sdk%20meta-imx-ml%20meta-imx-v2x%20%3D%20%22%20%E5%A4%B4%3A773c0049c3b35af8f5b5bdf8da78%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%22a6236a4fc184%20%22%20%3CBR%20%2F%3E%20meta-nxp-demo-experience%20%3D%20%22%20%E5%A4%B4%3Adb34fa86ad5f3c0d9c0a68f5f5f20240c04f2bfb%20%22%20meta-Arm%20meta-Arm%20meta-Arm-toolchain%20%3D%20%22%20head%3A%204d22f982bce8df6f6f6f8f8c4d11845c47a4d39f961cc47a4d39f961cc4c961cc47a4d39f961cc4c966%20%22%20meta-chromium%20%3D%20%22%20%E5%A4%B4%3Adc31889c0899971def535dc1c040edf18bc16691%20%22%20meta-clang%20%3D%20%22%20HEAD%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3A9b08495e6bcef524789aefb6a7cc80fdfd2ff409%20%22%20%E5%85%83%E5%9C%B0%E7%B2%BE%E5%85%83%E7%BD%91%E7%BB%9C%E5%85%83%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%20%3D%20%22%20head%3A%201750c66ae8e4268c472c0b2b94748a59d6ef866D%20%22%20meta-qt6%20%3D%20head%20%22%3A%20fd054cf5fc1b50df6d%2050cd606384ab338c6d9206437%20%22%20meta-parsec%20meta-tpm%20%3D%20%22%20%E5%A4%B4%3A070a1e82cc59424d230a23c0b2a104b01fbaa2AD%20%2030%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3Espan%26gt%3B%20%3CBR%20%2F%3E%20meta-virtualization%20%3D%20%22%20head%3A%209e92984ff47b3ca2106b1d27a93af061b28d1e8a%20%22%3C%2FP%3E%3CP%3E%E5%88%9D%E5%A7%8B%E5%8C%96%E4%BB%BB%E5%8A%A1%EF%BC%9A100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%20%E6%97%B6%E9%97%B4%EF%BC%9A0%3A00%3A08%3CBR%20%2F%3ESstate%20%E6%91%98%E8%A6%81%EF%BC%9AWanted%201071%20Local%202%20Mirrors%200%20Missed%201069%20Current%205652%20(0%25%20match%2C%2084%25%20complete)%3CBR%20%2F%3ENOTE%3A%20Executing%20Tasks%3CBR%20%2F%3ENOTE%3A%20No%20reply%20from%20server%20in%2030s%20(for%20command%20ping%20at%2022%3A27%3A39.389536)%3CBR%20%2F%3E%E7%AD%89%E5%BE%85%20bitbake%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E5%9B%9E%E5%A4%8D%E6%97%B6%E8%B6%85%E6%97%B6%20(60s%20at%2022%3A28%3A09.428551)%3CBR%20%2F%3Emiddepogudas%20%3Ca%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F251894%22%3E%40middepogudas%3C%2Fa%3E-ThinkPad-L14-gen-1%EF%BC%9A~%2Fdesktop%2Fdas%2Fproject%2Fimx-yocto-bsp%2Fbuild%24%20bitbake%20imx-image-multimedia%20%E6%B3%A8%E6%84%8F%EF%BC%9A%E6%AD%A3%E5%9C%A8%E9%87%8D%E6%96%B0%E8%BF%9E%E6%8E%A5%E5%88%B0%20bitbake%20%E6%9C%8D%E5%8A%A1%E5%99%A8...%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A30%20%E7%A7%92%E5%90%8E%E6%9C%8D%E5%8A%A1%E5%99%A8%E6%B2%A1%E6%9C%89%E5%9B%9E%E5%A4%8D%EF%BC%88%E5%AF%B9%E4%BA%8E%E5%91%BD%E4%BB%A4%20setFeatures%EF%BC%8C22%3A28%3A45.138%20306%EF%BC%89%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E9%87%8D%E8%AF%95%E6%9C%8D%E5%8A%A1%E5%99%A8%E8%BF%9E%E6%8E%A5%20(%231)...(22%3A29%3A15.167756)%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E8%BE%BE%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2150152%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20IMX8%20%20Plus%20%22Creating%20the%20BSP%20and%20Yocto%20build%20environment%22%20%20compile%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150152%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F251894%22%20target%3D%22_blank%22%3E%40middepogudas%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E4%B8%BB%E6%9C%BA%E4%BD%8D%E4%BA%8E%E5%85%AC%E5%8F%B8%E7%BD%91%E7%BB%9C%E5%86%85%EF%BC%8C%E8%AF%B7%E5%90%91%E5%85%AC%E5%8F%B8%E7%BD%91%E7%BB%9C%E7%AE%A1%E7%90%86%E5%91%98%E5%92%A8%E8%AF%A2%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%0A%3CP%3E%E5%93%88%E7%BB%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2150126%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20IMX8%20%20Plus%20%22Creating%20the%20BSP%20and%20Yocto%20build%20environment%22%20%20compile%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150126%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%81%A9%E6%99%BA%E6%B5%A6%E3%80%81%20%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%E4%BD%A0%E6%9C%89%E6%AD%A5%E9%AA%A4%E6%88%96%E6%96%B9%E6%B3%95%E6%9D%A5%E6%A3%80%E6%9F%A5%20%22%3CSPAN%3E%E7%BD%91%E7%BB%9C%E5%AE%89%E5%85%A8%E6%88%96%E4%BB%A3%E7%90%86%E6%9C%8D%E5%8A%A1%E5%99%A8%E5%87%BA%E7%8E%B0%3C%2FSPAN%3E%22%20%E5%90%97%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%AF%B7%E5%B8%AE%E5%8A%A9%E6%88%91%E4%BB%AC%E5%88%86%E4%BA%AB%E6%88%96%E6%8C%87%E5%AF%BC%E6%88%91%E4%BB%AC%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E8%BE%BE%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2150106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20IMX8%20%20Plus%20%22Creating%20the%20BSP%20and%20Yocto%20build%20environment%22%20%20compile%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%AF%B7%E6%A3%80%E6%9F%A5%E6%82%A8%E7%9A%84%E7%BD%91%E7%BB%9C%E9%97%AE%E9%A2%98%E6%98%AF%E5%90%A6%E5%AD%98%E5%9C%A8%E6%8F%90%E5%8F%96%E6%95%85%E9%9A%9C%EF%BC%8C%E6%98%AF%E5%90%A6%E5%AD%98%E5%9C%A8%E7%BD%91%E7%BB%9C%E5%AE%89%E5%85%A8%E6%88%96%E4%BB%A3%E7%90%86%E9%97%AE%E9%A2%98%EF%BC%9F%E5%8F%A6%E8%AF%B7%E6%A3%80%E6%9F%A5%E6%82%A8%E7%9A%84%E4%B8%BB%E6%9C%BA%E9%85%8D%E7%BD%AE%EF%BC%8C%E4%BB%A5%E5%A4%87%E7%AC%AC%E4%B8%80%E6%AC%A1%E5%9B%9E%E5%A4%8D%E6%97%B6%E5%8F%82%E8%80%83%E3%80%82%E4%B9%9F%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E5%BC%80%E5%A7%8B%E6%96%B0%E7%89%88%E6%9C%AC%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%0A%3CP%3E%E5%93%88%E7%BB%B4%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2150012%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20IMX8%20%20Plus%20%22Creating%20the%20BSP%20and%20Yocto%20build%20environment%22%20%20compile%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150012%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%81%A9%E6%99%BA%E6%B5%A6%E3%80%81%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E5%9B%9E%E6%9D%A5%EF%BC%8C%E8%AF%B7%E5%9C%A8%E4%B8%8B%E9%9D%A2%E6%89%BE%E5%88%B0%E7%B2%98%E8%B4%B4%E7%9A%84%E7%89%88%E6%9C%AC%E6%97%A5%E5%BF%97%E3%80%82%E4%BB%8D%E7%84%B6%E9%81%87%E5%88%B0%20bitback%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E8%BF%9E%E6%8E%A5%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E9%87%8D%E5%90%AF%E4%BA%86%E5%87%A0%E6%AC%A1%E7%94%B5%E8%84%91%E3%80%82%E6%88%91%E6%B2%A1%E6%9C%89%E6%89%BE%E5%88%B0%E4%BB%BB%E4%BD%95%E4%BD%8D%E7%83%A4%E8%BF%87%E7%A8%8B%E3%80%82%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E5%91%8A%E7%9F%A5%E5%A6%82%E4%BD%95%E8%BF%9B%E4%B8%80%E6%AD%A5%E5%BC%80%E5%B1%95%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E***********************Logs********%3C%2FP%3E%3CP%3Edasmiddepogu%20%40dasmiddepogu-ThinkPad-L14-gen-1%EF%BC%9A~%2Fdesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-yocto-%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%2Fbuild%24%20bitbake%20imx-image-full-c%20populate_sdk%20%E6%B3%A8%E6%84%8F%EF%BC%9A%E4%BD%A0%E7%9A%84%20conf%2Fblayers.conf%20%E5%B7%B2%E8%87%AA%E5%8A%A8%E6%9B%B4%E6%96%B0%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%8A%A0%E8%BD%BD%E7%BC%93%E5%AD%98%EF%BC%9A100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%20%E6%97%B6%E9%97%B4%EF%BC%9A0%3A00%3A01%3CBR%20%2F%3E%E4%BB%8E%E4%BE%9D%E8%B5%96%E5%85%B3%E7%B3%BB%E7%BC%93%E5%AD%98%E4%B8%AD%E5%8A%A0%E8%BD%BD%E4%BA%86%205449%20%E4%B8%AA%E6%9D%A1%E7%9B%AE%E3%80%82%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E8%A7%A3%E5%86%B3%E4%BB%BB%E4%BD%95%E7%BC%BA%E5%A4%B1%E7%9A%84%E4%BB%BB%E5%8A%A1%E9%98%9F%E5%88%97%E4%BE%9D%E8%B5%96%E5%85%B3%E7%B3%BB%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E9%A6%96%E9%80%89%E7%9A%84%20llvm-native%2017.0.6%20%E7%89%88%E6%9C%AC%E4%B8%8D%E5%8F%AF%E7%94%A8%EF%BC%88%E9%92%88%E5%AF%B9%20llvm-native%20%E9%A1%B9%E7%9B%AE%EF%BC%89%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%EF%BC%9A%E5%8F%AF%E7%94%A8%E7%9A%84%20llvm-native%20%E7%89%88%E6%9C%AC%EF%BC%9A17.0.3%3C%2FP%3E%3CP%3E%E7%89%88%E6%9C%AC%E9%85%8D%E7%BD%AE%EF%BC%9A%3CBR%20%2F%3EBB_VERSION%20%3D%20%22%202.6.0%20%22%20%3CBR%20%2F%3EBUILD_SYS%20%3D%20%22x86_64-linux%22%3CBR%20%2F%3ENATIVELSBSTRING%20%3D%20%22%E9%80%9A%E7%94%A8%22%3CBR%20%2F%3ETARGET_SYS%20%3D%20%22aarch64-poky-linux%22%3CBR%20%2F%3EMACHINE%20%3D%20%22imx8mp-lpddr4-evk%22%3CBR%20%2F%3EDISTRO%20%3D%20%22fsl-imx-xwayland%22%3CBR%20%2F%3EDISTRO_VERSION%20%3D%20%226.6-nanbield%22%3CBR%20%2F%3ETUNE_FEATURES%20%3D%20%22%20aarch64%20armv8a%20crcrypto%20%22%20%3CBR%20%2F%3ETARGET_FPU%20%3D%20%22%20%22%20meta%20%3CBR%20%2F%3E%20meta-poky%20%3D%20%22%20Head%3A%20046b70083f3f3bc9e25f547e8026400032f563d9%20%22%20meta-oe%20%E5%85%83%E5%A4%9A%E5%AA%92%E4%BD%93%20meta-python%20%3D%20%22%20Head%3A%201750c66ae8e4268c472c0b2b94748AD59AD9c0b2b94748AD59AD%206ef866D%20%22%20%3CBR%20%2F%3E%20meta-freescale%20%3D%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%22%20%E5%A4%B4%3A0a73d1bdd7713a6189482e463c98043c9939a2a2%20%22%20meta-freescale-3rdparty%20%3D%20%22%20%E5%A4%B4%3A7725256e3859b62f1ff201db7f2cf7026c17656D%20%22%20meta-freescale-%E5%8F%91%E8%A1%8C%E7%89%88%20%3D%20%E5%A4%B4%3A4f1f101ebab5eb054bbedbedbedbed10b247fc0547b30793%20%22%20meta-imx-bsp%20meta-imx-sdk%20meta-imx-ml%20meta-imx-v2x%20%3D%20%22%20%E5%A4%B4%3A773c0049c3b35af8f5b5bdf8da78%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%22a6236a4fc184%20%22%20%3CBR%20%2F%3E%20meta-nxp-demo-experience%20%3D%20%22%20%E5%A4%B4%3Adb34fa86ad5f3c0d9c0a68f5f5f20240c04f2bfb%20%22%20meta-Arm%20meta-Arm%20meta-Arm-toolchain%20%3D%20%22%20head%3A%204d22f982bce8df6f6f6f8f8c4d11845c47a4d39f961cc47a4d39f961cc4c961cc47a4d39f961cc4c966%20%22%20meta-chromium%20%3D%20%22%20%E5%A4%B4%3Adc31889c0899971def535dc1c040edf18bc16691%20%22%20meta-clang%20%3D%20%22%20HEAD%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3A9b08495e6bcef524789aefb6a7cc80fdfd2ff409%20%22%20%E5%85%83%E5%9C%B0%E7%B2%BE%E5%85%83%E7%BD%91%E7%BB%9C%E5%85%83%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%20%3D%20%22%20head%3A%201750c66ae8e4268c472c0b2b94748a59d6ef866D%20%22%20meta-qt6%20%3D%20head%20%22%3A%20fd054cf5fc1b50df6d%2050cd606384ab338c6d9206437%20%22%20meta-parsec%20meta-tpm%20%3D%20%22%20%E5%A4%B4%3A070a1e82cc59424d230a23c0b2a104b01fbaa2AD%20%2030%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3Espan%26gt%3B%20%3CBR%20%2F%3E%20meta-virtualization%20%3D%20%22%20head%3A%209e92984ff47b3ca2106b1d27a93af061b28d1e8a%20%22%3C%2FP%3E%3CP%3E%E5%88%9D%E5%A7%8B%E5%8C%96%E4%BB%BB%E5%8A%A1%EF%BC%9A100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%20Time%3A%200%3A00%3A19%3CBR%20%2F%3ESstate%20summary%3A%20Wanted%207008%20Local%200%20Mirrors%200%20Missed%207008%20Current%201122%20(0%25%20match%2C%2013%25%20complete)%3CBR%20%2F%3ENOTE%3A%20Executing%20Tasks%3CBR%20%2F%3EWARNING%3A%20llvm-project-source-17.0.6-17.0.6-r0%20do_fetch%EF%BC%9AFailed%20to%20fetch%20URL%20git%3A%2F%2Fgithub.com%2Fllvm%2Fllvm-project%3Bprotocol%3Dhttps%3Bbranch%3Drelease%2F17.x%E3%80%81%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20MIRRORS%EF%BC%88%E5%A6%82%E6%9E%9C%E5%8F%AF%E7%94%A8%EF%BC%89%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E6%9C%8D%E5%8A%A1%E5%99%A8%E5%9C%A8%2030%20%E7%A7%92%E5%86%85%E6%B2%A1%E6%9C%89%E5%9B%9E%E5%A4%8D%EF%BC%88%E5%91%BD%E4%BB%A4%20ping%20%E6%97%B6%E9%97%B4%E4%B8%BA%2001%3A48%3A27.402426%3CBR%20%2F%3E%E7%AD%89%E5%BE%85%20bitbake%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E5%9B%9E%E5%A4%8D%E6%97%B6%E8%B6%85%E6%97%B6%20(60s%20at%2001%3A48%3A57.437217)%3CBR%20%2F%3Edasmiddepogu%20%40dasmiddepogu-ThinkPad-l14-gen-1%EF%BC%9A~%2Fdesktop%2Fdas%2Fproject%2Fimx-yocto-bsp%2Fbuild%24%20ps%20ps%3CBR%20%2F%3E%20PID%20TTY%20%E6%97%B6%E9%97%B4%20CMD%3CBR%20%2F%3E%202919%20pts%2F0%2000%3A00%3A00%20bash%3CBR%20%2F%3E%20213920%20pts%2F0%2000%3A00%3A00%20ps%3CBR%20%2F%3E%3CA%20href%3D%22mailto%3Adasmiddepogu%40dasmiddepogu-ThinkPad-L14-Gen-1%3A~%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-yocto-bsp%2Fbuild%24%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%20dasmiddepogu%20%40dasmiddepogu-Thinkpad-l14-gen-1%EF%BC%9A~%2Fdesktop%2Fdas%2FProject%2FiMX-Gen-1%EF%BC%9A~%2Fdesktop%2Fdas%2FProject%2FiMX-project%2FiMX-Gen-1%EF%BC%9A~%2Fdesktop8mpluseek%2Fimx-yocto-bsp%2Fbuild%24%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EDas%20Middepogu%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2149634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20IMX8%20%20Plus%20%22Creating%20the%20BSP%20and%20Yocto%20build%20environment%22%20%20compile%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2149634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E8%AF%A5%E9%94%99%E8%AF%AF%E6%8F%90%E7%A4%BA%E6%97%A0%E6%B3%95%E8%BF%9E%E6%8E%A5%20bitbake%20%E6%9C%8D%E5%8A%A1%E5%99%A8%EF%BC%8C%E5%8E%9F%E5%9B%A0%E5%8F%AF%E8%83%BD%E6%98%AF%20bitbake%20%E5%AE%88%E6%8A%A4%E8%BF%9B%E7%A8%8B%E6%8C%82%E8%B5%B7%E6%88%96%E5%89%A9%E4%BD%99%E7%9A%84%E5%A5%97%E6%8E%A5%E5%AD%97%E6%96%87%E4%BB%B6%E3%80%82%E4%BD%A0%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E5%B0%86%E5%85%B6%E6%9D%80%E6%AD%BB%E7%84%B6%E5%90%8E%E6%B8%85%E7%90%86%E7%89%88%E6%9C%AC%E7%9B%AE%E5%BD%95%E4%B8%8B%E7%9A%84%E4%B8%80%E4%BA%9B%E9%94%81%E5%AE%9A%E6%96%87%E4%BB%B6%E7%84%B6%E5%90%8E%E9%87%8D%E5%90%AF%E4%B8%BB%E6%9C%BA%EF%BC%8C%E7%84%B6%E5%90%8E%E5%86%8D%E6%AC%A1%E8%BF%90%E8%A1%8C%20%22%20%3CSPAN%3Ebitbake%20imx-image-full%20-c%20populate_sdk%3C%2FSPAN%3E%20%22%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%0A%3CP%3E%E5%93%88%E7%BB%B4%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2149497%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20IMX8%20%20Plus%20%22Creating%20the%20BSP%20and%20Yocto%20build%20environment%22%20%20compile%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2149497%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%81%A9%E6%99%BA%E6%B5%A6%E3%80%81%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E4%BD%A0%E5%9B%9E%E6%9D%A5%E8%AE%A8%E8%AE%BA%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E4%BB%8D%E7%84%B6%E9%9D%A2%E4%B8%B4%E4%B8%80%E4%BA%9B%E7%89%88%E6%9C%AC%E9%97%AE%E9%A2%98...%22%20%E6%B3%A8%E6%84%8F%EF%BC%9A%E6%AD%A3%E5%9C%A8%E9%87%8D%E6%96%B0%E8%BF%9E%E6%8E%A5%E5%88%B0%20bitbake%20%E6%9C%8D%E5%8A%A1%E5%99%A8...%22.%E3%80%82%E8%AF%B7%E5%9C%A8%E4%B8%8B%E9%9D%A2%E6%89%BE%E5%88%B0%E6%97%A5%E5%BF%97%3C%2FP%3E%3CP%3E%E8%AF%B7%E4%BB%8E%E8%BF%99%E4%B8%AA%E9%93%BE%E6%8E%A5%3CA%20href%3D%22https%3A%2F%2Fdocs.nxp.com%2Fbundle%2FAN13712%2Fpage%2Ftopics%2Fcreate_the_yocto_build_environment.html)%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E(https%3A%2F%2Fdocs.nxp.com%2Fbundle%2FAN13712%2Fpage%2Ftopics%2Fcreate_the_yocto_build_environment.html)%3C%2FA%3E%E6%89%BE%E5%88%B0%E6%88%91%E6%89%80%E9%81%B5%E5%BE%AA%E7%9A%84%E6%AD%A5%E9%AA%A4%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%B0%B1%E5%A6%82%E4%BD%95%E8%BF%9B%E4%B8%80%E6%AD%A5%E5%BC%80%E5%B1%95%E5%B7%A5%E4%BD%9C%E6%8F%90%E5%87%BA%E5%BB%BA%E8%AE%AE%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E**********************************%E7%89%88%E6%9C%AC%E6%97%A5%E5%BF%97***************************************%3C%2FP%3E%3CP%3Edasmiddepogu%20%40dasmiddepogu-ThinkPad-L14-Gen-1%EF%BC%9A~%2Fdesktop%2Fdas%2Fproject%2Fimx8mpluseek%2Fimx-yocto-bsp%2Fbuild%24%20dasmiddepogu%20%40dasmiddepogu-ThinkPad-L14-Gen-1%EF%BC%9A~%2Fdesktop%2Fdas%2Fproject%2Fimx-yocto-bsp%2Fbuild%24%20bitbake%20imx-Image-full-cpulated-1%EF%BC%9A~%2Fdesktop%2Fdas%2Fproject%2Fimx-yocto-bsp%2Fbuild%24%20bitbake%20_sdk%20%E6%B3%A8%E6%84%8F%3CBR%20%2F%3E%EF%BC%9A%E6%AD%A3%E5%9C%A8%E9%87%8D%E6%96%B0%E8%BF%9E%E6%8E%A5%E5%88%B0%20bitbake%20%E6%9C%8D%E5%8A%A1%E5%99%A8...%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E6%AD%A3%E5%9C%A8%E9%87%8D%E8%AF%95%E6%9C%8D%E5%8A%A1%E5%99%A8%E8%BF%9E%E6%8E%A5%20(%231)...%EF%BC%88%E5%9B%9E%E6%BA%AF%E4%BF%A1%E6%81%AF%EF%BC%88%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E9%80%9A%E8%AF%9D%EF%BC%89%EF%BC%9A%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%20%22%20%2Fhome%2Fdasmiddepogu%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-yocto-bsp%2Fsources%2F%E5%8F%82%E8%80%83%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%81%E7%B3%BB%E7%BB%9F%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E3%80%82%2Fbitbake%2Flib%2Fbb%2Fmain.py%20%22%EF%BC%8C%E7%AC%AC%20487%20%E8%A1%8C%EF%BC%8C%E4%BD%8D%E4%BA%8E%20setup_bitbake%20server_connection%20%3D%20bb.server.process.%20%3CBR%20%2F%3E%20connectProcessServer%EF%BC%88sockname%EF%BC%8Cfeatureset)%20%3CBR%20%2F%3E%20%E6%96%87%E4%BB%B6%20%22%20%2Fhome%2Fdasmiddepogu%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-yocto-bsp%2Fsources%2F%E5%8F%82%E8%80%83%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%81%E7%B3%BB%E7%BB%9F%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E3%80%82%2Fbitbake%2Flib%2Fbb%2Fserver%2Fprocess.py%20%22%EF%BC%8C%E7%AC%AC%20686%20%E8%A1%8C%EF%BC%8C%E4%BD%8D%E4%BA%8E%20ConnectProcess%20%3CBR%20%2F%3E%20Server%20sock.connect%20(os.path.basename%20(sockname))%20%3CBR%20%2F%3EBlockingIOError%EF%BC%9A%5BErrno%2011%5D%20%E8%B5%84%E6%BA%90%E6%9A%82%E6%97%B6%E4%B8%8D%E5%8F%AF%E7%94%A8%3CBR%20%2F%3E%2C%2008%3A00%3A49.857906)%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E6%AD%A3%E5%9C%A8%E9%87%8D%E6%96%B0%E8%BF%9E%E6%8E%A5%E5%88%B0%20bitbake%20%E6%9C%8D%E5%8A%A1%E5%99%A8...%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E6%AD%A3%E5%9C%A8%E9%87%8D%E8%AF%95%E6%9C%8D%E5%8A%A1%E5%99%A8%E8%BF%9E%E6%8E%A5%20(%232)...%EF%BC%88%E5%9B%9E%E6%BA%AF%E4%BF%A1%E6%81%AF%EF%BC%88%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E9%80%9A%E8%AF%9D%EF%BC%89%EF%BC%9A%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%20%22%20%2Fhome%2Fdasmiddepogu%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-yocto-bsp%2Fsources%2F%E5%8F%82%E8%80%83%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%81%E7%B3%BB%E7%BB%9F%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E3%80%82%2Fbitbake%2Flib%2Fbb%2Fmain.py%20%22%EF%BC%8C%E7%AC%AC%20487%20%E8%A1%8C%EF%BC%8C%E4%BD%8D%E4%BA%8E%20setup_bitbake%20server_connection%20%3D%20bb.server.process.%20%3CBR%20%2F%3E%20connectProcessServer%EF%BC%88sockname%EF%BC%8Cfeatureset)%20%3CBR%20%2F%3E%20%E6%96%87%E4%BB%B6%20%22%20%2Fhome%2Fdasmiddepogu%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-yocto-bsp%2Fsources%2F%E5%8F%82%E8%80%83%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%81%E7%B3%BB%E7%BB%9F%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E3%80%82%2Fbitbake%2Flib%2Fbb%2Fserver%2Fprocess.py%20%22%EF%BC%8C%E7%AC%AC%20686%20%E8%A1%8C%EF%BC%8C%E4%BD%8D%E4%BA%8E%20ConnectProcess%20%3CBR%20%2F%3E%20Server%20sock.connect%20(os.path.basename%20(sockname))%20%3CBR%20%2F%3EBlockingIOError%EF%BC%9A%5BErrno%2011%5D%20%E8%B5%84%E6%BA%90%E6%9A%82%E6%97%B6%E4%B8%8D%E5%8F%AF%E7%94%A8%3CBR%20%2F%3E%2C%2008%3A00%3A49.858338)%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E6%AD%A3%E5%9C%A8%E9%87%8D%E6%96%B0%E8%BF%9E%E6%8E%A5%E5%88%B0%20bitbake%20%E6%9C%8D%E5%8A%A1%E5%99%A8...%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E6%AD%A3%E5%9C%A8%E9%87%8D%E8%AF%95%E6%9C%8D%E5%8A%A1%E5%99%A8%E8%BF%9E%E6%8E%A5%20(%233)...%EF%BC%88%E5%9B%9E%E6%BA%AF%E4%BF%A1%E6%81%AF%EF%BC%88%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E9%80%9A%E8%AF%9D%EF%BC%89%EF%BC%9A%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%20%22%20%2Fhome%2Fdasmiddepogu%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-yocto-bsp%2Fsources%2F%E5%8F%82%E8%80%83%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%81%E7%B3%BB%E7%BB%9F%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E3%80%82%2Fbitbake%2Flib%2Fbb%2Fmain.py%20%22%EF%BC%8C%E7%AC%AC%20487%20%E8%A1%8C%EF%BC%8C%E4%BD%8D%E4%BA%8E%20setup_bitbake%20server_connection%20%3D%20bb.server.process.%20%3CBR%20%2F%3E%20connectProcessServer%EF%BC%88sockname%EF%BC%8Cfeatureset)%20%3CBR%20%2F%3E%20%E6%96%87%E4%BB%B6%20%22%20%2Fhome%2Fdasmiddepogu%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-yocto-bsp%2Fsources%2F%E5%8F%82%E8%80%83%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%81%E7%B3%BB%E7%BB%9F%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E3%80%82%2Fbitbake%2Flib%2Fbb%2Fserver%2Fprocess.py%20%22%EF%BC%8C%E7%AC%AC%20686%20%E8%A1%8C%EF%BC%8C%E4%BD%8D%E4%BA%8E%20ConnectProcess%20%3CBR%20%2F%3E%20Server%20sock.connect%20(os.path.basename%20(sockname))%20%3CBR%20%2F%3EBlockingIOError%EF%BC%9A%5BErrno%2011%5D%20%E8%B5%84%E6%BA%90%E6%9A%82%E6%97%B6%E4%B8%8D%E5%8F%AF%E7%94%A8%3CBR%20%2F%3E%2C%2008%3A00%3A49.858697)%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E6%AD%A3%E5%9C%A8%E9%87%8D%E6%96%B0%E8%BF%9E%E6%8E%A5%E5%88%B0%20bitbake%20%E6%9C%8D%E5%8A%A1%E5%99%A8...%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E6%AD%A3%E5%9C%A8%E9%87%8D%E8%AF%95%E6%9C%8D%E5%8A%A1%E5%99%A8%E8%BF%9E%E6%8E%A5%20(%234)...%EF%BC%88%E5%9B%9E%E6%BA%AF%E4%BF%A1%E6%81%AF%EF%BC%88%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E9%80%9A%E8%AF%9D%EF%BC%89%EF%BC%9A%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%20%22%2Fhome%2Fdasmiddepogu%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-yocto-bsp%2Fsources%2F%E5%8F%82%E8%80%83%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%81%E7%B3%BB%E7%BB%9F%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E3%80%82%2Fbitbake%2Flib%2Fbb%2Fmain.py%22%EF%BC%8C%E7%AC%AC%20487%20%E8%A1%8C%EF%BC%8C%E4%BD%8D%E4%BA%8E%20setup_bitbake%20server_connection%20%3D%20bb.server.process.%20%3CBR%20%2F%3E%20connectProcessServer%EF%BC%88sockname%EF%BC%8Cfeatureset)%20%3CBR%20%2F%3E%20%E6%96%87%E4%BB%B6%20%22%20%2Fhome%2Fdasmiddepogu%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-yocto-bsp%2Fsources%2F%E5%8F%82%E8%80%83%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%81%E7%B3%BB%E7%BB%9F%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E3%80%82%2Fbitbake%2Flib%2Fbb%2Fserver%2Fprocess.py%20%22%EF%BC%8C%E7%AC%AC%20686%20%E8%A1%8C%EF%BC%8C%E4%BD%8D%E4%BA%8E%20ConnectProcess%20%3CBR%20%2F%3E%20Server%20sock.connect%20(os.path.basename%20(sockname))%20%3CBR%20%2F%3EBlockingIOError%EF%BC%9A%5BErrno%2011%5D%20%E8%B5%84%E6%BA%90%E6%9A%82%E6%97%B6%E4%B8%8D%E5%8F%AF%E7%94%A8%3CBR%20%2F%3E%2C%2008%3A00%3A49.859044)%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E6%AD%A3%E5%9C%A8%E9%87%8D%E6%96%B0%E8%BF%9E%E6%8E%A5%E5%88%B0%20bitbake%20%E6%9C%8D%E5%8A%A1%E5%99%A8...%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E6%AD%A3%E5%9C%A8%E9%87%8D%E8%AF%95%E6%9C%8D%E5%8A%A1%E5%99%A8%E8%BF%9E%E6%8E%A5%20(%235)...%EF%BC%88%E5%9B%9E%E6%BA%AF%E4%BF%A1%E6%81%AF%EF%BC%88%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E9%80%9A%E8%AF%9D%EF%BC%89%EF%BC%9A%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%20%22%20%2Fhome%2Fdasmiddepogu%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-yocto-bsp%2Fsources%2F%E5%8F%82%E8%80%83%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%81%E7%B3%BB%E7%BB%9F%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E3%80%82%2Fbitbake%2Flib%2Fbb%2Fmain.py%20%22%EF%BC%8C%E7%AC%AC%20487%20%E8%A1%8C%EF%BC%8C%E4%BD%8D%E4%BA%8E%20setup_bitbake%20server_connection%20%3D%20bb.server.process.%20%3CBR%20%2F%3E%20connectProcessServer%EF%BC%88sockname%EF%BC%8Cfeatureset)%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%20%22%2Fhome%2Fdasmiddepogu%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-yocto-bsp%2Fsources%2F%E5%8F%82%E8%80%83%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%81%E7%B3%BB%E7%BB%9F%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E3%80%82%2Fbitbake%2Flib%2Fbb%2Fserver%2Fprocess.py%22%2C%20%E7%AC%AC%20686%20%E8%A1%8C%EF%BC%8C%E4%BD%8D%E4%BA%8E%20ConnectProcessServer%3CBR%20%2F%3Esock.connect(os.path.basename(sockname))%3CBR%20%2F%3EBlockingIOError%EF%BC%9A%5BErrno%2011%5D%20%E8%B5%84%E6%BA%90%E6%9A%82%E6%97%B6%E4%B8%8D%E5%8F%AF%E7%94%A8%3CBR%20%2F%3E%2C%2008%3A00%3A54.865054)%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E6%AD%A3%E5%9C%A8%E9%87%8D%E6%96%B0%E8%BF%9E%E6%8E%A5%E5%88%B0%20bitbake%20%E6%9C%8D%E5%8A%A1%E5%99%A8...%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E6%AD%A3%E5%9C%A8%E9%87%8D%E8%AF%95%E6%9C%8D%E5%8A%A1%E5%99%A8%E8%BF%9E%E6%8E%A5%20(%236)...%EF%BC%88%E5%9B%9E%E6%BA%AF%E4%BF%A1%E6%81%AF%EF%BC%88%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E9%80%9A%E8%AF%9D%EF%BC%89%EF%BC%9A%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%20%22%2Fhome%2Fdasmiddepogu%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-yocto-bsp%2Fsources%2F%E5%8F%82%E8%80%83%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%81%E7%B3%BB%E7%BB%9F%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E3%80%82%2Fbitbake%2Flib%2Fbb%2Fmain.py%22%2C%20%E7%AC%AC%20487%20%E8%A1%8C%EF%BC%8C%E4%BD%8D%E4%BA%8E%20setup_bitbake%3CBR%20%2F%3Eserver_connection%20%3D%20bb.server.process.connectProcessServer(sockname%2C%20featureset)%20%3CBR%20%2F%3E%20%E6%96%87%E4%BB%B6%20%22%20%2Fhome%2Fdasmiddepogu%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-yocto-bsp%2Fsources%2F%E5%8F%82%E8%80%83%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%81%E7%B3%BB%E7%BB%9F%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E3%80%82%2Fbitbake%2Flib%2Fbb%2Fserver%2Fprocess.py%20%22%EF%BC%8C%E7%AC%AC%20686%20%E8%A1%8C%EF%BC%8C%E4%BD%8D%E4%BA%8E%20ConnectProcess%20%3CBR%20%2F%3E%20Server%20sock.connect%20(os.path.basename%20(sockname))%20%3CBR%20%2F%3EBlockingIOError%EF%BC%9A%5BErrno%2011%5D%20%E8%B5%84%E6%BA%90%E6%9A%82%E6%97%B6%E4%B8%8D%E5%8F%AF%E7%94%A8%3CBR%20%2F%3E%2C%2008%3A00%3A59.870058)%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E6%AD%A3%E5%9C%A8%E9%87%8D%E6%96%B0%E8%BF%9E%E6%8E%A5%E5%88%B0%20bitbake%20%E6%9C%8D%E5%8A%A1%E5%99%A8...%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E6%AD%A3%E5%9C%A8%E9%87%8D%E8%AF%95%E6%9C%8D%E5%8A%A1%E5%99%A8%E8%BF%9E%E6%8E%A5%20(%237)...%EF%BC%88%E5%9B%9E%E6%BA%AF%E4%BF%A1%E6%81%AF%EF%BC%88%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E9%80%9A%E8%AF%9D%EF%BC%89%EF%BC%9A%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%20%22%20%2Fhome%2Fdasmiddepogu%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-yocto-bsp%2Fsources%2F%E5%8F%82%E8%80%83%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%81%E7%B3%BB%E7%BB%9F%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E3%80%82%2Fbitbake%2Flib%2Fbb%2Fmain.py%20%22%EF%BC%8C%E7%AC%AC%20487%20%E8%A1%8C%EF%BC%8C%E4%BD%8D%E4%BA%8E%20setup_bitbake%20server_connection%20%3D%20bb.server.process.%20%3CBR%20%2F%3E%20connectProcessServer%EF%BC%88sockname%EF%BC%8Cfeatureset)%20%3CBR%20%2F%3E%20%E6%96%87%E4%BB%B6%20%22%20%2Fhome%2Fdasmiddepogu%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-yocto-bsp%2Fsources%2F%E5%8F%82%E8%80%83%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%81%E7%B3%BB%E7%BB%9F%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E3%80%82%2Fbitbake%2Flib%2Fbb%2Fserver%2Fprocess.py%20%22%EF%BC%8C%E7%AC%AC%20686%20%E8%A1%8C%EF%BC%8C%E4%BD%8D%E4%BA%8E%20ConnectProcess%20%3CBR%20%2F%3E%20Server%20sock.connect%20(os.path.basename%20(sockname))%20%3CBR%20%2F%3EBlockingIOError%EF%BC%9A%5BErrno%2011%5D%20%E8%B5%84%E6%BA%90%E6%9A%82%E6%97%B6%E4%B8%8D%E5%8F%AF%E7%94%A8%3CBR%20%2F%3E%2C%2008%3A01%3A04.877760)%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E6%AD%A3%E5%9C%A8%E9%87%8D%E6%96%B0%E8%BF%9E%E6%8E%A5%E5%88%B0%20bitbake%20%E6%9C%8D%E5%8A%A1%E5%99%A8...%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E6%AD%A3%E5%9C%A8%E9%87%8D%E8%AF%95%E6%9C%8D%E5%8A%A1%E5%99%A8%E8%BF%9E%E6%8E%A5%20(%238)...%EF%BC%88%E5%9B%9E%E6%BA%AF%E4%BF%A1%E6%81%AF%EF%BC%88%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E9%80%9A%E8%AF%9D%EF%BC%89%EF%BC%9A%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%20%22%20%2Fhome%2Fdasmiddepogu%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-yocto-bsp%2Fsources%2F%E5%8F%82%E8%80%83%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%81%E7%B3%BB%E7%BB%9F%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E3%80%82%2Fbitbake%2Flib%2Fbb%2Fmain.py%20%22%EF%BC%8C%E7%AC%AC%20487%20%E8%A1%8C%EF%BC%8C%E4%BD%8D%E4%BA%8E%20setup_bitbake%20server_connection%20%3D%20bb.server.process.%20%3CBR%20%2F%3E%20connectProcessServer%EF%BC%88sockname%EF%BC%8Cfeatureset)%20%3CBR%20%2F%3E%20%E6%96%87%E4%BB%B6%20%22%20%2Fhome%2Fdasmiddepogu%2FDesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-yocto-bsp%2Fsources%2F%E5%8F%82%E8%80%83%E5%8F%91%E8%A1%8C%E7%89%88%E3%80%81%E7%B3%BB%E7%BB%9F%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E3%80%82%2Fbitbake%2Flib%2Fbb%2Fserver%2Fprocess.py%20%22%EF%BC%8C%E7%AC%AC%20686%20%E8%A1%8C%EF%BC%8C%E4%BD%8D%E4%BA%8E%20ConnectProcess%20%3CBR%20%2F%3E%20Server%20sock.connect%20(os.path.basename%20(sockname))%20%3CBR%20%2F%3EBlockingIOError%EF%BC%9A%5BErrno%2011%5D%20%E8%B5%84%E6%BA%90%E6%9A%82%E6%97%B6%E4%B8%8D%E5%8F%AF%E7%94%A8%3CBR%20%2F%3E%2C%2008%3A01%3A09.884445)%3CBR%20%2F%3EERROR%3A%20Unable%20to%20connect%20to%20bitbake%20server%2C%20or%20start%20one%20(server%20startup%20failures%20would%20be%20in%20bitbake-cookerdaemon.log).%3CBR%20%2F%3Edasmiddepogu%20%40dasmiddepogu-ThinkPad-L14-Gen-1%EF%BC%9A~%2Fdesktop%2Fdas%2Fproject%2Fimax8mpluseek%2Fimx-yocto-%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%2Fbuild%24%3C%2FP%3E%3CP%3E**************************************************************%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E8%BE%BE%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2141752%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20IMX8%20%20Plus%20%22Creating%20the%20BSP%20and%20Yocto%20build%20environment%22%20%20compile%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2141752%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F251894%22%20target%3D%22_blank%22%3E%40middepogudas%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%A6%81%E7%89%88%E6%9C%AC%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%E3%80%82(6.6.3)%E6%BA%90%E4%BB%A3%E7%A0%81i.MX8MP%20%E7%9A%84%E4%BB%A3%E7%A0%81%EF%BC%8C%E8%AF%B7%E4%BB%8E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DL6.6.3_1.0.0_Docs%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E6%96%87%E6%A1%A3%3C%2FA%3E%E4%B8%AD%E4%B8%8B%E8%BD%BD%20Yocto%20%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%E3%80%82%20%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E5%8F%82%E9%98%85%20%3CLI-EMOJI%20id%3D%22lia_red-heart%22%20title%3D%22%3Ared_heart%3A%22%3E%3C%2FLI-EMOJI%3E%20%E4%B8%BB%E6%9C%BA%E8%AE%BE%E7%BD%AE%26gt%3B%20%E7%94%A8%E4%BA%8E%20Ubuntu%20%E7%89%88%E6%9C%AC%EF%BC%88%E6%8E%A8%E8%8D%90%2020.04%2F22.04%EF%BC%89%E4%BB%A5%E5%8F%8A%26lt%3B3.2%20%E8%8A%82%E4%B8%BB%E6%9C%BA%E4%BB%A3%E7%A0%81%E5%8C%85%20%26gt%3B.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%0A%3CP%3E%E5%93%88%E7%BB%B4%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
