NAND boot Stride Size Fuse Value
1,846件の閲覧回数
rickardandersso
The i.MX 6SoloX Applications Processor Reference Manual refers to "Stride Size Fuse Value", but I have searched the reference manual without finding the actual register. Where can I set "Stride Size Fuse Value"?
Rickard
1,747件の閲覧回数
Yuri
  The stride size is usually the pages in each block which comes from the
boot configuration (Pages In Block) : “the search area contains copies of the FCB
at each stride distance, so in case the first NAND block becomes corrupted,
the ROM will find its copy in the next NAND block.”
Yuri
Note: If this post answers your question, please click the Correct Answer
button. Thank you!
1,748件の閲覧回数
Yuri
Yuri
button. Thank you!
