MMPF0100 power-down sequence when enters OFF mode.
1,633 次查看
satoshishimoda
Senior Contributor I
Hi community,
I have a question about MMPF0100.
You know in OFF mode, MMPF0100 stops all power outputs except VCOREDIG and VSNVS.
I want to know the power-down sequence of MMPF0100 outputs when MMPF0100 enters in OFF.
Would you let me know it?
Satoshi Shimoda
标记 (1)
1,532 次查看
igorpadykov
Hi Satoshi
MMPF0100  datasheet does not specify power-down sequence,
that means that sequencer is not used at power-down and one can
think that outputs are turned off simultaneously.
1,533 次查看
igorpadykov
Hi Satoshi
