MIPI CSI Clock questions
1,733 次查看
Eddy1
Contributor V
Hi:
Recently, I was testing the ov5640 camera on the imx8mm platform, but using an oscilloscope to test the 5640 MIPI clock, only 18M was found. How can I modify the mipi clock? The drive path I used is:drivers/media/platform/mxc/capture/ov5640_mipi_v2.c
1,501 次查看
Eddy1
Contributor V
HI:
I have resolved this issue and re ported the driver. Thank you for your support
4 回复数
1,708 次查看
joanxie
what bsp version do you use? did you use nxp board or your customized board? did you use your own bsp or nxp demo images?
1,697 次查看
Eddy1
Contributor V
Hi:
The board I customized, I'm using the 4.14 kernel.my own bsp(yocto)
1,685 次查看
joanxie
what dtb do you use? pls share it and share the logfile too, after board boot up d, pls dump the clock too,
1,502 次查看
Eddy1
Contributor V
HI:
