UART port configuration for stdout/stdin/stderr in u-boot
已解决
跳至解决方案
1,859 次查看
masa-ori
I am looking for information how to configure uart4 as console I/F in u-boot, because only uart4 can be assigned on my target board (i.MX8MP), and other else pins are used.
As a first step, I am trying to change the u-boot configuration on a i.MX8MPlus-BB EVK board.
In the u-boot source, I found CONFIG_MXC_UART_BASE is set as UART2_BASE_ADDR in the include/configs/imx8mp_evk.h and changed to UART4_BASE_ADDR, but board was stacked.
So please advise me how to configure uart4 as u-boot console.
Thanks in advance.
1 解答
1,794 次查看
masa-ori
Hi jackie2, thank you for information.
It takes a week because imx-atf build is challenge for me, I modified sources according to given information.
Finally build was completed and checked it is working.
Thank you.
在原帖中查看解决方案
2 回复数
1,839 次查看
jackie2
1,795 次查看
masa-ori
Thank you.
