MIPI CSI Clock questions
Eddy1
Hi:
Recently, I was testing the ov5640 camera on the imx8mm platform, but using an oscilloscope to test the 5640 MIPI clock, only 18M was found. How can I modify the mipi clock? The drive path I used is:drivers/media/platform/mxc/capture/ov5640_mipi_v2.c
Eddy1
HI:
I have resolved this issue and re ported the driver. Thank you for your support
joanxie
what bsp version do you use? did you use nxp board or your customized board? did you use your own bsp or nxp demo images?
Eddy1
Hi:
The board I customized, I'm using the 4.14 kernel.my own bsp(yocto)
joanxie
what dtb do you use? pls share it and share the logfile too, after board boot up d, pls dump the clock too,
Eddy1
HI:
