MFG Tool Issue
MFG Tool Issue
4,321 次查看
tony_l_cai
Hi All,
     when I used MFG Tool download the img to the board, The prompt stopped on the "Loading uboot",and didn't continue to the follow steps. What has happened?
     And what I need to do can make all work? please help me in detail. 3Q!
标签 (2)
4,098 次查看
igorpadykov
Hi tony
for new board please run DDR test
https://community.freescale.com/docs/DOC-96412
and rebuild MFG Tools with new board ddr settings in Uboot file flash_header.S
check sect.3.9 Building Manufacturing Firmware attached document
4,099 次查看
igorpadykov
Hi tony
4,098 次查看
tony_l_cai
The following picture is the operation after DDR stress tool testing:
and could you tell me some possible reasons?
4,098 次查看
igorpadykov
Hi tony
for new problem/qustion new thread should be
created.
Thanks !
~igor
