LVDS Display output in I.MX8QM Board
2,276 次查看
mallibeerala
How can I enable LVDS Display output in I.MX8QM Board, which dtb file, I have to load for enabling LVDS display.
I am able to get HDMI display by following dtb file fsl-imx8qm-mek-hdmi.dtb
Thanks & Regards,
Mallikarjuna B.
4 回复数
2,046 次查看
Sanjay_Pandey1
LVDS and MIPI Display is active by default in i.MX8QM MEY Evaluation Board. For HDMI you have to pass "hdmi" parameter while writing the image on board.
I had tested it by through MIPI to HDMI and LVDS to HDMI converter.
2,271 次查看
joanxie
the default dts file supports lvds already, which is imx8qm-mek.dtb
2,268 次查看
mallibeerala
I am getting following warning "it6263 7-004c: Probe failed. Remote port '/ldb@572410e0/lvds-channel@0' disabled" and at the same time I am getting HDMI display output properly.
Thanks & Regards,
Mallikarjuna B.
2,256 次查看
joanxie
did you use nxp demo images? imx8qm-mek.dts doesn't enable the hdmi, pls double check if you use the correct dtb file
"https://source.codeaurora.org/external/imx/linux-imx/tree/arch/arm64/boot/dts/freescale/imx8qm-mek.d..."
