LCD Screen Selection
1,647 次查看
oferlivny
I'm starting to develop on MX6 ARM2 CPU board, and I'm looking for the easiest solution for connecting a screen to the board.
I'm working with embedded linux, and don't have any specific requirements from the screen (other than it being small - 10 inch or so, and quick and easy setup). I need it mainly to for debug (other than using a terminal).
Did anyone had a good experience with integrating a display with this board through quick and easy setup and can post its details here?
标记 (2)
1,567 次查看
PrabhuSundarara
LVDS
http://www.hannstar.com/Common.aspx?mid=198&tmid=3&modid=4
BSP already has support for these displays. No need of any extra effort for integrating these displays.
1,567 次查看
oferlivny
Thanks for the reply!
Can you please specify a specific model of a display you have experienced with?
Will all displays require the same integration effort?
Prabhu Sundararaj said:
Easiest is using HDMI or LVDS display. If your requirement is limited to use 10 inch display, then go for LVDS display.
1,567 次查看
PrabhuSundarara
