Issues with meta-nxp-security-reference-design
malj
I just started to work on adding secure boot to my project (irst time and lot of reading). In the Linux User Guide, IMXLUG_6.6.23_2.0.0, from June 28 2024, section 10.9.1.3 Yocto setup for secure boot build, you cannot follow the steps due to a lacking manifest.
Also, when I manually added the layer, the nxp-cst-signer.bb  is pointing towards
CST_SIGNER ?= "git://[email protected]/imxs/cst-signer.git;protocol=ssh"
 which I assume is a place where I should not have access. I guess it might be ok to point it towards
https://github.com/nxp-imx-support/nxp-cst-signer.git
instead?
Is there a way to report such things, or is the forum the place to go? Are you using githubs issue tracker?
brian14
Hi @malj,
Thank you for your report, the expert team will fix the link.
In the meantime, you can use the GitHub link.
git://github.com/nxp-imx-support/nxp-cst-signer.git;protocol=https
brian14
Hi @malj,
Thank you for contacting NXP Support!
I have reviewed the case and currently, I'm checking with the team for possible solutions.
brian14
Hi @malj,
%3CLINGO-SUB%20id%3D%22lingo-sub-1906458%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIssues%20with%20meta-nxp-security-reference-design%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1906458%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3EI%20just%20started%20to%20work%20on%20adding%20secure%20boot%20to%20my%20project%20(irst%20time%20and%20lot%20of%20reading).%20In%20the%20Linux%20User%20Guide%2C%20IMXLUG_6.6.23_2.0.0%2C%20from%20June%2028%202024%2C%20section%20%3CSTRONG%3E10.9.1.3%20Yocto%20setup%20for%20secure%20boot%20build%3C%2FSTRONG%3E%2C%20you%20cannot%20follow%20the%20steps%20due%20to%20a%20lacking%20manifest.%3C%2FP%3E%3CP%3EAlso%2C%20when%20I%20manually%20added%20the%20layer%2C%20the%20nxp-cst-signer.bb%26nbsp%3B%20is%20pointing%20towards%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3ECST_SIGNER%20%3F%3D%20%22git%3A%2F%2Fgit%40bitbucket.sw.nxp.com%2Fimxs%2Fcst-signer.git%3Bprotocol%3Dssh%22%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%26nbsp%3Bwhich%20I%20assume%20is%20a%20place%20where%20I%20should%20not%20have%20access.%20I%20guess%20it%20might%20be%20ok%20to%20point%20it%20towards%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fnxp-cst-signer.git%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3Einstead%3F%3C%2FP%3E%3CP%3EIs%20there%20a%20way%20to%20report%20such%20things%2C%20or%20is%20the%20forum%20the%20place%20to%20go%3F%20Are%20you%20using%20githubs%20issue%20tracker%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBest%20regards%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1910075%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Issues%20with%20meta-nxp-security-reference-design%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1910075%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F193642%22%20target%3D%22_blank%22%3E%40malj%3C%2FA%3E%2C%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThank%20you%20for%20your%20report%2C%20the%20expert%20team%20will%20fix%20the%20link.%3C%2FP%3E%0A%3CP%3EIn%20the%20meantime%2C%20you%20can%20use%20the%20GitHub%20link.%20%3CBR%20%2F%3Egit%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fnxp-cst-signer.git%3Bprotocol%3Dhttps%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1907359%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Issues%20with%20meta-nxp-security-reference-design%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1907359%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F193642%22%20target%3D%22_blank%22%3E%40malj%3C%2FA%3E%2C%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThank%20you%20for%20contacting%20NXP%20Support!%3C%2FP%3E%0A%3CP%3EI%20have%20reviewed%20the%20case%20and%20currently%2C%20I'm%20checking%20with%20the%20team%20for%20possible%20solutions.%3C%2FP%3E%3C%2FLINGO-BODY%3E
