Issues with meta-nxp-security-reference-design
malj
I just started to work on adding secure boot to my project (irst time and lot of reading). In the Linux User Guide, IMXLUG_6.6.23_2.0.0, from June 28 2024, section 10.9.1.3 Yocto setup for secure boot build, you cannot follow the steps due to a lacking manifest.
Also, when I manually added the layer, the nxp-cst-signer.bb  is pointing towards
CST_SIGNER ?= "git://[email protected]/imxs/cst-signer.git;protocol=ssh"
 which I assume is a place where I should not have access. I guess it might be ok to point it towards
https://github.com/nxp-imx-support/nxp-cst-signer.git
instead?
Is there a way to report such things, or is the forum the place to go? Are you using githubs issue tracker?
brian14
Hi @malj,
Thank you for your report, the expert team will fix the link.
In the meantime, you can use the GitHub link.
git://github.com/nxp-imx-support/nxp-cst-signer.git;protocol=https
brian14
Hi @malj,
Thank you for contacting NXP Support!
I have reviewed the case and currently, I'm checking with the team for possible solutions.
brian14
Hi @malj,
