Is it possible to work with CAN Bus on Android Application?
5,301 次查看
trongthinh
I am using iMX8mq. I connected a module named MCP2515 (SPI to CAN converter) to SPI interface of iMX8. Linux kernel recognized the module as CAN0 (found by ifconfig). Is it possible to send/read data via CAN bus on Java Android Application?
标记 (3)
4,621 次查看
joanxie
yes, you can, for more information, pls refer to the link as below:
How to check if SPI is working?
https://community.nxp.com/thread/480207
4,621 次查看
joanxie
refer to the imx8M Reference Manual, imx8M doesn't have flexCAN
4,621 次查看
trongthinh
Hi Joan Xie,
I use SPI to CAN converter.  is it possible?
4,622 次查看
joanxie
