Is it possible to enable phonegap and java on LTIB for imx6q. Please reply if any one has enabled it.Enable phonegap framework, java on imx6q using LTIB
1,467 次查看
shalinikp
标签 (2)
1,097 次查看
igorpadykov
Hi shalini
for java please look at
All Boards Java
Minimal i.MX6 armhf image with Vivante fb (for JavaFX)
I am not aware of efforts with phonegap, probably you can try to ask
on meta-fsl-arm mailing list, so that someone familiar with phonegap could try to assist you.
https://lists.yoctoproject.org/listinfo/meta-freescale
1,097 次查看
shalinikp
Thanks for d reply. I will look into it. I also have another query. I need to install httpd-2.0.54.tar.gz(apache web browser) available in LTIB. But I m not finding the patch any where. Can you please help me in this, as where can I get the patch from ?
Shalini
1,097 次查看
igorpadykov
Please check
https://community.freescale.com/ideas/1066
