Inquiry Regarding Real-Time Processing with MIPI-CSI on i.MX 8MP
1,006 次查看
JH-LEE
I have an inquiry regarding MIPI-CSI on the i.MX 8MP.
Currently, I am using v4l2 to capture one frame at a time.
Is it possible to receive data on a line-by-line basis instead of frame by frame for real-time processing?
900 次查看
joanxie
I have already mailed to you, it seems that the mail is lost, can use DAM to capture, but should also based on frame
977 次查看
joanxie
i.mx8mp doesn't have such use case for real time
973 次查看
JH-LEE
Is it possible to use DMA to access the memory areas dequeued and queued by the V4L2 API?
Although, I understand that synchronization might be challenging.
901 次查看
joanxie
