Inquiry Regarding Real-Time Processing with MIPI-CSI on i.MX 8MP
1,000件の閲覧回数
JH-LEE
I have an inquiry regarding MIPI-CSI on the i.MX 8MP.
Currently, I am using v4l2 to capture one frame at a time.
Is it possible to receive data on a line-by-line basis instead of frame by frame for real-time processing?
894件の閲覧回数
joanxie
I have already mailed to you, it seems that the mail is lost, can use DAM to capture, but should also based on frame
3 返答(返信)
971件の閲覧回数
joanxie
i.mx8mp doesn't have such use case for real time
967件の閲覧回数
JH-LEE
Is it possible to use DMA to access the memory areas dequeued and queued by the V4L2 API?
Although, I understand that synchronization might be challenging.
895件の閲覧回数
joanxie
