Inquiry Regarding Real-Time Processing with MIPI-CSI on i.MX 8MP
JH-LEE
I have an inquiry regarding MIPI-CSI on the i.MX 8MP.
Currently, I am using v4l2 to capture one frame at a time.
Is it possible to receive data on a line-by-line basis instead of frame by frame for real-time processing?
joanxie
I have already mailed to you, it seems that the mail is lost, can use DAM to capture, but should also based on frame
joanxie
i.mx8mp doesn't have such use case for real time
JH-LEE
Is it possible to use DMA to access the memory areas dequeued and queued by the V4L2 API?
Although, I understand that synchronization might be challenging.
joanxie
