Import Processor Data with Config Tools for i.MX v7
2,897 次查看
Kazuma_Sasaki
Senior Contributor I
I am getting a config tool from following URL.
Config Tools for i.MX v7 Now Available
My development PC can not connect to internet due to security policy.
therefore, I would like to import processor data from other PC.
I have successfully done processor data exporting as attached file.
But, I could not import these data. Could you please teach me procedures to import data?
(1) Importing procedure
I have tried according to following user guide.
(2) Error description
After import data, I've tried create a new configuration. but, I could not find any data on the window as shown in the capture below.
Kazuma Sasaki.
标记 (1)
2,812 次查看
AldoG
Please try to import them manually, unzip the file in the following folder:
C:\ProgramData\NXP\mcu_data_v7
Open config tool and the processor data should be available.
Hope this helps,
Aldo.
4 回复数
2,813 次查看
AldoG
Hope this helps,
Aldo.
2,812 次查看
Kazuma_Sasaki
Dear Aldo,
I appreciate your support.
C:\nxp\i.MX_CFG_v7\mcu_data
<before unzip, following files stored.>
- resources
- offline_data.zip
<after unzip, following files stored.>
- resources
- offline_data.zip
- boards
- components
- processors
- ksdk2_0_info.xml
- npidata.mf
Unfortunately, I could not solve this issue by your workaround.
Should I need some more steps?
Kazuma Sasaki.
2,812 次查看
AldoG
Yes, please note that it is a different folder, please try to unzip in the following folder:
Aldo
2,812 次查看
Kazuma_Sasaki
Dear Aldo,
I am sorry for my wrong operation.
Finally, I could import data correctly. Thank you so much.
Kazuma Sasaki.
